How to open batch maple output as mws in Maple Player?  I was used to doing this daily at work before retirement in my university office on a campus computer.  There was an "open" command in a file menu of some sort that I could click on, I seem to remember.   Am just fresh afte downloading Maple Player on my iMac and have it installed.  The file from my batch Maple output is form a run of batch Maple on the office machine that I can logon to remotely from home, as I did in this case.  I get rough looking graphic output (using the alphabet style graphics methods).  It would be good to have a more detailed and fine grained graphics to answer some basic questions that I am analyzing.  Thanks . . !!
hello,
I am trying to fit my data (in the form of two vectors "temp" and "resistance") on  resitivity as a function of the temperature "T" using a Dabye model.
The fit, intended to give as a result the two parameters "alpha" and "theta", doesn' seem to give any results.
Here my sample code:
>with(plots):
with(Statistics):
>rho[0]=1.33;
>T[0]=6;
> NonLinearFit(rho[0]+alpha*(T-T[0])*((T-T[0])/theta)^5*(int(x^5/(exp(x)-1)(1-exp(-x)), x = 0 .. theta/(T-T[0]))),temp, resistance, T,output=[parametervalues, residuals],parameterranges=[alpha=0.001..0.01, theta=10..100],initialvalues=[alpha=0.0027,theta=50]);
I am looking forward for your suggestions.
Hello, everyone. I have some problem with multithreaded calculation. I just need calculate eigenvalues of matrix m at various parameters (and then export to a file) using advantages of the parallelizing. The following code works but in serial way
restart: with(LinearAlgebra):
m:=ImportMatrix(cat(currentdir(),"m.txt")): # here is matrix m.txt
step:=1:
prc:=proc(k1,k2)
local u,i,j,nmc:
u:=Matrix(ceil(1+(k2-k1)/step),5):
u[1,1]:=k1:
for i from 2 to op([1,1],u) do
u[i,1]:=u[i-1,1]+step:
for i from 1 to op([1,1],u) do
nmc:=sort(Eigenvalues(m*u[i,1], output='list')):
for j from 2 to op([1,2],u) do
u[i,j]:=nmc[j-1]:
writedata[APPEND](cat(currentdir(),"u_",convert(k2,string),".txt"), [convert(Re(u[i]),list)]):
print(u[i,1]);
return finished:
with(Threads[Task]):
Start(ArrayTools[Concatenate], 2, Task=[prc,1,20], Task=[prc,20+step,40]);
quit:
The Start(ArrayTools[Concatenate], 2, Task=[prc,1,20], Task=[prc,20+step,40]) function makes two tasks of calculation at the parameter ranges of 1-20 and 21-40. But in this case Start spends twice more time than simply prc(20+step,40). How to realize a multithreaded calculation?
By the way I don't need to use a Concatenate function in Start but without any procedure Start doesn't work.
The following code
A := Matrix(2,(i,j) -> a||i||j):
A + 1;
A + a;
produces the following output:
Why does Maple accept these additions, which mathematically are nonsensical? And why, if accepting these mathematically, does Maple not evaluate them analogously by putting the scalars either inside or outside the matrix in both cases?
Hello;
        i am wording on fluid dynamics, in which i can up a system of nonlinear partial differential equation with i am suppose to solve using implicit keller box method. i need an asistance on how to implement this in maple.
error module is maple.dll_unloaded
i have already called stopmaple(kv);
in
testfunction(string hello){....stopmaple(kv));
testfunction(1);
testfunction(2);
when call testfunction again , it got error
Maple people:
The title is the question.  I would like to know if there is any Maple code available, either part of Maple itself or written by a user, to do computations with quaternions or dual quaternions.
I could Google this and probably find something, but I'll probably find a more helpful and less outdated answer here.
I am teaching a student about the subject and I'd like something to help me teach and help him learn.
I have a lot of experience with Maple but I am not a "computer person", so if the code involves fancy "libraries" or something beyond regular Maple worksheets, I may need a few tips how to use it.
GS
Hello everybody,
This one is an easy one but I cannot find the answers.  Suppose that I clik on the template for evaluating a function.  But mine have two (or more) variables (f=f(x,y)).  I have the x=a as one placeholder.  But I need to have an another inplut placeholder for y=b.  Can somenone tell me how to do it under Windows and under Linux.
Mario Lemelin
Maple 17 Ubuntu 13.10 - 64 bits
Maple 17 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
ifactor(op(1, convert(0.999987406876435, fraction)));
ifactor(op(2, convert(0.999987406876435, fraction)));
ifactor(op(1, convert(0.999919848203811, fraction)));
ifactor(op(2, convert(0.999919848203811, fraction)));
x1:=2;
x2:=3;
x3:=7;
x4:=17;
x5:=173;
x6:=709;
x7:=5347;
x8:=18713;
i think that there is a need to distinct all factor into a list of x1,x2,x3.... depending on all factors in these two decimal
0.999987406876435 = x4*x2^3*x5/(x3*x1^4*x6)
0.999919848203811 = x1*x8/(x3*x7);
then replace factors with x1,x2,x3....
with(Groebner):
T := lexdeg([x1,x2,x3],[e1,e2,e3]);
GB := Basis([e1+.999987406876435, e2-.999919848203811],T):
Error, (in LinearAlgebra:-Basis) invalid input: LinearAlgebra:-Basis expects its 1st argument, V, to be of type {Vector, {set(Vector), list(Vector)}} but received [e1+HFloat(0.9999874068764352), e2-HFloat(0.9999198482038109)]
with(Groebner):
T := lexdeg([x1,x2,x3,x4,x5,x6,x7,x8],[e1,e2]);
GB := Basis([e1-x4*x2^3*x5/(x3*x1^4*x6), e2-x1*x8/(x3*x7)],T):
Error, (in LinearAlgebra:-Basis) invalid input: LinearAlgebra:-Basis expects its 1st argument, V, to be of type {Vector, {set(Vector), list(Vector)}} but received [e1-x4*x2^3*x5/(x3*x1^4*x6), e2-x1*x8/(x3*x7)]
 u_{tt} = c^2 u_{xx}, \,
 u(t,0)=0, \quad u(t,L)=0,
as well as the initial conditions
 u(0,x)=f(x), \quad u_t(0,x)=g(x).
Trace  on computing the distinct-degree decomposition of the squarefree polynomial
f=x^17+2x^15+4x^13+x^12+2x^11+2x^10+3x^9+4x^4+3x^3+2x^2+4x belong to F_5[x].tell from the output only how many irreducible factors of degree i the polynomial f has, for all i.
Mapleprimes_Integral.mw
I have a question regarding following problem:
assume(a > 0, a < 1, t > 0, Z0 > 0, z > 0)
f1 := proc (z) options operator, arrow; 1/z end proc
I_1 := int(f1(z)*ln((a*z+1)/(1+z/a)), z = 0 .. Z0); 1; MultiSeries:-asympt(%, Z0, 3)
2*ln(Z0)*ln(a)+(a^2-1)/(a*Z0)-(1/4)*(a^4-1)/(a^2*Z0^2)+O(1/Z0^3)
Using the representation which should hold for all a>0 and z>0
int(z*exp(t)*(a^2-1)/((exp(t)+a*z)*(exp(t)*a+z)), t = 0 .. infinity); 1; combine(%)
ln((a*z+1)*a/(z+a))
I'm calculating the result the other way around
int(z*exp(t)*(a^2-1)*f1(z)/((exp(t)+a*z)*(exp(t)*a+z)), z = 0 .. Z0); 1; I_2 := int(%, t = 0 .. infinity); 1; MultiSeries:-asympt(%, Z0, 3)
plot(eval([I_1, I_2], a = 1/2), Z0 = 0 .. 10)
So the results are the same.
But if I calculate this with another function
f2 := proc (z) options operator, arrow; 1/(z*(z+a)) end proc
I_3 := int(f2(z)*ln((a*z+1)/(1+z/a)), z = 0 .. Z0); 1; MultiSeries:-asympt(%, Z0, 3)
-dilog(a^2)/a-2*ln(a)/Z0+(1/2)*(2*ln(a)*a^2+a^2-1)/(a*Z0^2)+O(1/Z0^3)
int(z*exp(t)*(a^2-1)*f2(z)/((exp(t)+z*a)*(exp(t)*a+z)), z = 0 .. Z0); 1; I_4 := IntegrationTools:-Change(int(%, t = 0 .. infinity), t = ln(z)); 1; MultiSeries:-asympt(%, Z0, 3); 1; simplify(convert(convert(MultiSeries:-series(I_4, Z0, 1), polynom), polynom))
ln(a)*(ln(Z0)+ln(a))/a
I get another result :-/ The Integral doesn't even vanish in the limit Z0 -> 0
Though if I take the limit prior:
int(z*exp(t)*(a^2-1)*f2(z)/((exp(t)+z*a)*(exp(t)*a+z)), z = 0 .. infinity);
-dilog(a^2)/a
the result is correct. What is the problem here?
Download Mapleprimes_Integral.mw
I want to find real roots only.  Cannot we find a simplified formula for x in this case which gives only real roots?
eq1 := a^2*x^3+Typesetting:-delayDotProduct(2*a*b-Typesetting:-delayDotProduct(a^2, e), x^2)+(-2*a*b*c^2-a*c+b^2)*x-c*b-d-b^2*e = 0:
# Formula
eq2 := A*x^3+B*x^2+C*x+E = 0:
a := .7438:
b := 15.12*z[1]+10.85*z[1]^2:
c := 18.92-17.76*z[2]:
d := -.9224:
e := 2.106-5.317*z[2]+2.87*z[2]^2:NULL
A := a^2:
B := -a^2*e+2*a*b:
C := -2*a*b*e^2-a*c+b^2:
E := -b^2*e-b*c-d:
eq2
.55323844*x^3+(-1.165120155+2.941568785*z[2]-1.587794323*z[2]^2+22.492512*z[1]+16.140460*z[1]^2)*x^2+(-1.4876*(15.12*z[1]+10.85*z[1]^2)*(2.106-5.317*z[2]+2.87*z[2]^2)^2-14.072696+13.209888*z[2]+(15.12*z[1]+10.85*z[1]^2)^2)*x-(15.12*z[1]+10.85*z[1]^2)^2*(2.106-5.317*z[2]+2.87*z[2]^2)-(15.12*z[1]+10.85*z[1]^2)*(18.92-17.76*z[2])+.9224 = 0
``# Putting z1 and z2 value
.55323844*x^3+14.11629660*x^2+83.26002702*x-3.52866181 = 0
[[x = 0.4208050385e-1], [x = -9.354079555], [x = -16.20375615]]
Download cubic.mw
Gentlemen
I know the following:{A>E,F>Z,F<P,Z>E,P<A} , all real Numbers
can I get maple to sort these in order largest to smallest.
[in this case:  A>P>F>Z>E ]
First 1475 1476 1477 1478 1479 1480 1481 Last Page 1477 of 2429
