Given the lagrangian from the pendulum physics example on the help page,
or text format.
L := -sin(omega*t-phi(t))*(diff(phi(t), t))*a*l*m*omega+(1/2)*(diff(phi(t), t))^2*l^2*m+cos(phi(t))*g*l*m
Hi Everybody.
Doing some calculation in quantum mechanics, I stuble on that integral:
I see immediately that the answer is 1/2.  But Maple 18 cannot give an answer other than a limit that he cannot evaluate.  I even try assumption that p and hbar are realcons.  I get infinity.
Any idea?
Mario Lemelin
Maple 18 Ubuntu 13.10 - 64 bits
Maple 18 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
Can anyone explain to me why there is a difference between:
f := int((A*sin(omega*t+phi)-B*sin(omega*t))^2, t);
and the expanded version:
f := int((A*sin(omega*t)*cos(phi)+A*cos(omega*t)*sin(phi)-B*sin(omega*t))^2, t);
Is there any difference between
Matrix(4,5,(K,C)->K+C);
Array(1..4,1..5,(K,C)->K+C);
Say if I have a very 'complicated' procedure myfunc(K,C) that takes two options, but it runs all dependently.
Matrix(4,5,(K,C)->myfunc(K,C));
Array(1..4,1..5,(K,C)->myfunc(K,C));
Which one is more efficient? The final ouput of each run from myfunc is just a integer value.
The reason I am asking it that i think both runs on a 'single' thread (core) as CPU usage is always very low, around 15-20%.
If I look at the task manager, some cores (threads) arent doing anything.
Is there anyway to speed things up?
I am trying to get a Fourier transform of a Gaussian:
so I say
and get
The Fouriertransform of a Gaussian is well known and the result I expect is something like
exp(1/2*sigma^2*omega^2)
ignoring normalizations & other factors. I know that I can add functions to inttrans, but I kind-of expected inttrans[fourier] to know how to transform a Gaussian, it is a commonly used transformation. Even if I set phi0 to 0 it does not produce anything useful.
Mac Dude
hello, i'm trying to rewrite the RiemannSum function, it's for my homework,
i wrote the entire fonction, but looks like my function is not evaluated, i don't understand why!!! if anyone could see what's wrong please let me know, thanks. here is  my piece of code, and i also attached the file
> with(Student[Calculus1]);
> with(plots);
> with(plottools);
> f(x):= (1)/(5.6 sqrt(2 Pi))*exp(-((x-169)^( 2 ))/(2(5.6)^(2)));
SR:=proc(a, b, f, n) description "Les sommes de Riemann";  local Delta, x,SR,xetoile, i;  Delta:= (b-a)/(n);  for i from 0 to n by 1 do  x(i):= a + i*Delta;  end do;  for i from 1 to n by 1 do  xetoile(i):= (1)/(4)(x(i) + 3 x(i-1));  end do;  SR := 0;  for i from 1 to n by 1 do  SR := SR + f(xetoile(i))*Delta;  end do;  return SR  end proc;
if i compute the procedure SR(0, 150, f(x), 10), it doesn't give a result
Hi.
Please, I need your help, to form and solve a linear system.
1) I want to solve the system (13) using "GenerateMatrix" , the system is   evaluated  at  point x[m]=-a+m*h, m=0..2N , In my code I get  equation (15), ( I think it's okay), I juste use subs, x=x[m].
My function, ph(x) approximate by phi[m]=phi(x[m]).  and I want to compute the vecteur [phi[1], phi[2],...,phi[2*N+1]] is my solution.
2) The nodes, are x[k]=-a+k*h, k=0..2*N;  I want to display these nodes in the x-axis, i write the code with the names of each point, but there is an error.
There is some a mistake in my code maple.
Here, my code.
Fred.mw
coeff dosn't work correctly in maple 17
Here is the code
E := m1*(diff(x1(t), t, t))+3*k*x1(t)-k*x3(t)-k*x2(t);
coeff(E, x1(t));
Error, unable
the coeff of diff(x1(t),t,t) and x2(t) and x3(t) can be determined and are true, but the coeff of x1(t) can not be determined??!!!!!!!!!!!!
Hello , Happy weekend ... I need a help on plot of a wavefunction give below , i have made the plot using plot3d in cylindrical coordinate. But what i need now is the Polar plot of it. And it always comes with the code ensure calling sequence is correct.
psi(r,phi):= C[0, .1]*BesselI(4, 2*lambda*exp((1/2*I)*phi))*BesselJ(2, 1/r)+C[1, .1]*BesselI(6, 2*lambda*exp((1/2*I)*phi))*BesselJ(3, 1/r)+ C[2, .1]*BesselI(8, 2*lambda*exp((1/2*I)*phi))*BesselJ(4, 1/r)+ C[3, .1]*BesselI(10, 2*lambda*exp((1/2*I)*phi))*BesselJ(5, 1/r)+ C[4, .1]*BesselI(12,2*lambda*exp((1/2*I)*phi))*BesselJ(6, 1/r)+ C[5, .1]*BesselI(14, 2*lambda*exp((1/2*I)*phi))*BesselJ(7, 1/r)+C[6, .1]*BesselI(16, 2*lambda*exp((1/2*I)*phi))*BesselJ(8, 1/r)+ C[7, .1]*BesselI(18, 2*lambda*exp((1/2*I)*phi))*BesselJ(9, 1/r);
C[0, .1]:= 2.222222222*10^11;  C[1, .1]:=8.333333333*10^18 ; C[2, .1]:=6.250000000*10^26 ; C[3, .1]:= 2.127659574*10^32; C[4, .1]:= 3.125000000*10^43 ; C[5, .1]:=1.639344262*10^52 ; C[6, .1]:=1.408450704*10^61; C[7, .1]:=1.886792453*10^70;
My 1st case:
lambda:=0.1; plot3d(abs(psi(r,phi))^2,phi=0..2*Pi,r=0..5, coords=cylindrical);
2nd case: What i want.
lambda:=0.1; plot(abs(psi(r,phi))^2,r=-0..5, phi= 0..2*Pi, coords = polar);
ex := taylor(exp(x), x = 0, 5);
it can not use with subs(x=1,ex);
how to remove O(x^5) part
How can I use maple and separation of variables ,solve the wave equation utt=uxx for a string of lengh 4 with u(x,0)=sin (Pi/2 x) e-x . ut(x,0)=0.u(0,t)=0 and u(4,t)=0.
Is there a way to solve the following integral completely?
int(int(x^2+y^2, y = -sqrt(2*a*x-x^2) .. sqrt(2*a*x-x^2)), x = 0 .. 2*a)
When I try solving that all I get is the following:
All is well when I calculate it using polar coordinates though:
int(int(r^3, r = 0 .. 2*a*cos(t)), t = -(1/2)*Pi .. (1/2)*Pi)
Why doesn't maple solve the first one completely and is there a way around this?
Calor
Hello everybody,
While doing a document about quantum mechanics, I stumble on this strange behaviour.
>with(ScientificConstants);
>GetConstant(a[0]);
>GetValue(a[0])
Error message:
Error, (in ScientificConstants:-GetValue) `a[0]` is not a scientific constant object
But in the Assistant Scientific Constant, the value is there: 5.291772e-11m
Why is it not directly available like I did the first time?
Mario Lemelin
I would like to ask if one can divide the maple worksheet (mw) to multiple files like series of command. It could be simillar to include in C++. I have found only save and read command but they can be use only for variables or they can be use in other way ?
Thank you for any possible solution,
vidocq
First 1438 1439 1440 1441 1442 1443 1444 Last Page 1440 of 2429
