Hello ,
2014_PDE_project.mw
I was using maple as a documentation software and was preparing some notes for my exam.
The file now opens but most of the content is gone. Even the one which was properly saved.
I see Joe Riel 5676 has solved an earlier case like this. could somebody look at this and correct the file and upload it again please.
Hello: I'm looking over the Help section but I can not find a Maple package that has a command to compute the symmetric sum or the cyclic sum. I just started working with inequalities. Please could anyone recommend a package that allows me to compute expressions related to Muirhead's Inequality (see part 2 of  the answer:  http://math.stackexchange.com/questions/488967/majorization-muirhead)
I want to introduce a matrix of order M by M as for any m, M, pl help as show in file
Help.mw
Dear all;
Please I have maybe a simple question. I need to point these nodes in R^3 using Maple. Thanks for your help.
Tab := [[0, 0, 0], [1/5, 0, 0], [2/5, 0, 0], [0, 1/5, 0], [1/5, 1/5, 0], [2/5, 1/5, 0], [0, 2/5, 0], [1/5, 2/5, 0], [2/5, 2/5, 0], [0, 0, 1/5], [1/5, 0, 1/5], [2/5, 0, 1/5], [0, 1/5, 1/5], [1/5, 1/5, 1/5], [2/5, 1/5, 1/5], [0, 2/5, 1/5], [1/5, 2/5, 1/5], [2/5, 2/5, 1/5], [0, 0, 2/5], [1/5, 0, 2/5], [2/5, 0, 2/5], [0, 1/5, 2/5], [1/5, 1/5, 2/5], [2/5, 1/5, 2/5], [0, 2/5, 2/5], [1/5, 2/5, 2/5], [2/5, 2/5, 2/5]]
This table contains some point of R^3. How can I put these point.
Hi All,
I have a stupid question.
I wanted to distinguish the fuction of map and Map and tried some test.
Sometimes, the Map is identical to the map:
But sometimes not:
Maple Help seems not to explain the difference very clearly.
map_and_Map.mw
I'd appreciate any help on this topic. Thank a lot.
Please help in this question.
Using   I want to plot in R^3, the set of point u[i,j]^k . This point has as cordinate  (x[i],y[j],t[k]).
x := i -> (1/5)*i;  #  x[i] the x-coordinate
y := j -> (1/5)*j; # y[j] the y-coordinate
t := k -> (1/5)*k;  #  t[k] the t-coordinate
The name of point is u[i,j]^k
How can I  plot all the point.
 with(geom3d):
point(u[i,j]^k, x(i),y(j),t(k));
Hi all
Assume that we have the following colomn vector:
and we want to construct the following matrix:
How can we do this with maple????
Note that r is a variable and the dimension of matrix depend on r.
regards
Mahmood   Dadkhah
Ph.D Candidate
Dear all;
I need a help in this question.
u(x,y,t) my solution of PDE. x,y space, and t=time.
In the case without t. .i.e. u(x,y). Here is a visualization of the lattice u(x_i,y_j). i=1..3, anf j=1..3.  Please try this example, it's working.
my question, if i would like to add a third variable t, i.e.  and get u(x_i,y_j,t_k)  on each points. I would like to show the lattice in (x,y) plan for each t_k. I Think I will get many parallel lattice.
Please can some one, modify this code to get the parallel lattice. Thanks.
with(PDEtools):
interface(rtablesize=20):
Here,
L := 'L':
N := 'N':
g := 'g':
Z := i -> -L+2*L/(N+1)*i;
x[0] = Z(0),x[N+1] = Z(N+1),y[0] = Z(0),y[N+1] = Z(N+1);
N := 4;
L := 1;
r := L/(N+1)/4;
ngon := (n,x,y,r,phi) -> [seq([x+r*cos(2*Pi*i/n+phi), y+r*sin(2*Pi*i/n+phi)], i = 1 .. n)]:
p[1] := display([seq(polygonplot(ngon(4,Z(0),Z(j),r,Pi/2),color=magenta),j=0..N+1),
seq(polygonplot(ngon(4,Z(N+1),Z(j),r,Pi/2),color=magenta),j=0..N+1),
seq(polygonplot(ngon(4,Z(i),Z(0),r,0),color=magenta),i=1..N),
seq(polygonplot(ngon(4,Z(i),Z(N+1),r,0),color=magenta),i=1..N),
seq(seq(polygonplot(ngon(20,Z(i),Z(j),r,0),color=white),i=1..N),j=1..N),
textplot([seq(seq([Z(i+0.1),Z(j),typeset(u[i,j])],i=0..N+1),j=0..N+1)],align={above,right})],view=[Z(-1)..Z(N+2),Z(-1)..Z(N+2)],tickmarks=[[seq(Z(i)=typeset(x[i]=evalf[2](Z(i))),i=0..N+1)],[seq(Z(i)=typeset(y[i]=evalf[2](Z(i))),i=0..N+1)]],
axes=boxed,scaling=constrained,labels=[``,``]):
p[1];
Hi All,
I used the command map to apply a procedure to elements of a array like this:
Why did I get the null array "[]"?
A vector was also used and got the similar result:
i want to find initial condition for F(0),G(0), H(0) and thetap(0) which is are missing in this problem.. then i facing this error Error, (in dsolve/numeric/bvp) Newton iteration is not converging
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/hydronew2.mw .
Download hydronew2.mw
Recently I started to learn to use maplesim. I wanted to set up a feedback system which is used to control the speed of DC motor. I don't know how to build it. Please give me some advice. I really appreciate your help.
Hi, with a list
l:=[1,1,1,2,3,3,4];
What's the best way to get the index(s) for the values equal to '1'?
Say for x=1, we want
[1,2,3]
for x=2, we want
[4]
ect.
I'm calculating the geodesics to a parametrized system in R3. When trying to solve the geodesic equations for a surface of revolution, I'm getting a strange error. The goal is to write the code for any parametrized surface, not just revolution (hence I didn't use the short cut for surfaces of revolution).
For the code, I find the first fundamental for, then the geodesics, then turn the christoffel symbols into a time-variant array. (Gamma for the position of (u,v) in the uv-plane, and C as the array so I can take derivatives with respect to time.)
The code for creating the Christoffel Symbols and the parametrization of the paraboloid:
restart; with(LinearAlgebra):
V := (u, v) -> <v*cos(u), v*sin(u), v^2+1>;
Christoff := proc (X)
local x1, x2, M, N, i, j, k, s, E, F, G, g, Q, Delta, Prelim, cyclicPrelim;
global Gamma, C; #GAMMA
x1 := (u, v) -> <diff(X[1], u), diff(X[2], u), diff(X[3], u)>;
x2 := (u, v)-> <(diff(X[1], v), diff(X[2], v), diff(X[3], v))>;
E :=  (u, v) -> DotProduct(x1(u, v), x1(u, v), conjugate = false);
F := (u, v) -> DotProduct(x1(u, v), x2(u, v), conjugate = false);
G := (u, v) -> DotProduct(x2(u, v), x2(u, v), conjugate = false);
simplify([E(u, v), F(u, v), G(u, v)]);
M := (u, v) -> <E(u, v), F(u, v); F(u, v), G(u, v)>;
simplify(M(u,v));
printlevel := 3;
Delta := simplify(Determinant(M(u, v)));
N := (1/Delta)*<G(u, v), -F(u, v); -F(u, v), E(u, v)>;
Q[1] := simplify(map(diff, M(u, v), u));
Q[2] := simplify(map(diff, M(u, v), v));
for i to 2 do for j to 2 do for k to 2 do
Prelim[i, j, k] := Q[k][i, j];
simplify(Prelim[i, j, k] ); end do end do end do;
#(OPTIONAL PRINTOUT) print(Prelim);
cyclicPrelim[i, j, k] := Prelim[i, j, k]+Prelim[j, k, i]-Prelim[k, i, j] ;
#(OPTIONAL PRINTOUT)  print(cyclicPrelim);
Gamma[i, j, k] := simplify((1/2)*add(N[i, s]*cyclicPrelim[j, s, k], s = 1 .. 2));
# for k from 1 to 2 do
#print(`GAMMA[i,j,k] =` Matrix([[ `%a` , `%a` ],[ `%a` , `%a` ]])` \n`, Gamma[1,1,k], [Gamma[1,2,k], Gamma[2,1,k], Gamma[2,2,k]);
# end do;
#printf('GAMMA[%a,%a,%a] = %a \n', i,j,k, Gamma[i,j,k]);
print([Gamma[1,1,1], Gamma[1,2,1], Gamma[2,1,1], Gamma[2,2,1], Gamma[1,1,2], Gamma[1,2,2], Gamma[2,1,2], Gamma[2,2,2]]);
for i from 1 to 2 do
for j from 1 to 2 do
C[i,j,k]:= apply(Gamma[i,j,k],t);
C:=Array(1..2,1..2,1..2,[ [ [ apply(Gamma[1,1,1],t), apply(Gamma[1,2,1],t) ], [ apply(Gamma[1,1,2],t), apply(Gamma[1,2,2],t) ] ], [ [ apply(Gamma[2,1,1],t), apply(Gamma[2,2,1],t) ],  [ apply(Gamma[2,1,2],t), apply(Gamma[2,2,2],t) ] ] ]);
print(C);
The differential equation solver:
inits:=[u(0)=1, D(u(t))(0)=1,v(0) = 1, D(v(t))(0)=1];
sys1:= [D[1$2](u(t))+C[1,1,1]*(D(u(t)))^(2)+2*C[1,1,2]*(D(u(t)))*(D(v(t)))+C[1,2,2]*(D(v(t)))^2=0, D[1$2](v(t))+C[2,1,1]*(D(u(t)))^(2)+2*C[2,1,2]*(D(u(t))*D(v(t)))^(2)+C[2,2,2]*(D(v(t)))^2=0];
L:=dsolve({sys1} union {inits});
The error message that comes up is:
"Error, (in unknown) invalid input: op expects 1 or 2 arguments, but received 0"
Any help would be greatly appreciated.
Hi say I have the vector V1.
V1:=Vector([a,b,c,d,e,f,g]):
and function myfun.
how do i use it as the input to the function my fun, by taking away each element in turn?
myfun(V1[2..]);              # 1st element removed
myfun(V1[[1,3..]]);         # 2nd element removed
myfun(V1[[1,2,4..]]);      # 3rd element removed
and so go
is there a more efficient way?
Many thanks,
Hi everybody,
I have never done statistics in Maple.  In a simple calculation, I need to calculate the RMS of 55 numbers.  The average of those numbers is 100484.3 and it is given that the RMS is 1.28 counts.  I have the a list of the 55 numbers.  Since I don't need a demonstration, it would help me a lot if you could tell me how to load the data from a *.txt file (one number per line), and use the appropriate commands to obtaine the result that is only given.
For the moment, I only need the steps to proceed with the calculations and how to do it in Maple.
Thank you very much in advance for your help.
Mario Lemelin
Maple 18 Ubuntu 13.10 - 64 bits
Maple 18 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
First 1440 1441 1442 1443 1444 1445 1446 Last Page 1442 of 2429
