I have 2nd order nonlinear ode I try to solve with Runge Kutta 4th order method in maple but all I get from the out is 1 and 0.This is the equation: theta_ode.mw . How do I do it Or how do I write the code to solve it with maple using  Runge Kutta 4th order method?
Maple can plot a function that is a convolution of Dirac delta-function and some regular function.
with(plots); a := 1.0
f := proc (x) options operator, arrow; exp(-abs(x)) end proc
G := proc (x, xi, t) options operator, arrow; `if`(t = 0, Dirac(x-xi), (1/2)*exp(-(1/4)*(x-xi)^2/(a^2*t))/sqrt(Pi*a^2*t)) end proc
u := proc (t, x) options operator, arrow; int(G(x, xi, t)*f(xi), xi = -infinity .. infinity) end proc; plot(u(0., x), x = -3*Pi .. 3*Pi)
1.0
Hovewer, it is unable animate this function (the first frame is empty).
n := 10:
Is it a bug? Is there a nice workarround of this bug?
Download Heat_Equation2.mw
How do you find the perimeter of an ellipse using maple?
For eg, x^2/20+y^2/13=1
Need help with starting this question. Thanks!
If a sequence is defined by X0=0, X1=1, X2=2 and Xn=n(Xn-3+Xn-2+Xn-1), n>=3
How many digits will X2013 have?
I have no idea how to start to answer this question. Please help Thanks!
Let G(x) denote the no. of ways of representing n as the sum of two prime numbers.
For eg, G(10)=2: where 10=3+7=5+5
           G(20)=2: where 20=3+17=7+13
           G(30)=3: where 30=7+23=11+19=13+17
How do you find G(10 000 000)?
I assign a function like so: f:=x->0.2*x^2*(x-3)^3
Then using d/dx in the expression palette I differentiate: d/dx f(x)
Get the following: 0.6x^2 (x-3)^2 D(x^2)(x-3)
What is the "D" in the last expression? What hasn't the whole differentiation been completed?
I'm having problem dealing with this question on Maple and would appreciate any help possible.
If f(x) = x/2, if x is even
   f(x) = 3x-1, if x is odd
which sequence will 2013^1102 fall in
1->1->1...
5->7->5...
17->25->37->55->41->61->91->17...
x11 := Vector([0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]):
y11 := Vector([ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]):
z11 := Vector([ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]):
> seq({round(x11[k]), round(y11[k]), round(z11[k])}, k = 1 .. 27);
{-21322, 0, 1550}, {-330, 0, 232}, {0, 9, 1528}, {-283, -33, 0}, {-55, 0, 55},
{-99, 0, 1876}, {-676, -16, 0}, {0, 42, 6085}, {-12559, 0, 1146},
{-456, 0, 521412}, {0, 105, 1111}, {0, 4, 16}, {-109, 0, 12}, {-175, -8, 0},
{-522, 0, 34}, {0, 26, 2030}, {-8, 0, 1388}, {-1085, 0, 10},
{-1999, -44, 0}, {-204, 0, 30}, {-56, 0, 2582103}, {-218, 0, 58},
{-179, -6, 0}, {-8549, -42, 0}, {-49, 0}, {-1883, -73, 0}, {0, 112, 184}
https://drive.google.com/file/d/0B2D69u2pweEvS0RVTFZWTnVKWms/edit?usp=sharing
{-49, 0}
there is a missing comma in this, is it the built in robot in maple playing human or my window make a joke?
this bug make me get an misunderstanding from mathematica stackexchange
https://drive.google.com/file/d/0B2D69u2pweEvZXp5WndMN0x5VGs/edit?usp=sharing
i can not display web correctly, What's wrong with me?
How to copy decimal number into notepad without scientific notation
after apply formating and copy the result to notepad, it still have scientific notation e
for rounding
I am not that good at english, but i will try to tell you what my problem is.
I have a worksheet in maple where i can't find out to make the results appear.
Maybe it is easiere for you guys to help me if i can send you the document.
Looking forward to hear form you
Niclas
Hi there!
I want to have a procedure, which takes as one of it's arguments an algebraic, say sin(x) for instance. So far thats easy, I just type:
proc(arg)
Within this proc I would like to define a function now, which has this expression on it's image side. So it should look like f:=x->sin(x). What I tried is:
minexample := proc(arg)
  local f:
  f := x -> arg:
  f(pi)
minexample(sin(x));
But this code would produce sin(x), as a result and not 0, as I would expect. Could anyone tell me what I do wrong, and how I can get it right please? : )
What I would also like to know is, what kind of data type expressions such as sin(x), or algebraic expressions are, so I can specify that in the definition already to make the proc more transparent to use.
Please write a Maple procedure called Position which retures the position i of an element x in a list L
That is, Position should return an integer i>0 such that L[i]=x. If x is not in list L,0 is returned..
i found command i may need to use
proc(), do end do ,member(e, a,'p'), if then elif, end proc,
can anyone help with this?  it may be a too elementary question to ask here .....and i know
 beginner
I tried to get the maximum and minimum values of the following function. From the plot I get them but its not accurate. Please advise me to get them accurate.
F:=0.85:B:=0.5:
K:=N->(N*(1+F*N/(N^2+B^2-F*N)));
implicitplot(((N^2+B^2-F*N)*K=N*(N^2+B^2-F*N+F*N),K=0..10,N=0..10,view=[0..5,0..4],numpoints=90000,axes=boxed,thickness=2,color=black,font=[1,1,20],tickmarks=[3, 3],linestyle=1));
This is just a question on terminology. The name "combine" implies pulling terms together. Yet, when applied to something like sin(x)^2 it has the effect of expanding it:
r:=sin(x)^2;
combine(r);
Which seems counter-intutive to me. I tried first expand(r) but that did not expand it.
Fyi, in Mathematica the function to do the above is called
Sin[x]^2;
TrigReduce[%]
    1/2 (1 - Cos[2 x])
As Mathematica does not have a Combine[] function.
So, I am just wondering about the naming, that is all. I would never have thought first that a command called combine() will expand sin(x)^2.
How can i sort like below? i want to sort x dependent y is fixed
Original case          sorted case
x   y                         x(i)   y[]
2   1                         1      4
3   2                         2      1
5   3                         3      2
1   4                         4      5
4   5                         5      3
First 1506 1507 1508 1509 1510 1511 1512 Last Page 1508 of 2429
