I'm trying to create a small app for Maple Player to graph solids of revolution. When I run the app in the desktop version of Maple T.A it works, but when I move it into the Maple Player App it crashes. Any ideas?
Let OA=OB=OC=R=3,AB=3√2 and BC=2√2 .Find AC?
I am interested in implementing this worksheet: http://www.yorku.ca/marko/ComPhys/NoncomProduct/NoncomProduct.html
and variations on it, in maple.  However, it seems very clumsy.  acer of stackoverflow (http://stackoverflow.com/questions/21051935/taylor-expansion-of-an-operator-product) recomended I ask my question here.
would this worksheet be super easy to implement in maple 17 (don`t know what the difference between maple 17 and mapleprimes is..)?
hi, I am new here I want to solve these toe coupled equations with the following boundary condition numerically:
  1)  diff(f(eta),eta$3)+(1)/(2)*f(eta)*diff(f(eta),eta$2)-Pi*(2*f(eta)*(diff(f(eta),eta))*
(diff(f(eta),eta,eta))+f(eta)^2*(diff(f(eta),eta,eta,eta))+eta*(diff(f(eta),eta))^2*(diff(f(eta),eta$2)))-K*
(diff(f(eta),eta)-1)=0
2)   diff(theta(eta),eta,eta)+(1)/(2)*Pr*f(eta)*(diff(theta(eta),eta))=0
boundary conditions: 1)  f(0) = 0   2)  D(f)(0) = 0   3)  D(f)(infinity=10) = 1
                               1) theta(infinity=10) = 1      2) theta(0)=0
Pi=0.1    K=0.2
Hi. I need to calculate the elements of the large two-dimensional symmetric matrix.
for j from 1 to N do
for i from j to N do
    a[i,j]:=elem(i,j):
The calculations of elements are time consuming. I want to use Threads for this purpose. Could you help me with it? Thank you.
Does anybody know why the answer of a equation i am getting on maple is coming with "eval" written?
Example:
the answer should be a number ...
Why does it happen?
solve the system of equations (10a+3b+4c+d+e=0,11b+2c+2d+3e+f=0,15c+4d+5e+4f+g=0,2a+b-3c+12d-3e+f+g=0,6a-5b+3c-d+17e+f=0,3a+2b-3c+4d+e-16f+2g=0,4a-6b+c+d+3e+19g=0)
I would like to express 2*sin(x+Pi/4) in the form sqrt(2)*sin(x)+sqrt(2)*cos(x). I've tried many variations using simplify/expand/combine/etc. to no avail. Any ideas?
-.733448502640020+0.*I
i am investigating above numeric
when ln(-.733448502640020+0.*I);
-.3099978916+3.141592654*I
it has Pi imaginary part
then
i try
complex(1, exp(Pi)^3);
it return Complex(...) but not 1 + i*exp(Pi)^3
3 means 3 times come from recursively  using pattern ln(Re(ln(x) - 3.141592654*I))
3.141592654 in imaginary part appear 3 times
i use Round(Im(x), 8) during above operation
 actually i want to extract Pi imaginary part from -.733448502640020+0.*I
however, after minus exp(Pi) from it first time,
it is near the original number  -.733448502640020
is this elimination of imaginary part is just a illusion from log function?
I have the  following simple code in Maple:
x:=2*y
save x, "file1.mpl";
This code works successfully in Maple 13 and 14. However, does not work in Maple 17.  I do not understand why this happens. Can anyone help me to save a procedure in Maple 17.
HI,
I need to solve the following integration in terms of z. But Maple is not giving me any exiplict expression in terms of z. Please help me out for the same. Thanx in advance.
f := BesselJ(1, t)*(z*BesselJ(0, t)*BesselJ(1, z)-t*BesselJ(0, z)*BesselJ(1, t))/((1+10*t)*(z^2-t^2))
int(f, t = 0 .. infinity)
int(BesselJ(1, t)*(z*BesselJ(0, t)*BesselJ(1, z)-t*BesselJ(0, z)*BesselJ(1, t))/((1+10*t)*(z^2-t^2)), t = 0 .. infinity)
Download question.mw
Sunit
Dear Experts,
When I run this code in maple I am facing with "Error, (in dsolve/numeric/bvp) initial Newton iteration is not converging".
 unprotect('gamma');
 lambda:=5*10^5:
 mu:=0.003:
 beta:=4*10^(-10):
 delta:=0.2:
 alpha:=0.043:
 sigma:=alpha+delta:
 k:=6.24:
 gamma:=0.65:
 A[1]:=1:
 A[2]:=1:
ics := x[1](0)=1.7*10^8, x[2](0)=0,x[3](0)=400,psi[1](50)=0,psi[2](50)=0,psi[3](50)=0:
ode1:=diff(x[1](t), t)=lambda-mu*x[1](t)-(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[1](t)*x[3](t)+delta*x[2](t),
 diff(x[2](t), t) =(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[1](t)*x[3](t)-sigma*x[2](t),
 diff(x[3](t), t) =(1+psi[3](t)*k*x[2](t)/A[2])*k*x[2](t)-gamma*x[3](t),
 diff(psi[1](t), t) =-1+1/A[1]*beta^2*x[1](t)*x[3](t)^2*(psi[1](t)-psi[2](t))^2-psi[1](t)*(-mu+beta^2*x[3](t)^2*(psi[1](t)-psi[2](t))/A[1]*x[1](t)-(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[3](t))-psi[2](t)*(-beta^2*x[3](t)^2*(psi[1](t)-psi[2](t))/A[1]*x[1](t)+(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[3](t)),
> diff(psi[2](t), t) =1/A[2]*psi[3](t)^2*k^2*x[2](t)-psi[1](t)*delta+psi[2](t)*sigma-psi[3](t)*(psi[3](t)*k^2/A[2]*x[2](t)+(1+psi[3](t)*k*x[2](t)/A[2])*k),
> diff(psi[3](t), t) = 1/A[1]*beta^2*x[1](t)^2*x[3](t)*(psi[1](t)-psi[2](t))^2-psi[1](t)*(beta^2*x[1](t)^2*(psi[1](t)-psi[2](t))/A[1]*x[3](t)-(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[1](t))-psi[2](t)*(-beta^2*x[1](t)^2*(psi[1](t)-psi[2](t))/A[1]*x[3](t)+(1-beta*x[1](t)*x[3](t)*(psi[1](t)-psi[2](t))/A[1])*beta*x[1](t))+psi[3](t)*gamma;
sol:=dsolve([ode1,ics],numeric, method = bvp[midrich]);
Please help me to solve this equation on Maple.
I understand that the question is not really Maple related, but I still hope for some help.
See the worksheet below. I defined a pure sine wave and determined the complex Fourier coefficients for it which I used to plot the amplitude and power spectra. It is easy to see the relations in terms of amplitude and power between the time and frequency signal.
The Fourier Transform of the sine wave logically shows the Dirac distribution, but I can't see the relation in terms of amplitude and power to the original time signal. Taking the integral of the transformed signal (A) wil result in a step of Pi at w=-1 and again at w=1. What am I missing here?
restart; with(inttrans); with(plots); with(DynamicSystems)
Define a signal:
T := 2*Pi;
2*Pi
sin(t)
Determine the waveform power:
F := (int(f^2, t))/T+C:
C := simplify(solve(subs(t = 0, F) = 0, C)):
eval((int(f^2, t = -(1/2)*T .. (1/2)*T))/T)
1/2
plot([f, f^2, F], t = -Pi .. Pi, gridlines = true)
Determine the complex Fourier series coefficients and plot the spectra:
q := proc (n) options operator, arrow; (int(f*exp(-(2*I)*n*Pi*t/T), t = -(1/2)*T .. (1/2)*T))/T end proc:
simplify(q(n))
I*sin(Pi*n)/(Pi*(n^2-1))
ComplexCoefficients := evalf(`<,>`(seq(q(n), n = -1 .. 1)))
ComplexCoefficients := Vector(3, {(1) = .5000000000*I, (2) = 0., (3) = -.5000000000*I})
B := evalf(`<,>`(seq(sqrt(Re(q(n))^2+Im(q(n))^2), n = -3 .. 3))):
C := evalf(`<,>`(seq(Re(q(n))^2+Im(q(n))^2, n = -3 .. 3))); -1; DiscretePlot(C, -3, 1, titlefont = ["ARIAL", "bold", 14], title = "Power Spectrum", color = "Red", gridlines = true, style = stem)
So, the signal power for f of 1/2 can be found directly within the power spectrum plot "(2*1/(4))."
I would expect to be able to directly see the amplitude and power relation to the time signal from the Fourier Transform of f but i can't.
A := fourier(f, t, w);
I*Pi*(Dirac(w+1)-Dirac(w-1))
Download 20140127MaplePrime.mw
Jus started using Maple and I was wondering why maple doesn't execute the following function:
Thx,
Frank
I have to solve a system composed of a mass, a spring and a damper, represented by this equation :
m (d2x/dt2) + c (dx/dt) + k x(t) = F(t)
with m the mass, t the time, c the constant of the damper, k the constant of the spring, F an external force applied to the mass and x(t) the movement of the mass m at time t.
First 1472 1473 1474 1475 1476 1477 1478 Last Page 1474 of 2429
