I am a new maple user and I am having a problem with this question:
here is my maple procedure. I have to make the iteration works until I have met the initial condition it will stop. the initial conditions here is z:=ic.
This is my approach:
sum(1/(4*n+1/3*k),k=1..infinity)
but I end up getting infinity for my answer which is obviously wrong.
I am using Maple 13, I am working on Optimtimization package (worksheet mode) in command-line
LPSolve(-x-y, {y <= -5*x+2, y <= 3*x+1/2}, assume = nonnegative)
I have equations in microsoft word file and I have to copy the...
I am a student taking differential equations and I need to implement Euler's method using Maple 17. I have set up a do loop that looks like this:
for i from 1 to n1 do
k:= f(t,v):
v:= v + h*k:
t := t + h:
Where n1 is initialized to 50, f(t,v) := 0.0207v2 -893.58, and h is 0.1. v and t are both initialized as 0.
Hi ,,,,  I think it is a bug in Maple   "try to calculate int(abs(x-2),x);   ... does not give a right answer
Question 1
a := miu1 = Diff(lambda1(t),t) + lambda3(t);
b := miu2 = Diff(lambda2(t),t) + lambda1(t) - 4*lambda3(t);
c := miu3 = Diff(lambda3(t),t) + lambda2(t) - 3*lambda3(t);
d := miu = 2*Diff(lambda3(t),t$2) - 5*Diff(lambda3(t),t) + 7*lambda3(t);
how to eliminate all derivatives of lambda in miu
result in
miu - 2*Diff(miu3,t) - miu3 + 2*miu2 = 2*lambda1 - lambda2 + 2*lambda3;
I have now been stck in a few days on a task that should be done in maple. I'm pretty new to maple so hope some of you could help me a bit. The task is to create a table of a ball that is thrown, when the starting speed should be from 0.2 to 4, and each step should be at 0.2. Afther that the table need to be plotted. I have used euler method to sett the functions up and the functions is a vector. Any one know what comands i should be using?
I have here Maple proc, but it doesn't work. I am try to solve this equation
pde := diff(u(t, x), t, t)-(diff(u(t, x), x, x))+x^2*u(t, x);
with 3 piont known , we have
stencil:=u(i,j)=-u(i-1,j-1)+(1-h^2/8*v(h/2*(j-i-1))^2)*u(i,j-1)+(1-h^2/8*v(h/2*(j-i+1))^2)*u(i-1,j);
please see the file I attached here
wave_proc.mw
I am try to program a proc that will plot the kinematic equations.
kinematics := proc(a::procedure, t::name, s0::numeric, v0::numeric, t0::numeric, t1:: numeric)
local v:=t->v0+int(a(t),t);
local s:=t->s0+int(v(t),t);
plot([a(t),v(t),s(t)], t=t0..t1);
the above is my code, which works ok.
Note: a is acceleration function, v is velocity function, s is position function, t is independent variable,...
(i)develop an algorithm for computing f¡ÊF[x,y],F a field,where the degree of f in y is less than n and and f(x,ui)=vi; for i=0,1......,n-1, for distinct ui∈F,and arbitrary Vi∈F[x].showthat f is unique.
(ii) assuming that the degree of each Vi is less than m, what is the computing time of your algorithm (in term of m and n)?
(iii) computer f∈ F[11][x,y]such thatf(x,0)=x^2+7,f(x,1)=x^3+2*x+3,f(x,2)=x^3+5.
sys := [1.8*a+.4000000000*b+103.9*c-.5000000000*e-102.6*g = 0, .5000000000*b+102.6*c+.3*d+.3500000000*e-102.1*g = 0, -3.3*a-1.050000000*b+102.4*c+.7*d+.2500000000*e-105.1*g = 0, -2.5*a+1.450000000*b+102.6*c+3.3*d+1.050000000*e-102.4*g = 0, -1.6*a+1.100000000*b+105.8*c+.3*d+1.750000000*e-105.5*g = 0, -.7*a-.2500000000*b+105.1*c-.2*d+.2000000000*e-105.7*g = 0, -.3*a-.3500000000*b+102.1*c+2.5*d-1.450000000*e-102.6*g = 0, .2*a-.2000000000*b+105.7*c+1.6*d-1.100000000*e-105.8*g = 0...
hello. how can I translate a graph in the x axis 3 times and then again in the y axis 2 times?
Find a(n)of sequence1,8,1,4,7,0,7,0,....   (n=1,2,3,4,...) ,
First 1526 1527 1528 1529 1530 1531 1532 Last Page 1528 of 2429
