You have clickable calc. Today I saw in your email that you have clickable physic but in french. Do you have it in english too>?
manolo
Hi everybody.
There are several weeks I'm on a school project and for it we need a Maplesim Simulation. It contains a sine voltage (source), a diode bridge (simplify), a condenser and a resistor. The problem is : when I want to simulate it, an error message appears : System is undetermined. I dopn't understand why I've this and from where's the problem...
If you could help me asap, it will be very very nice.
Have a nice day.
I'm using Maple 17 on Windows 8 (64-bit).
I have noticed that when I use the 'spacecurve' command and try to display it with the 'display' command, nothing shows up. I made sure that I used 'with(plots)' and 'with(plottools)', still nothing. However 'plot3d' works fine. I think it has something to do with the version of Java I'm using but I don't know what. Any help is welcome, thx
Specifications of my laptop:
Graphics: NVIDIA Geforce GT 740m
Processor: Intel(R) Core(TM) i7-3630QM (2.40GHz)
Ram: 6,00 GB
OS: Windows 8.1
AOA... I wan to plot the following piecewise function
f := x^2+1         if x belongs to (0,1)
f := x-x^2          if x belongs to (1,2)
f := x+1-x^2       if x belongs to (2,3)
I have this expression on image below and I would like to do multi taylor in these variables. The maple says that the expansion is not possible to do. Does somebody know where the problem could be ? Thank you very much for help.
Equation:
Taylor series:
Hi All,
I would like to request information the representation of the following result from Mathematica :
Mathematica result:    MeijerG[{{0, 1/2}, {}}, {{0, 1}, {-1, -1}}, a, 1/2]
Maple is able to take: MeijerG[{{0, 1/2}, {}}, {{0, 1}, {-1, -1}}, a] which is represented as
                                MeijerG([[0, 1/2], []], [[0, 1], [-1, -1]], a)
Could you please advise me on how to implement this function in maple. I would be grateful if you also include matlab in the discussion.
The matiematica output is a result of the following integration:
Integrate[r*(BesselI[1, al*r]* BesselK[1, al*r]), r]
Looking forward to your reply. Thanks in advance.
Raj
Hi guys, I am new on maple I have a simple question for you.
Let's say  A:=b^2*c
Then let's say D:=A*x
Maple give me as result something like D:=b^2*c instead of D:=A*x
And let's say E:=D*F I get E:=b^2*c*x*F instead of E:=A*x*F
My equation is more complicated than these but the problem is the same.
I hope I was clear in the explanation of the problem :)
Hi all;
Hope all of you  be in good health
I want to construct a special function b_{nm}(t) like:
with piecewise command i did it but the result is incorrect.
any one can help me to do it?
Best wishes
Mahmood   Dadkhah
Ph.D Candidate
Hey Guys
I'm designing some stuff for controll theory
There I met following problem:
I want calculate the matrix A which is the product of X and G.
A is 6x6 matrix and all values in the diagonal  are ones, the rest is undefined and should be calculated
X is 6x6 diagonal matrix with the values X1...X6
and G is also 6x6 and have all these values.
now I'm stuck 'cause I haven't used Maple frequently (only some simple stuff up to now, nothing with matrices)
I'd really appreciate it, if someone can tell how to tackle this problem
Cheers
I am trying to use Maple for Finite Element calculations. I have a 2d setup with linear basis functions and a 2d gaussian kernel that can rotate with respect to the axes. Attached please find the work sheet I am using.
Basis_function:
B := (x1,y1,x,y) -> max(0, 1-abs(x-x1))*max(0, 1-abs(y-y1))
transmissibility function:
t_hat:= (x1,y1,x,y) -> A*exp(-a*(x-x1)^2-2*b*(x-x1)*(y-y1)-c*(y-y1)^2)
where A  and a,b,c are positive constants. a,b,c are calculated based on an angle phi and the two variances of the gaussian function.
I want to calculate the following function for different points (x1,y1) , (x2,y2):
trans := (x1, y1, x2, y2) -> int(int(B(x1, y1, xz, yz)*(int(int(t_hat(xz, yz, xp, yp)*(B(x2, y2, xz, yz)-B(x2, y2, xp, yp)), xp = x2-10*sigma1 .. x2+10*sigma1), yp = y2-10*sigma2 .. y2+10*sigma2)), xz = x1-hx .. x1+hx), yz = y1-hy .. y1+hy);
this integral in the form that is in the work sheet, works well for phi=0 and the results are what I want (numbers that go to zero as we move points 1 and 2 away from each other). for other values for phi it either gives an error (too many levels of recursion) or it returns expressions that seem unreasonable when I evaluate them (they don't go to zero).
for example, it doesn't work for phi = 0.5 at all. for phi = Pi/4 it will calculate some expression,
but as you move away from a point (e.g. trans(0,0,100,100)) the value does not become smaller than a certain value, but they should go to zero.
It seems that what I am trying to do is very sensitive to a,b,c, but actually it shouldn't be so different. I like to avoid exact integration, and just get a number, but I have no idea how to do this numerically. and I don't know how to write the problem in a way that would work for every angle phi.
any ideas?
thanks in advace,2d_maple_primes.mw
with(plots); with(LinearAlgebra); with(ArrayTools)
Transmissibility function specifications
alpha := 1;
(1/4)*Pi
a := (1/2)*(cos(phi)/sigma1)^2+(1/2)*(sin(phi)/sigma2)^2;
17/64
15/64
17/64
A = (1/8)/Pi
Transmissibility*Kernel
t_hat := proc (x1, y1, x, y) options operator, arrow; A*exp(-a*(x-x1)^2-2*b*(x-x1)*(y-y1)-c*(y-y1)^2) end proc
B := proc (a, b, x, y) options operator, arrow; max(0, 1-abs(x-a))*max(0, 1-abs(y-b)) end proc
trans := proc (x1, y1, x2, y2) options operator, arrow; int(int(B(x1, y1, xz, yz)*(int(int(t_hat(xz, yz, xp, yp)*(B(x2, y2, xz, yz)-B(x2, y2, xp, yp)), xp = x2-10*sigma1 .. x2+10*sigma1), yp = y2-10*sigma2 .. y2+10*sigma2)), xz = x1-hx .. x1+hx), yz = y1-hy .. y1+hy) end proc
#####testing here######
#for phi == 0 the results are what i want, numbers that go to zero as the points go far from each other. for phi != 0 trans returns an expression and the evaluation of that expression doesn't go to zero as we move the points far apart.
trans(0, 0, 0, 1)
trans(0, 0, 1, 0)
trans(0, 0, 5, 5)
This should be zero for any angle
trans(0, 0, 50, 50)
Download 2d_maple_primes.mw
Hi, everyone.
I want to setup some conjugate rules for the quantum operator such as
conjugate(a) = a, conjugate(b) = -b.
And during the calculation progress, it works like
conjugate( k1*a + k2*conjugate(b) ) = conjugate(k1)*a + conjugate(k2)*b
#k1, k2 are complex numbers.
How can we build up this? I checked in the help system, but failed to find an answer.
I open a new subject about Fredholm Integral equation. My code work correctly.
But, I need some modification to get a nice display of the matrix found using
MatA,Vectb := GenerateMatrix(convert(sys3,list),Sol_phi);
such as Sol_phi is my solution that I want to find.
I introduced two function alpha1 and alpha2 in the code  see Equation (9) can I write all the coeficient of my matrix using the two function alpha[1] and alpha[2], it's better to see and read the matrix form.
Fred.mw
I have
Let
A:= sum(a[n]*phi(n)+b[n+1]*phi(n+2),n=0..N);
Please, I need to write this sum, using only phi(n), how can I use maple to get the solution.
Thank you very much for any idea.
Hi:
how calculate the integral the below function in maple?
int(sin(x)*delta(x-Zeta), x = 0 .. l)=sin(Zeta)
delta is delta function.
Hello;
I would like to extract data from a 2D plot to compare my numerical result in Matlab.
I used this command.
However, I need to spesify the nodes on x axis to get the error in Matlab. My matlab codes give the result as fix step size i.e [0 0.1 0.2 ... 1.0] or [0 0.01 0.02 ... 1.00] etc.
Is there any command in Maple to spesify the nodes on x axis?
Thanks you!
First 1436 1437 1438 1439 1440 1441 1442 Last Page 1438 of 2429
