Hello, i am working on creating a smooth curve from my data points: [0.2e-1, .158], [0.2e-1, .159], [0.3e-1, .161], [0.3e-1, .164], [0.3e-1, .166], [0.4e-1, .169], [0.6e-1, .173], [0.8e-1, .178], [.1, .185], [.11, .187], [.14, .193], [.19, .2], [.28, .21], [.38, .223], [.44, .233], [.58, .244], [.82, .256], [1.4, .278], [1.71, .281], [1.78, .282], [1.78, .282], [1.81, .282]
however, I am not sure how to to create the smooth curve formula for said data points. I tried using polycurve, but it didn't spit out any equations.
If f(n)=a^n+b^n+c^n   and f(1)=1,f(2)=2,f(3)=3 ,n=1,2,3,.... Find f(5) ?
As of today it does no longer properly load using Firefox, but using IE works
Hi! I am a newbie in Maple. For several days trying to read help but no luck. Search here for "solve tensor equation" does not help either.
There are tensor package and physics package but in both helps i have not found how to solve simple tensor equation AijmnBmnkl=Cijkl. Let's say A and C i create as analytical arrays and then create tensors on the base of them (not Arrays - for some reason the tensor cannot be created on the base of Arrow...
I would like to plot z(x(t)) with the odeplot function.
For the moment, i manage to plot x(t) and z(t).
But i don't manage to plot z(x(t)) ?
My last code lign is wrong.
Can you help me for this plotting ?
Thanks a lot
Here my code :
M:=1;
1l:=1;
g:=9.81;
sys:=diff(z(t),t,t)=-1/z(t)*diff(x(t),t)^2-1/z(t)*diff(z(t),t)^2-x(t)/z(t)*diff(x(t),t,t),M*(-l^2/(x(t)*z(t)))*diff(x(t),t,t)=M*g-M*(-1/z(t)*diff(x(t),t)^2-1/z(t)*diff(z(t),t)^2);
Cinit:=D(x)(0)=0,x(0)=0.99999999,D(z)(0)=0,z(0)=sqrt(l^2-0.99999999^2); D(x)(0) = 0, x(0) = 0.99999999, D(z)(0) = 0, z(0) = 0.0001414213562
sol:=dsolve({sys,Cinit},numeric);
tx:=odeplot(sol,[t,x(t)],0..10,numpoints=200,color=blue,legend="x"):display(tx);
 tz:=odeplot(sol,[t,z(t)],0..10,numpoints=200,color=blue,legend="z"):display(tz);
txz:=odeplot(sol,[x(t),z(x(t))],0..10,numpoints=200,color=blue,legend="z"):display(tz);(x)
Good afternoon sir,
I request you to support me with regard to the above cited subject.
I would like to solve the a sytem of 5 differential equations for a combution process and i dont know how to do.
my enties are as follows
PDEtools[declare](prime = t);
derivatives with respect to t of functions of one variable will
   now be displayed with '
MW = 29;
Hello, I have a quadratic eigenvalue problem. I used to solve it using "polyeig" function in matlab. May I know if there is such a function in maple too? I cant seem to find it.Thanks.
@Carl Love
This is the integral
I do it by hand the result is Pi, but I do it with maple VectorCalculus it is zero,
how to do it fairly? please demonstrate.thanks!
Is there a way to remove the small dashed box that shows up while one is typing in document mode?
Also, is there a way to remove italic style from everything? I do not like italic at all. I tried many things, such as
Format > Styles. Select the 2D Input character style and click modify
but when I start new line, it goes back to italic.
I can also open the style sheet file (my_styles.mw) that I use, and look at the XML there. What do I need to change...
Hi folks, I'm running Maple 17.02 and getting very different behaviors from subs and isolate. My actual expressions are way more complicated but this simple example illustrates the problem:
restart; with(PDEtools); F := diff_table(f(x, y, w, z, a, b));
subs(F[x] = Z(x, y, w, z, a, b), F[x]+F[x, b]-10);
subs(F[x] = Z(x, y, w, z, a, b), F[x]+F[x, y]-10);
The last line gives me what I want  Z+Z[y]-10 but the second line gives me Z+F[x,b]-10....
I keep getting this error and have no idea how to fix it.
Error, (in Elements:-Maplet) `Elements:-ElementTable[typ]` does not evaluate to a module
This is my code for the section with the error. Any help would be greatly appreciated.
FindParamTan:=Maplet(onstartup = RunWindow(MAIN),
Window[MAIN](title="Computing Vertical and Horizontal Tangents to Parametric Curves",
[ [ halign=none,
    Button("New Curve", Evaluate(function = "ask"), background=magenta),
An elementary example of successful using Threads:
First 1520 1521 1522 1523 1524 1525 1526 Last Page 1522 of 2429
