As the title, how to convert "sin(x)+cos(x)" and this kinds into "sqrt(2)*sin(x+pi/4)"?
Sum of two sine functions with the same cycle should can be converted into one sine function, with some amplitude gain and phase offset.
While solving cubic formula, i got this warning in Maple.
Why D variable is protected?
eq1 := A*x^3+B*x^2+C*x+D = 0
A := x^2:
B := 2*x*y-4*z^2:
C := -2*x*y*z+x^2-y*z:
D := 4*x^2-x*z
Error, attempting to assign to `D` which is protected.  Try declaring `local D`; see ?protect for details.
eq1
x^5+(2*x*y-4*z^2)*x^2+(-2*x*y*z+x^2-y*z)*x+D = 0
How can I join the points on this graph to look like the second graph below.
I'm trying to model a simple pendulum. I have arrived at this code which gives me an animation of a point swinging.
To analyse the pendulum I want to plot a graph of phi against time, but do not know how to take readings from my animation to plot a graph with.
I designed the animation and wanted to display it automatically in the embedded component. Instead of animation toolbar, is it possible to control animation through commands? How do I do that?
Hello guys, I want maple to show me the time taken to execute the entire 500 loops shown in the code below. I read maple help and was able to come up with the code  (just part of the whole code).
st := time[real]():
for k from 1 to 500 do
  sol := LinearSolve(A, eval(b, [y[0]=y_init,z[0]=z_init])):
  y_init:=sol[9]:
  z_init:=sol[10]:
time[real]() - st;
my problem is that the time that shows varies/differs if i run it several times. I was expecting the same time interval of calculation. Am I doing something wrong?
how to solve this case which like sylvester
NullSpace(A*X+X*A) = B
find X?
 any things like
A*X + X*A = NullSpace^-1(B)
if i assume Matrix([[x1,x2,x3],[x4,x5,x6],[x7,x8,x9]]);
find NullSpace(Matrix([[x1,x2,x3],[x4,x5,x6],[x7,x8,x9]]))
then from the equation of it, put all equations = 0, and then solve them
and then substitue value of B into the result, can it be said NullSpace^-1(B)?
Can we define/set a range in Maple. e.g
I have the following equation:
y = 1.048 + 1.02*x + 6.118*(z-4.041*x^2) + 16.22*(z^2) +6.241* (x*z)
The value of z is within 0.001 - 0.543, y is from 1 - 12 and x is from 0.001 - 0.7
How should I define it in Maple, so while solving equations it read the values within the given range?
x := (1+v/2*cos(u/2))*cos(u);
y := (1+v/2*cos(u/2))*sin(u);
z := v/2*sin(u/2);
I converted this comment into a question since it was unrelated to the question in which it was put.
That way also other MaplePrimes users can have a shot at this new question.
Preben Alsholm
Dear Preben Alsholm
Hi;
Hope you to be healthy and have nice times,
I have another problem and if it doesn't consuming your valuable times, please guide me.
I have some Basis function,say W1(t),W2(t),W3(t),W4(t) which are orthonormal and i want to write a program that can approximate the integral of W(t)=[W1(t),W2(t),W3(t),W4(t)] again by Wi's, in other word
int(W(t')dt',t'=0..t)≈PW(t), where P is knows as integral operational matrix. the following is my attempt and unfortunately has no real solution!!!!
>              # Definition of 3th B-Spline
> piecewise(x>=0 and x<=1,1,0):
> h[1]:=unapply(%,x):
> h[2]:=simplify(int(h[1](x-t),t=0..1)):
> hh:=unapply(%,x):
>              #Definition of 3th B-Spline
int(hh(x-t),t=0..1):
> simplify(%):
> N:=unapply(%,x):
> J:=1:     # Number of base function is 2^J+2
> phi:=linalg[matrix](2^J+2,1):
> for i from -2 to 2^J-1
> do
> N(2^J*x-i)*h[1](x): #for deleting out side of[0,1]
> simplify(%):
> phi[i+3,1]:=unapply(%,x):
> od:
> w[1]:=phi[1,1](x):
> w[1]/sqrt(int(w[1]^2,x=0..1)):
> W[1]:=unapply(%,x):
> for i from 2 to 2^J+2
> do
> kk:=0:
> for j1 from 1 to i-1
> do
> aa[j1]:=int(phi[i,1](x)*w[j1],x=0..1):
> bb[j1]:=int(w[j1]^2,x=0..1):
> kk:=kk+aa[j1]/bb[j1]*w[j1]:
> od:
> w[i]:=simplify(phi[i,1](x)-kk):
> w[i]/sqrt(int(w[i]^2,x=0..1)):
> W[i]:=unapply(%,x):                 #Orthonormality process
> for j from 1 to 2^J+2 do
> for io from 1 to 2^J+2 do
> f[j]:=int(W[j](s),s=0..x);
> c[io][j]:=int(f[j](x)*W[io](x),x=0..1);
> od;
> od;
Best Wishes
I am new to Maple and I have difficulties simplifying expressions like the following: (exp(a+b)+exp(a+c))*exp(-a).
I would expect to see exp(b)+exp(c) but nothing happens when I use the simplify() function.
I googled but didn't find a solution.
Hi everyone,
At some point in my calculations, I want to do some simple manipulations wiht the use of the «clickable» features in M17.  For the moment, I can see directy how to do it by hand and I do it by copy-paste and use the mous to change it a little bit.  But I just cannot find a simple way to do it by simple click.
You will find in this attach question, the maipulations I want to do.  It is starting from equaiton (7).  Am I at the edge where it is simple by hand than with the features?
 Space_manipulation.mw
Thank you in advance.
Mario Lemelin
Maple 17.02 Ubuntu 13.10 - 64 bits
Maple 17 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
I was wondering how (or what is the best way) to write a worksheet in which a change of formula is used when a certain value on the y-axis is reached.
So for example: if there is a mass-spring system with damping in it, I would like to change the value of the damping when the displacement/velocity/acceleration has reached a certain value.
So when I apply a force to the mass-spring system, and the acceleration for example is LOWER than 0.2 m/s^2 I use a value of X % damping, but when the value of the acceleration is HIGER than 0.2 m/s^2 I want to apply Y % damping. So in time the curve will increase (when low damping is used) and the curve will decrease (because high damping is used, because the y-value is higher than 0.2 m/s^2), and so on...
I hope somebody has a 'simple' idea. I know what I want to do, but I don't know how to put this down in a formula which I can write in Maple.
Greetings,
Frank
Hi, i need help. I'm currently working with Taylor and Maclaurin series in Maple. I can easily compute the sum by typing in fx :
taylor( (ex,x=0, 5) , and then I get the first 5 numbers of the series. But I would like Maple to write the series as a sum from n =0 to infinity fx.  I can't figure out how to do it. Can it be done?
Thanks for helping.
First 1476 1477 1478 1479 1480 1481 1482 Last Page 1478 of 2429
