(Observeration, Hypothesis) = (then,if)
I want to use all logic with just a custom logic MP(A,B), simply notation as (A,B)
and convert all basic logics into above definition
A -> B = (B,A)  --- implication
(not (not A)) v B = (B,not A) -- Disj
not (not (A ^ B)) = not( (not A) v (not B) ) = not(not B, A) -- Conj
when i meet Disj and Conj
Is not(not B, A) = (B, not A) ?
if so, i am confused as it conclude Disj = Conj ?!
the reason i ask this is that Not logic make pattern not match
i have thought to make not(Prop("Go")) to become Prop("not Go") if not logic can move into proposition
if not logic has distributivity
i design this
because convenient of calculation
however, i do not understand not applied in not(Observeration, Hypothesis) if it can not move into bracket to become (not Observeration, not Hypothesis)
or
should it not(Observeration, Hypothesis) = (Observeration, not Hypothesis) ?correct?
Hi, I would like to write this :
as simply as possible with maple instructions.
Example :
thx.
Eq1:=diff(f(x),x)=1;
f:=1:
plot(1,x=0..10);
cs:=(f)(0)=0;
p:=dsolve({Eq1,cs},numeric);
odeplot(p, [x,diff(f(x),x)], 0..10);
why I cannot get a plot diff(f(x),x) like this?
whats going on here?
Hello everyone!
I have a question that I can't seem to find a straight answer to. I need to fit a circle to a collection of points that a circular in nature. I was trying to use the following elliptical least squares fit, but I can't determine what I should be minimizing.
Here's the page:
http://www.maplesoft.com/applications/view.aspx?SID=1395&view=html
For an ellipse, I used the general conic:
F:=a*x^2+b*x*y+c*y^2+d*x+e*y+f
I minimize using:
V:=Minimize(E,{4*a*c-b^2=1});
What would I use for a circle? Or is there a better way for a circle?
Let me first explain what I mean by 'color mapped scatter plot'.
Suppose we have a three dimensional coloum data like
[[1, 1, 0],[1, 2, 2],[1, 3, 3],[2, 1, 1],[2, 2, 4],[2, 3, 5],[3, 1, 2],[3, 2, 1],[3, 3, 3]]
The first two numbers are independendant variables, and the 3rd ones indicate 'values' at the given two independent variables.
Then, for example, if I use Origin 8.5, I can make a so called color mapped scatter plot which gives me a plot like usual two dimensional scatter plot but the color of the symbols are determined by the values in the third column.
I show an example from the Originlab, http://www.originlab.com/www/helponline/origin/en/UserGuide/Color_Mapped_Graph.html,
An example of the color mapped scatter plot made with Origin
I looked into the manual, etc. but I could not find a way. Because data are not evenly and homogeneously spread over x-y plane, and not dense, typical contour plot cannot be used.
Does anyone have a quick idea?
write a maple package for quaternion polynomials.it must include the following procedures:
1) for quaternion polynomials f, g:  find degree of f , compute f +g ,f-g, fg.
2)for matrices over quarternion polynomials A,B: compute A+B,A-B, AB.
hint using records to represent quaternions.
I have a procedure I need to place Inline and am not sure how to do this.
Please help me to write a procedure that calculate the Integer remainder ( that do the same job as irem but I should not use any other maple procedures)
Hello everyone!
I used Maple 17 to fit an ellipse to a set of points using the following guide:
My rotated ellipse was calculated to be:
SOL;
0.3939708949 x^2 - 0.005975799853 + 0.6345432059 y^2
But everytime I try to graph it in Maple 17, it only shows the axes and nothing else. Any help would be extremely appreciated.
I am recently using maple to plot poincare surface of section, and when I do the harmonic hamiltonian I need to fix different values of p1,q1,p2 and q2 in a tyler series expansion. So i'm expected to use the numbers from a txt file to caculate the tyler series expansion. But after i realize the "readdata" code, i don't know what to do next...
Can anybody tell me how to operate those data please?
Thank you very much!
By the way, I'm not a native English speaker, if my question is unclear please ask me for confirming...
I have some data:
Matrix(10, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = .5, (2, 2) = 3.25, (3, 1) = 1.0, (3, 2) = 5.82, (4, 1) = 1.5, (4, 2) = 7.50, (5, 1) = 2.0, (5, 2) = 8.79, (6, 1) = 2.5, (6, 2) = 9.83, (7, 1) = 3.0, (7, 2) = 10.66, (8, 1) = 3.5, (8, 2) = 11.35, (9, 1) = 4.0, (9, 2) = 11.94, (10, 1) = 4.5, (10, 2) = 12.46})
I want Maple to make a trendline fitting a Logarithmic function. I can make it output some function with this:
LeastSquares(`<,>`(.5, 1.0, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5), `<,>`(3.25, 5.82, 7.50, 8.79, 9.83, 10.66, 11.35, 11.94, 12.46), x, curve = a+b*ln(x))
It outputs:
5.96497783539274+4.25309474196387*ln(x)
But please notice, the dataset in the function does not have the first 0 and 0. If i do that:
LeastSquares(`<,>`(0, .5, 1.0, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5), `<,>`(0, 3.25, 5.82, 7.50, 8.79, 9.83, 10.66, 11.35, 11.94, 12.46), x, curve = a+b*ln(x))
It outputs:
Error, (in Matrix) numeric exception: division by zero
Besides that, i need the R-squard value for determinating how well it fits.
If i do the same thing i Excel the data set will give a formular: 5.5464ln(x)-0.2175 with a R-sward value of 0.9985.
How can i do this i maple?
Thanks in Advance!
Emil Kristensen
A large procedure I made caused me some problems. I finally found the source of the problem.
There seems to be some interaction between the end of parameters marker, $, and the elementwise operation ~.
Consider these 3 versions of essentially the same procedure:
Q1:=proc(Var::list,$) local n;
  n:=nops(Var);
  print(Var,n);
  proc(var::list)
       subs(Var=~[seq(1..n)],var); #Elementwise
Q1([x,y]); #Doesn't work : "invalid expression"
Q2:=proc(Var::list,$) local n;
  n:=nops(Var);
  print(Var,n);
  proc(var::list)
      subs(zip(`=`,Var,[seq(1..n)]),var); # zip
Q2([x,y]); #No problem
Q3:=proc(Var::list) local n; #No end of parameters marker $
  n:=nops(Var);
  print(Var,n);
  proc(var::list)
       subs(Var=~[seq(1..n)],var); # Elementwise
Q3([x,y]); # No problem
lprint(Q3([x,y])); #Curious output involving ` $`
#A fourth procedure in which the output is not a procedure works:
Q4:=proc(Var::list,$) local n;
  n:=nops(Var);
  print(Var,n);
  subs(Var=~[seq(1..n)],Var)
Q4([x,y]);
Does anybody have any comments? Is it a bug?
This is a silly question, but Maple's help menu didn't address it, and I couldn't find an answer in a few minutes of Web-surfing.  I have Maple15 installed on my office PC.  I have managed to set the default settings to avoid Maple's recent "disprovements", so that, for example, I can see what I've typed.  Using Maple today, in worksheet mode, for some reason a command prompt does not appear after I execute a command.  I want one to.  Does anyone know how to fix this?
GS
AOA...I want to introduce an operator to find the derivative of fractional order i.e.,
J^((alpha)) x^(k):=(GAMMA(k+1))/(GAMMA(k-alpha+1))x^(k-alpha):
when i applied J^(1/2) on x^2+x^3 it gives
GAMMA(3)*x^(3/2)/GAMMA(7/2)+GAMMA(4)*x^(5/2)/GAMMA(9/2)
Help.mw
First 1454 1455 1456 1457 1458 1459 1460 Last Page 1456 of 2429
