Hi.
Please help to use dsolve.
Suppose I have a Matrix A of size two. Y=[u,v].
Y'(t)=A*y(t).
How can use dsolve this problem.
I am using Maple to plot steady state diagrams.
Initially I just plot the diagram, then I work out stability, and want to change the linestyle - solid for stable, dashed for unstable. is there a way I can manually select parts of the line on the plot and change the linestyle, or do I need to do several different plots and combine with display?
Any suggestions on the easiest way to plot steady state diagrams in Maple would be appreciated.
lonelyoak
EDIT
So I have plotted my whole steady state diagram via implicit plot, so if I try and select parts of it I get the whole graph. My alternative seems to be to plot all the branches seperately, which is possible but just time consuming.
EDIT
Sorry I don't think I made what I was asking for clear. I want to be able to select segments of the graph and change the linestyle on certain parts.
For example if I had plotted x^2 between -2 and 2, I might want to put a dashed line when y is between 1 and 2 and x is positive. Is this possible without breaking it up into seperate plots?
Is there any simple way to print the sum of a series with exceptions?
For example, the following works (sort of), but its not consistent with mathematical notation, where one would expect to see something like a Sigma^' printed out, and the condition, alongw ith ther limits appear under the Sigma sign:
[Sum(1/(k^2-p),k=0..infinity),And(k<>p)]
Hi MaplePrime-ers!
I've been using the Maple(17) toolbox in Matlab(2012b) to quickly enumerate systems of equations by: (i) solving them symbolically, (ii) using unapply to make them functions, (iii) then supplying the points (driver equations) to get the system solution.  Speed is a must, because there may be 3 million+ systems to solve.  Symbolics is also very important because I am evaluating topology, so the structure of the equations may change, and therefore a functional approach will not work.
I have had success (seen in the first code snippet).  I would like similiar behaviour in the second code snippet, but sometimes I get 'solutions may be lost' as an error message,  or 'Error, (in unapply) variables must be unique and of type name'
The system of equations include:  Linear equations, 5th order polynomials, absolute functions, and pieceiwse functions.
Here is code with a topology that solves:
#Interconnection Equations
eq2[1] := FD_T + EM2_T = 0;
eq2[2] := ICE_T + GEN_T = 0;
eq2[3] := EM2_A + GEN_A + BAT_A = 0;
eq2[4] := -FD_W + EM2_W = 0;
eq2[5] := -ICE_W + GEN_W = 0;
eq2[6] := -EM2_V + GEN_V = 0;
eq2[7] := -EM2_V + BAT_V = 0;
#ICE
eq_c[1] := ICE_mdot_g=((671.5) + (-21.94)*ICE_T + (0.1942)*ICE_W + (0.5113)*ICE_T^2 + (-0.01271)*ICE_T*ICE_W + ( -0.0008761)*ICE_W^2 + (-0.006071)*ICE_T^3 + (9.867e-07)*ICE_T^2*ICE_W + (5.616e-05)*ICE_T*ICE_W^2 + (1.588e-06)*ICE_W^3 + (3.61e-05)*ICE_T^4 + (8.98e-07)*ICE_T^3*ICE_W + (-2.814e-07)*ICE_T^2*ICE_W^2 + (-8.121e-08)*ICE_T*ICE_W^3 + ( -8.494e-08 )*ICE_T^5 + (-2.444e-09)*ICE_T^4*ICE_W + (-9.311e-10)*ICE_T^3*ICE_W^2 + ( 5.835e-10)*ICE_T^2*ICE_W^3 ) *1/3600/1000 * ICE_T * ICE_W;
#BAT
eq_c[2] := BAT = 271;
#EM2
EM2_ReqPow_eq := (-148.3) + (4.267)*abs(EM2_W) + (12.77)*abs(EM2_T) + (-0.0364)*abs(EM2_W)^2 + ( 1.16)*abs(EM2_W)*abs(EM2_T) + (-0.258)*abs(EM2_T)^2 + ( 0.0001181)*abs(EM2_W)^3 + (-0.0005994)*abs(EM2_W)^2*abs(EM2_T) + ( 0.0001171)*abs(EM2_W)*abs(EM2_T)^2 + (0.001739 )*abs(EM2_T)^3 + (-1.245e-07 )*abs(EM2_W)^4 + ( 1.2e-06)*abs(EM2_W)^3*abs(EM2_T) + ( -1.584e-06)*abs(EM2_W)^2*abs(EM2_T)^2 + ( 4.383e-07)*abs(EM2_W)*abs(EM2_T)^3 + (-2.947e-06)*abs(EM2_T)^4;
eq_c[3] := EM2_P = piecewise( EM2_T = 0, 0, EM2_W = 0, 0, EM2_W*EM2_T < 0,-1 * EM2_ReqPow_eq, EM2_ReqPow_eq);
eq_c[4] := EM2_A = EM2_P/EM2_V;
#GEN
GEN_ReqPow_eq:= (-5.28e-12) + ( 3.849e-14)*abs(GEN_W) + (-71.9)*abs(GEN_T) + (-1.168e-16)*abs(GEN_W)^2 +(1.296)*abs(GEN_W)*abs(GEN_T) + (2.489)*abs(GEN_T)^2 + (1.451e-19)*abs(GEN_W)^3 + (0.0001326)*abs(GEN_W)^2*abs(GEN_T) + (-0.008141)*abs(GEN_W)*abs(GEN_T)^2 + (-0.004539)*abs(GEN_T)^3 +(-6.325e-23)*abs(GEN_W)^4 + (-2.091e-07)*abs(GEN_W)^3*abs(GEN_T) + ( 3.455e-06)*abs(GEN_W)^2*abs(GEN_T)^2 + ( 2.499e-05)*abs(GEN_W)*abs(GEN_T)^3 + (-5.321e-05)*abs(GEN_T)^4;
eq_c[5] := GEN_P = piecewise( GEN_T = 0, 0, GEN_W = 0, 0, GEN_W*GEN_T < 0,-1 * GEN_ReqPow_eq, GEN_ReqPow_eq);
eq_c[6] := GEN_A = GEN_P/GEN_V;
#ASSUMPTIONS
assume(BAT_V::nonnegative);
assume(FD_W::nonnegative);
#FINAL EQUATIONS
sys_eqs2 := convert(eq2,set) union {eq_c[1],eq_c[2],eq_c[3],eq_c[4],eq_c[5],eq_c[6]};
#Selecting which variables to solve for:
drivers2:= { ICE_T,ICE_W,FD_T,FD_W};
symvarnames2:=select(type,indets(convert(sys_eqs2,list)),name);
notdrivers2:=symvarnames2 minus drivers2;
#Symbolic solve
sol2:=solve(sys_eqs2,notdrivers2) assuming real:
symb_sol2:=unapply(sol2,convert(drivers2,list)):
#Enumerate (there will generally be about 40, not 6)
count := 0;
for i1 from 1 to 40 do
     for i2 from 1 to 40 do
          for i3 from 1 to 40 do
               for i4 from 1 to 40 do
                    count := count + 1;
                    solsol2(count) := symb_sol2(i1,i2,i3,i4);
               od;
          od;
     od;
od;
count;
This works great!  I would like simliar output in my second code snippet, but this time with more inputs to symb_sol.  However, if I try and change the interconnection equations a little, and add a piecewise function, and another driver... (differences in bold)
eq1[1] := FD_T+EM2_T = 0;
eq1[2] := ICE_T+GBb_T = 0;
eq1[3] := GEN_T+GBa_T = 0;
eq1[4] := EM2_A+GEN_A+BAT_A = 0;
eq1[5] := -FD_W+EM2_W = 0;
eq1[6] := -GEN_W+GBa_W = 0;
eq1[7] := -ICE_W+GBb_W = 0;
eq1[8] := -EM2_V+GEN_V = 0;
eq1[9] := -EM2_V+BAT_V = 0;
#ICE
#BAT
#EM2
#GEN
#GB
FiveSpeedGearbox_R := proc(ig)
local i ,eq;
i[1]:=3.32;
i[2]:=2;
i[3]:=1.36;
i[4]:=1.01;
i[5]:=0.82;
eq:= piecewise(ig=1,i[1],ig=2, i[2],ig=3,i[3],ig=4,i[4],ig=5,i[5],1);
return eq(ig);
eq_c[7] := GBb_T = -1/GB_R * GBa_T;
eq_c[8] := GBb_W = GB_R * GBa_W;
eq_c[9] := GB_R = FiveSpeedGearbox_R(ig);
#System Equations
sys_eqs := convert(eq1,set) union convert(eq_c,set);
 #Solve for variables
symvarnames:=select(type,indets(convert(sys_eqs,list)),name);
drivers:= {ig, ICE_T,ICE_W,FD_T,FD_W};
not_drivers := symvarnames minus drivers;
#Assumptinons
sol:=(solve(sys_eqs,not_drivers) assuming real);
symb_sol:=unapply(sol,convert(drivers,list)): ---> Error, (in unapply) variables must be unique and of type name
Subsequent parts don't work...
count := 0;
                    for i5 from 1 to 40 do
                         count := count + 1;
                         solsol2(count) := symb_sol2(i1,i2,i3,i4,5);
                    od;
               od;
          od;
     od;
od;
count;
While running the last line sol:, 1 of 2 things will happen, depending on the solver. Maple17 will take a long time (30+ minutes) to solve, then report nothing, or sol will solve, but will report "some solutions have been lost".
Afterwards, evaluating symb_sol(0,0,0,0,0) will return a viable solution (real values for each of the variables).  Whereas evaluating symb_sol(0,X,0,0,0), where X <> 0, will return and empty list [].
Does anyone know how to (i) speed up the symbolic solve time?  (ii) Return ALL of the solutions?
Thanks in advance for reading this.  I've really no idea why this isn't working.  I've also attached two worksheets with the code: noGB.mw   withGB.mw
 Adam
When running setup file Maple18WindowsX64Installer.exe (user has administative permissions), white blank window with no elements (buttons,menus,etc) appears and nothing happens (link to screenshot -http://s020.radikal.ru/i711/1403/d5/f33ac2f06181.png ). This problem seems due the Bitrock InstallBuilder packer which is used in last version of Maple installers for Windows. Is it possible to fix this problem? If no, could you please provide link to Maple installer prepared by previous packers?
hi all.
i have a system of ODE's including 9 set of coupled OED's .
How do I know if I have the latest Maple build id?  What is it now?
How do i write Hassell equation: Xn+1=(Ro*Xn)/(1+Xn)^4 in maple? I need that specific syntax as a procedure with three inputs (Xo, Ro, n), so it will calculate X up to n (X1,X2, X3 and so on up to 50). I already try it and i used for loop but it doesn't work. Any ideas? Thank you.
Dear all;
I have a simple question about round and floor. Please read these line.
I have an interval [0,a].  For a given step size h=a/N; N is an integrer.
all the noeuds in this interval are X[i]:=i*h; must be in the interval [0,a].
If we make a procedure with input h, and a. ANd the oupt put x[i]. I try this
sol:=proc(h,a)
local x, N, i;
x[0]:=0;
## My question how we define the N in the next line.  N:=floor(a/N); or N:=round(a/h);
N:=round(a/h);
for i from 0 to N-1 do:
x[i+1]:=x[i]+h;
seq([[x[i]], i=0..N);
for example
a*b v a^-1 = b
i guess Disj or Conj are Max or Min respectively
however i do not know how to max(a,b) where a and b are permutation group
reference from L group in
http://books.google.com.hk/books/about/Lattice_Ordered_Groups.html?id=_qAFX38-pKkC&redir_esc=y
if can not calculate this, do not know how to determine whether equal in a*b v a^-1 = b
After simulate the model of MapleSim, I can only know the curve of where I need to know about. I need the specific parameter(each point value), like a piece of sheet. How I can put it of in an Excel of Word?
I have a problem with export value from module.
Could you somene check?,
Thank's in advance.
test.mw
wz
computer the Gram-Schmidt orthogonal of (22,11,5),(13,6,3),(-5,-2,-1) belong to R^3.
By solving cubic equation in maple (version 17), I got
-0.363700352e-2*y^3-.4041941000*y^2+3.397775673*y-2.377540486 = 0
[[y = .7709248124], [y = 7.123944371], [y = -119.0286907]]
Now I want to find these roots through the formula.
I solve it generally in Maple..
``# Suppose
A*y^3+B*y^2+C*y+E = 0
A := -0.363700352e-2:
B := -.4041941000:
C := 3.397775673:
E := -2.377540486:
y1 := (1/6)*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)/A-(2/3)*(3*A*C-B^2)/(A*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3))-(1/3)*B/A
-45.82526955*(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)-36.74197467/(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)-37.04460717
-119.0286907-0.1e-8*I
y2 := y = -(1/12)*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)/A+(1/3)*(3*A*C-B^2)/(A*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3))-(1/3)*B/A+(1/2*I)*sqrt(3)*((1/6)*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)/A+(2/3)*(3*A*C-B^2)/(A*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)))
y = 22.91263477*(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)+18.37098733/(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)-37.04460717+((1/2)*I)*3^(1/2)*(-45.82526955*(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)+36.74197467/(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3))
y = .770924807+0.1772050808e-7*I
y3 := y = -(1/12)*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)/A+(1/3)*(3*A*C-B^2)/(A*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3))-(1/3)*B/A-(1/2*I)*sqrt(3)*((1/6)*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)/A+(2/3)*(3*A*C-B^2)/(A*(-108*E*A^2+36*A*B*C+12*sqrt(3)*sqrt(27*A^2*E^2-18*A*B*C*E+4*A*C^3+4*B^3*E-B^2*C^2)*A-8*B^3)^(1/3)))
y = 22.91263477*(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)+18.37098733/(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)-37.04460717-((1/2)*I)*3^(1/2)*(-45.82526955*(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3)+36.74197467/(.7114884222-(0.5542993294e-1*I)*3^(1/2))^(1/3))
y = 7.123944373-0.1692050808e-7*I
y1, y2, y3 formulas are computed by Maple by solving it for general formula.
But, now I got answers in real and imaginery parts, i.e
y1 = -119.0286907-1.*10^(-9)*I
y2 = .770924807+1.772050808*10^(-8)*I
y3 = 7.123944373-1.692050808*10^(-8)*I
Why, is it so?
I want answers in simple forum directly only by using these formulas. As i have to show the proof!
Download qstn.mw
computer a Gröbner basis for <f_[1] = x^2*y - 2*y*z + 1, f_[2] = x*y^2-z^2+ 2*x,  f_[3] = y^2*z - x^2+ 5 > belong to Q[x,y,z], using ≺= <_grlex with x≺y≺z. compare your output to the Gröbner basis the Maple computers with a different order.
First 1450 1451 1452 1453 1454 1455 1456 Last Page 1452 of 2429
