i want to plot the region D={(x,y)|0<=x<=1,0<=y<=1-x} in a 2d plot. how to i do this in the most possible way?
i know im supposed to use with(plots) and then implicitplot() but i cant seem to get it right...
any help is appreciated :)
diff(sin(x)^2,x$n); # Maple fails
# then I tried:
combine(sin(x)^2);diff(%,x$n);
# this works, but Maple should drop the pochhammer term (derivation of a constant)
What is the reasoning behind the output?
Hello everyone, I am trying to solve  a differential equation with one extra boundary condition.
restart:with(plots):
Eq:= diff(f(y),y$3)+f(y)*diff(f(y),y$2)-diff(f(y),y$1)^2-(diff(f(y),y$1)+y/2*diff(f(y),y$2))=0;
bc:=D(f)(0)=1,f(0)=0,(D@@2)(f)(b)=0, f(b)=b/2;
With the arbitrary trial values, the integrated solutions will generally not satisfy the outer boundary conditions.
(D@@2)(f)(b)=0, f(b)=b/2.
I need find a way to adjust the two trial values such that the numerical solution eventually matched
the required boundary conditions.
Good afternoon sir.
I request your kind suggestion to the above cited question.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
Hello, Suppose I have two sinusoids with the same amplitude and frequency. By changing the phase of one of them it is possible to 'align' them. When the phases are exactly the same the difference between the two sinusoids becomes zero. Now lets define a variable (U[int]) that gives a measure of the difference between the two sinusoids and change the phase phi to generate an animation and 3D plot and see if it is possible to mathematically determine that the difference becomes zero when the phases of the waveforms are equal. Chosing a time t>0 and solving for the derivative does the job.
My question is, can (and how can) Maple determine for which phase phi we have the minimum function without chosing a time t.
u[G] := sin(omega*t)
u[L] := sin(omega*t+phi)
U[int] := int((u[G]-u[L])^2, t)+C
C := solve(subs(t = 0, U[int]) = 0, C)
omega := 9:
animate(plot, [[u[G], u[L], (1/10)*U[int]], t = 0 .. 2, legend = ["Public grid voltage", "Local grid voltage (control goal)", "Cum. Actuator voltage (scaled)"]], phi = -Pi .. Pi, gridlines = true, labels = ["Time [s]","Voltage [V]"], labeldirections = ["horizontal", "vertical"], labelfont = ["ARIAL", "bold", 12])
plot3d(U[int], t = 0 .. 2, phi = -Pi .. Pi, shading = zhue, orientation = [-150, 70, 15])
t := 1:
phi = fsolve(diff(U[int], phi))
Download 20131114_Finding_min.mw
Thanks a lot!
Hi there,
i want to generate some plots in files in this example:
this code doesn't work. but without restart; it works fine. i passed 2 days to figure out that "restart;" was the problem.
my questions are :
1. why i have to eliminate the first line of restart;
2. how can i save my files in a directory that is in the current directory. For example i have a directory in current directory named "plotFILES".
thanks in advance for your help
I have a Matrix whose entries are polynomials in several formal parameters (the matrix is sparse and the polynomials are rather simple, though inverses of the parameters may also arise).
Then, when I compute the kernel with LinearAlgebra-NullSpace, maple naturally gives a basis of solutions over the same ring of polynomials.
Now for some reason there are some parameters that I don't want to see in the solutions (all but two of them, actually).
How can I compute the part of the kernel that lives in $\mathbb{Z}[a,a^{-1}, b,b^{-1}]$, i.e. that involves only the first two parameters?
Thank you,
NoThik
Edit : the coefficients of the polynomials are integers, and I expect the kernel elements to have integer coefficients as well.
Find the Fourier Series for the function f(x) defined as follows, and compare the graphs of some truncated Fourier series (try 1,2,3,5,6,30, terms) with the graph of f(x).
f(x)= min(|x|, pi/2), -pi less than or equal to x less than or equal to pi.
Also, let f(x) be periodic with a period of 2*pi. Thanks.
Hey, I have some data points:
I than entered:
X := Data[() .. (), 1];
Y := Data[() .. (), 2];
f := a+b*x^c+d*x^e;
Statistics:-NonlinearFit(f, X, Y, x);
 and when I entered Statistics:-NonlinearFit(f, X, Y, x);, It wouldn't output anything.
I am using maple 17 and I was trying to run a nested loop as shown below. I expected to get all combinations of i and j (9 components). But i and j always remain 3. What is the problem here? Can anyone suggest alternate solutions? I dont understand in which order maple increments i,j or k in each loop.
for k to 9 do
      for i to 3 do
          for j to 3 do
          a[k] := i, j
          end do
      end do
table([1=(3,3),2=(3,3),3=(3,3),4=(3,3),5=(3,3),6=(3,3),7=(3,3),9=(3,3),9=(3,3)
I would like to make the operator L (factorization)
in the form
Thank you for your answer.
Greetings,
I have a differential equation:
an the solution:
I want to substitute
ekf := omega = sqrt(c/m);
algsubs(ekf, sol);
but sol does not change.
This works a bit but does not substitute everything in a way that you would expedect
This is the result:
I want to find the sum of the reciprocals of the factorials of the elements of in the sets [[0,2,3,0,0], [2,3,0,0,0], [1,1,2,2,0] .....]]  -----(1)
For example 1/(0!2!3!0!0!) + 1/(2!3!0!0!)+ 1/(1!1!2!2!0!)+........;----(2)
The lists are the partion(5) made into a list of 5 elements with 0s filling the partitions with less than 5 elemenst such as (2,2,1)=>(2,2,1,0,0)
All I need is help on how to make from (1) the sum (2) which is the sum of the reciprocals of the products of the factorials of each set.
I would like to choose the maximum interval which is here B3 not the maximum value.I used max which gave me the maximum value. Any ideas?
This is the output:
B1:=[2., 36.718220544331125]
B2:=[2., 35.08378362904457]
B3:=[2., 51.78712780854305]
datamax:= 51.78712780854305
how to get datamax:= [2., 51.78712780854305] instead of datamax:= 51.78712780854305?
This is my Maple code:
> restart;
> n := 3;
> for i to n do A[i] := RandomTools:-Generate(distribution(Uniform(.5, .75))) end do;
> eq := diff(X(t), t) = -S*X(t);
> ic[1] := X(0) = 150;
> for i to n do s[i] := dsolve({ic[1], subs(S = A[i], eq)}, X(t), range = 0 .. 10, numeric) end do;
> for i to n do B[i] := eval([t, X(t)], s[i](2)) end do;
datamax := max([seq(B[i], i = 1 .. n)]);
Greetings to all.
Just a quick question, probably something obvious, please bear with me Your patience is appreciated.
As part of solving a posted problem at math.SE it became necessary for me to compute the bivariate generating function
sum(sum(binomial(2*q,n-1)*z^q/q!, q=0..infinity)*w^n,n=1..infinity)
The correct answer (in fact a simple computation) is
w exp(z(w+1)^2).
When asked to compute this sum with the command shown, Maple produces
hypergeom([], [], z) w
My question for you is, how does this represent the above answer that I computed manually? When I simplify the hypergeometric, Maple says
w exp(z)
which would appear to be the wrong value. Could someone enlighten me regarding this discrepancy?
BTW there seems to be no tag "hypergeometric" and I don't have enough points to create it.
Best regards, Marko Riedel
First 1507 1508 1509 1510 1511 1512 1513 Last Page 1509 of 2429
