I would like to know whether it is possible to change the color of animations that have already been produced and assigned to a variable.
Let's take for example
P := plots:-animate(plot, [sin(x+t), x = -Pi .. Pi], t = -Pi .. Pi, frames = 8)
is there a command to change the color of the curve AFTER it has been produced?
The calculus to generate all my plots took 4 hours so I would like not to have them calculated again.
Thx
How can I typeset this in Maple? A ket with a 2 element column vector in it, but without the vector brakets. Like this:
| x over y >
AOA... Pl correct it
Help.mw
can we load part of a package not the package whole !? for example from physics package i only need diff tool not all of the package tools,can i do sth for that !?
Eq1:=diff(psi(y),y$4)-diff(psi(y),y$2)=0;
dsolve({Eq1});
bcs:=psi(h1)=F,D(psi)(h1)=-1,psi(h2)=-F,D(psi)(h2)=-1;
dsolve({Eq1,bcs});
Error, (in dsolve) found differentiated functions with same name but depending on different arguments in the given DE system: [{psi(h1), psi(h2), psi(y)}, {psi(h2), psi(y)}]
Any suggestion?
Cheers!
Dear all;
Please see only the last lines of this procedure,
1)I ask if this procedure give an output epsilon(x0,h). Really, I need your help. Thanks.
2) Can we plot epsilon(x0,h), versus h
> heun := proc (x0, h)
local x, y, i, N, k, f, ode, k1, k2, x1, x2, y1, y2;
f :=(x,y)-> 1/(1+cos(y)) ;
ode := diff(y(x), x) = f(x, y);
N := round((1/2)*x0/h);
y2 := Array(0 .. N);
x2 := Array(0 .. N);
y1 := Array(0 .. 2*N);
x1 := Array(0 .. 2*N);
x2[0] := 0; y2[0] := (1/4)*Pi;
for i from 0 to N-1 do
x1[2*i+2] := (2*i+2)*h;  k1[1] := f(x1[2*i], y1[2*i]);
k1[2] := f(x1[2*i]+h, y1[2*i]+h*k1[1]);
y1[2*i+2] := y1[2*i]+(1/2)*h*(k1[1]+k1[2]);
x2[i+1] := (2*i+2)*h;
k2[1] := f(x2[i], y2[i]);
k2[2] := f(x2[i]+2*h, y2[i]+2*h*k2[1]);
y2[i+1] := y2[i]+h*(k2[1]+k2[2])
return firstresulat = evalf([seq([x2[i], y2[i]], i = 0 .. N)]);
return secondresulat =evalf([seq([x1[2*i], y1[2*i]], i = 0 .. N)]);
epsilon:=(x0,h)->add((firsttest[i][2]-secondtest[i][2])^2 , i=1..round(x0/(2*h))+1)
Please, I need you help, to make a simple procedure with two output.  I try this simple code :
test:= proc(a,b)
local variable .....;
for i from 1 to 10 do
expression
end do
retur  fff;
return ggg;
end proc
Then I do  : test(a,b) but I get only ggg and not fff
Any help please
how maple calculate exp(x) with e.g. 100000 decimal numbers
a divsion of the series x^k/k! with e.g. 1/25000!/25001 lasts longer than the exp(1.xx) calculation
is there a faster way to calculate exp(x) than with the x^k/k! series
I've been poking around with convolutions on Maple, and some weird behavior came up---if I let it compute the convolution of a piecewise function, then take the convolution of that, it comes out differently than if I enter a function from scratch as the middle step---file attached (PiecewiseProblem.mw).  I'm not really a Maple pro, so am I'm doing something crazy here?
hello,
so i've been having trouble with this one for a while. I think i'm just missing something simple.. maybe yous could help.
all we have to do is to write a maple procedure that takes an integer N and a boolean function F as in14 as arguments, returns nothing, and plots a square N N lattice of points, coloring the points (i; j) with F(i; j) true in red and the other ones blue.
thaaaanks.
why mapleprimes.com does not send me email notifications ?! could anyone help ? i do not receive email notification of related posts.
Thank you for your Help.
h: stepsize;
x in [0,x0];
I give all the step of my code, but I think there is a mistake. I wait for your Help.
I would like to compute the error between  Method Huen with step size h and step size 2h using the definition of epsilon given below:
 ## The error written epsilon(x0,h)= sqrt(1/(N+1) * sum_i=0^N  (y_i^{2h}-y_(2i)^h)^2 ), where y_i^(2h) is the approximation of y(i*2*h).
 ## We want : loglog epsilon versus h.
  epsilon:=(x0,h)->sqrt( 1/(N+1)*add( (Heun1(f,x0,i)-Heun2(f,x0,i))^2,i=0..N ) );
  f:=(x,y)=1/(1+cos(y));
  ode:=diff(y(x),x)=f(x,y);
ic:=y(0)=1;  h:=x0/(2*N);
## Method Heun with step size 2h
> Heun1 := proc (f, x0,)
local x, y, i, h, k;
y := Array(0 .. N);
x := Array(0 .. N);
h := evalf((1/2)*x0/N);
x[0] := 0;
y[0] := 1;
for i from 0 to N do
x[i+1] := (2*i+2)*h;
k[1] := f(x[i], y[i]);
k[2] := f(x[i]+h, y[i]+h*k[1]);
y[i+1] := y[i]+h*((1/2)*k[1]+(1/2)*k[2]);
[seq([x[i], y[i]], i = 0 .. N)];
### Now Heun with step size h  ( the same h)
> Heun2 := proc (f, x0,)
y := Array(0 .. N);
x := Array(0 .. N);
x[0] := 0;
y[0] := 1;
x[i+1] := (i+1)*h;
[seq([x[2*i], y[2*i]], i = 0 .. N)];
Thanks you for your help.
Is MapleSim 6.1 fully Modelica 3.1 compliant? If not, which features does it miss for the moment?
Lookup tables? (modelica ones, not maplesim's)
Thank you very much
> with(DETools);
> eq1 := diff(y(t), t) = v(t);
d
--- y(t) = v(t)
dt
> eq2 := diff(v(t), t) = -3*v(t)+10*y(t);
d
--- v(t) = -3 v(t) + 10 y(t)
dt
> phaseportrait([eq1, eq2], [y, v], t = 0 .. 10, [[y(0) = 0, v(0) = 1]], y = -10 .. 10, v = -10 .. 10, linecolor = blue);
why my phase portrait not working
I want to display the value of k   for which the stop test is verified. Thanks for your help.
epsilon:=(y0,N)->evalf(abs(
 testerror:=array(1..75);
for k from 2 by 2 to 50 do
testerror[k]:=data[RK3][k][2];
if testerror[k]<=0.0001 then break; end if; end do;
First 1452 1453 1454 1455 1456 1457 1458 Last Page 1454 of 2429
