ASK.zip
In short, I want to use
'ss' expression(1)
to simplify
'kappa' expression (2).
At the moment, I can only archieve it through solving for each variable and get to expression (5).
simplify using siderules failes in this case. Is there another way to do it?
Casper
Hi folks, the package PDEtools has a nice command declare that allow us to display PDEs using jet notation: say f[x]-g[y] instead of diff(f(x,y),x)-diff(g(x,y),y) but when I try to export it to LaTeX or just trying to copy and paste the display in a text file, I always get the long expression. If I try to copy as MathML I got junk... Any ideas on how to copy an expression displayed in jet notation to a text document?
Hello, I would like to use the LeastSquares subpackage in the LinearAlgebra package in order to solve the following problem:
Set of data: (1.0,2.33),(2.0,0.0626),(3.0,-2.16),(4.0,-2.45),(5.0,-0.357),(6.0,2.21),(7.0,2.75),(8.0,0.636),(9.0,-2.45).
I am trying to put the above data in the curve y=a+b*cos(x)+c*sin(x)+d*cos(2x)+e*sin(2x).
My attempt to solve this:
with(LinearAlgebra);
Find the eigenvalues and eigenvecotrs for A=[2 0.37 0]
        [0  1.1 -4.29]
Find the quadratic polynomial which interpolates (2,0), (6,1), (8,0). Start by setting f(x)=ax^2+bx+c, for example, and the unknowns as a,b,c.
I have the following system of equations to solve which is quite big.. Does anyone know how I can solve it faster or in a more simple way?
solve({(-(1/((0.002+0.001)^2+(0.001+1*(e+p))*(0.001+1*(j+p))))*((0.002+0.001)*sin(-0.39)-(0.001+1*(e+p))*cos(-0.39)*(e*(-m+(0.68/d)+(0.599/g))+j*m)-(1/((0.002+0.001)^2+(0.001+1*(e+p))*(0.001+1*(j+p))))*((0.001+1*(j+p))*sin(-0.39)-(0.002+0.001)*cos(-0.39))*(j*(-n+(0/i)+(-0.73/l))+e*n...
eqt := y^5+y^4 + -0.5109*y^3 + -0.0595*y^2 + 0.0000-(-3.1086e-015*u^4 + u^3 + -0.5109*u^2 + -0.0595*u) = 0;
solve({eqt, y=m*t+c, u=n*t+d}, {y, u}, 'parametric');
solve({y^5+y^4 + -0.5109*y^3 + -0.0595*y^2 + 0.0000-(-3.1086e-015*u^4 + u^3 + -0.5109*u^2 + -0.0595*u) = 0, u=t}, [x,y]);
solve(eqt, [y(t), u(t)])
algcurves[parametrization](eqt, y, u, t);
all trials i failed
Hi. I have a question it goes.
Find the equation f(x) which satisfies the following conditions. f'(x)= 1/(1+cot(x)) and f(pi/4)=1.
So I enter the following in Maple and this is what I end up with.
http://s5.postimg.org/eriq99rs7/Maple.jpg
This should work as far as I can tell. The final diff command should return the original f'(x), but it doesn't. Can anyone tell me why?
I have used this exact method before on similair problems and it...
I have a linear problem A*X = B, with dimensions of A approximately 500*1300, and B is a vector with only one nonzero coordinate.
I feed it to LinearSolve, and there are a *lot* of solutions - presented as one vector with linear polynomial coordinates.
How can I get only one (hopefully with as many zeros as possible) ?
Thank you in advance.
NoThik
Does anyone know why I cannot solve the following system of equations?
solve({(-(0.1e-2+e+p)*j*(e*(-m+.68/d+.599/g)+j*m)/(((0.2e-2+0.1e-2)^2+(0.1e-2+e+p)*(0.1e-2+j+p))*i)+(0.2e-2+0.1e-2)*j*(j*(-n+0*(1/i)-.73/l)+e*n)/(((0.2e-2+0.1e-2)^2+(0.1e-2+e+p)*(0.1e-2+j+p))*i)-j*m/i)/(2*10) = -0.3e-2, (-(0.1e-2+e+p)*j*(e*(-m+.68/d+.599/g)+j*m)/(((0.2e-2+0.1e-2)^2+(0.1e-2+e+p)*(0.1e-2+j+p))*l)+(0.2e-2+0.1e-2)*j*(j*(-n+0*(1/i...
HI,
I have a system of ODEs like
Good morning sir,
In  general, there are five ways to decide the nature of a given square matrix based on the signs of the eigenvalues, for example
  1. If the eigenvalues are positive then the nature is positive definite.
  2. If the eigenvalues are negative then the nature is negative definite.
  3. If the eigen values are nonnegative then the nature is Positive semidefinite.
  4. If the eigenvalues are nonpositive then the nature is negative semi definite.
  5. If the eigenvalues are positive and negative then the nature is indefinite.
triangle(T, [[x1,y1], [x2,y2], [x3,y3]]);
area:=proc(1/2*[x1(y2-y3)+x2(y3-y1)+x3(y1-y2)]);
AA:=(T)->[area(T)];
Struggling to get my head round how to plot the results of the follwoing, as it seems I have 4 variables...
I have a data file containing the results of the following problem:
1) Consider a cube. Each side (a,b,c) has a length of 1 unit.
2) Place an ion (0,0,0) where [a,b and c intersect] and find the associated energy at that point.
3) Move the ion to a point 0.05 units along side a to (0.05,0,0) and re-find the associated energy.
I want to solve the inequality sqrt(8*16^x - 1/2* 9^x) <= 3*4^x - 3^x
I tried
solve(sqrt(8*16^x - 1/2* 9^x) <= 3*4^x - 3^x,x);
And I got
Error, (in evala/inv/heuristic) cannot allocate memory (size=117506048).
How to solve the above inequality?
First 1522 1523 1524 1525 1526 1527 1528 Last Page 1524 of 2429
