Hi there,
i would like to know, how can i change the x-axis labels of an graph?
Currently i read data from text file in format like this:
0 10
1 11
2 14
3 15
This values i plot in a graph with this commands:
averagedValues := readdata("mytextfile.txt", [integer, float]);
plot({averagedValues}, x = 0 .. averagedRowCount)
My problem is, that each x value has a date label....
I think the answer to my question is not there yet.
So I would like to save some variables in a .m file in an another folder without using the whole C:/.../ thing.
The reason why is that I am using a windows and a mac so if work on my mac I can still execute my reading and my writting commands on my mac.
the file I want to write from is located in :
/Maple_projet/Code/Timoshenko/
and the folder I want to write to is in
I'm using maple 16 to do a surface plot w/ plot3d of a fairly complex integral. The integral involves a number of nested functions. The plot ends up taking a very long time. The surface appears to have many holes in it. In fact, only about half of the surface is plotted, and the rest looks like empty space. I know that the integral/function is defined at these empty points, because I can evaluate it there and get a real number. What can I do to fix this? I've tried different...
My problem is that I have two functions in two variables, say x and y. The functions are both polynomials in x, but sometimes y appears in an exponent. What I want to do is find the gcd of these functions as if they are viewed as polynomials in x. However, when I use the gcd command it says it can not do it because the arguments must be polynomials. I have tried redefining the functions as just functions in x (i.e. h(x) = f(x,y)), but it still does not work. So is there anyway...
hey friends please help me out of this error hmm_working.mw
I'm trying to develop a new notation and am having problems with lists vs. sets.
Basically I have things of the form [[a,b]],[[c,d,e]],[[f],[f,h]] and I want to change them to the form [{a,b}],[{c,d,e}],[{f},{f,h}].
I start from a flat list [a,b,c,d,e,f,f,h] and then divide it up, so using sets initially would lose repeated elements. But then once it has been divided up, I need the innermost brackets to be sets.
I recently purchased a new MacBook Pro (retina) with Mountain Lion and found that my Maple 12 programs would not run.  So I updated to Maple 16.  Initially all seemed to work well.  But now when i try to open a Maple .mw file, I get the message
"File acm23test.mw could not be found.  Please select a different file."
What has happened and how can I get my programs working again?
DavidR
Hello guys , i have a matrix that i want to find its eigenvalues , i have its answer but maple calculations didnt give its anwer.
answer:3(1+q),{-3m+sqrt(m*(256m^3+160m^2-31m-16)}/4m(m+1),{-3m-sqrt(m*(256m^3+160m^2-31m-16)}/43(m+1)
m and q can bu any number
maple calculation :
eigen.mw
thank you guys
Ok, so here's my first question on Mapleprimes.
I have the following procedure:
BlocksLSymm:=proc(stringLength)
local i, j, V;
global vars_set;
V:=Vector(2^(stringLength)+1,symbol=x):
# Create List
vars_set:={};
x[1]:=x[2];
for i from 0 to stringLength do
 for j from 0 to i do
  vars_set:={op(vars_set), x[2^i-2^j+1]};
BlocksLSymm(5);
vars_set;
Is it possible when solving a differential equation to get the corresponding recurrence relation of the series expansion instead of the actual solution?
e.g.
ode:=y''=omega^2*y(x)
the solution is obviously exp(\pm omega*x)
But I want
a_(n+2) = omega^2/(n+1)(n+2) * a_n
or something like that
1. nonlinear ODE with parameter "epsilon"
(x^n +epsilon*y(x))dy/dx + n*x^(n-1) * y(x) =m*x^(m-1) ; y(1)=b>1
where n=2,3,4,.. and m=0,1,2,3,...
2. Duffing equation with parameter "epsilon"
d^2 y(x)/dx^2 + y(x) + epsilon*y(x)^3=0 ; y(0)=A ; y'(0)=0
I want to make my maple.ini file so that it sets plotoptions(discont=true) as starndard, so that I don't have to write it all the time.
I did it a couple of years ago, but can't make it work now.
Hope some of you can help me.
Michael
I don't think the geom3d package can be used symbolically it needs specific values.  Maybe I'm wrong, am I?
I'm plotting this function of (x) which is very complicated expression anyway I plotted it..Now I want to plot the f(x)/max value of f(x)???
I appriciated for any advice...
First 1562 1563 1564 1565 1566 1567 1568 Last Page 1564 of 2430
