Hi, im new with maple
so I am still a bit confused with how to use it..
i have an nonlinear ODE with parameter "b"
(x+b*y(x))dy/dx + y(x) =0 ; y(1)=1
if i want b=0.1 and x=0, 0.1, 0.2, ..,1
how do i
I want to find all values of m such that the equation (x-m)*(x-2*m-1)*(x+3*m-2)*(x+m+3)=0 has two positive solutions and two negative solutions. How to solve this problem with Maple?
so I have the following function to be plotted:
M = (1+y^2)/((x^2+1)*(1+z^2))
Anyone have any background knowledge on the above 3D polynomial?  Assuming all 4 parameters are real I ploteed some 3D plots & some interesting surfaces are generated.  I imagine this has some physical application.  If anyone has some knowledge on this please respond & include any references you might know of.
I tried using maple to solve the below system of Partial differential equations but itzz not jst coming out... any assistance will be appreciated (post the maple codes if used)
sys2 := -(diff(u(y, t), y, y)) + S*(diff(u(y, t), y)) + diff(u(y, t), t) + M.u(y,t) + (u(y,t)/k)-theta(y,t) = 0,
 -(diff(theta(y, t), y, y))/Pr + diff(theta(y, t), t) + S*(diff(theta(y, t), y)) = 0
The variables are... u(y,t) and theta(y,t)
The initial conditions are;
I am having some trouble with a recursive formula which I instead turned into a loop to avoid any errors. I defined an array before starting the loop and defined the last index as a floating number (this will be the initial point used in the loop). Within the loop, I first defined my recursive formula (which contains other arrays that are indexed; everything is switched to floating points) and it equates without trouble. Underneath this (still within the loop...
Bonjour,
Comment calculer avec Maple une intégrale première de omega:=(x^2-y*(x+y^2))*dx+x*(x+y^2)*dy.
Merci d'avance,
Gérard.
     I have a set of first order, linear ODE's in matrix form, I was able to solve them with matrixDE for 4 equations (which were uncoupled), but I would like to up this to around 132+ equations if possible. When I tried 9 equations I got
 Error, (in collect/series) integer too large in context
on my laptop and on my other computer it was very slow and I didn't wait for a solution.
Should I try a numerical solution ...
> with(PDEtools):
> declare(y(x), prime=x):
> ode := diff(diff(y(x),x),x)*diff(y(x),x)*y(x)*f(x)-2*diff(y(x),x)^3*x^6> + 2*diff(y(x),x)^2*y(x)*diff(g(x),x) + y(x)^5;
 diff(ode,diff(y(x),x));
Error, invalid input: diff received diff(y(x),x), which is not valid for its 2nd argument
 i want to make deravatition with respect to the first deravatives,what should i do?
Say I wanted to print out all values from 1 to 8 but excluding 3, how would I do that using a for loop?
For example, this just stops after 2:
for i to 8 while i <> 3 do
print(i);
end do ;
whereas I want it to skip 3 so going 1,2,4,5,6,7,8.
For what I'm actually doing, I need i to run over a range but excluding one value.
I am not sure if this is a general problem.  And I am considering the best way to evaluate the expression (Equation) when it contains variables which have been modified by using assume.   Here is a tiny test example:
assume(a>0,x>0);
int(int(x^2/y^2,y=1/x..x),x=1..a);S:=%:
                        1  4   1   1  2
I've made multiple graphs, and plotted them with the command 'display'. I also put a legend to every plot I made.
But now the legend which is showed by using 'display' is given randomly. So I put in different heights from say 200 mm to 1000 mm, with 100 mm spaces in between. The legend gives me randomly all the heights: like 200, 400, 100, 300, 700...etc. Is there a way to organise or order the legend? So that I can say I want the legend to start at 200 mm and end it at 1000 mm. So a kind of an ascending height legend. That is way more pleasant to the reader, obviously.
Greetings.
Frank
I have the following code which solves a system od ode (3 ode) with constraint parameter. actually, this algorithm is time consuming and is not effective as I see that some people solve this odes with matlab in an efficient (qucik) way. So, I ask you if it is possible help me to improve the efficiency of the following code
eq1 := diff(u(eta), eta, eta)+diff(u(eta), eta)/ (eta+zet)+Gr*Pr*T(eta)-Nr*phi(eta)+sigma1;
eq2 := diff(T(eta), eta, eta)+diff(T(eta), eta)/(eta+zet)+Nb*diff(T(eta), eta)*diff(phi(eta), eta)+Nt*diff(T(eta), eta)^2-u(eta);
eq3 := diff(phi(eta), eta,eta)+diff(phi(eta), eta,eta)/(eta+zet)+ Nt/Nb*(diff(T(eta), eta, eta)+diff(T(eta), eta)/(eta+zet))-Le*u(eta);
zet:=0.1:
Nt:=0.05;
Nb:=0.05;
Le:=10;
Pr:=1;
Gr:=5;
Nr:=0.1;
Ree:=5;
#sigma:=2;
p:=proc(pp2) option remember; global res,F0,F1,F2;
if not type([pp2],list(numeric)) then return 'procname(_passed)' end if:
res := dsolve({subs(sigma1=pp2,eq1)=0,eq2=0,eq3=0,u(0)=0,u(1-zet)=0,phi(0)=0,phi(1-zet)=0,T(0)=0,T(1-zet)=0}, numeric,output=listprocedure);
F0,F1,F2:=op(subs(res,[u(eta),phi(eta),T(eta)]));
evalf((2/(1-zet^2))*Int(F0(eta)*(eta+zet),eta=0..1-zet))-Ree*Pr;
fsolve(p(pp2)=0,pp2=(-80)..(80));   # I dont know what exactly this parameter has
#res := dsolve({eq1=0,eq2=0,eq3=0,u(0)=0,u(1-zet)=0,phi(0)=0,phi(1-zet)=0,T(0)=0,T(1-zet)=0}, numeric);
sigma1:=%;
odeplot(res,[[eta,u(eta)],[eta,phi(eta)],[eta,T(eta)]],0..1-zet);
I'd like to change the font size in my MapleSim plots, especially when I resize the plot to take up the whole screen.  I know how to set the line thickness of the plot lines, but I can't seem to find an option for setting the font size in the legends, titles and axes.
Also, is there a way to change the default font and line width?
thanks!
James
Aslam-u-Alikum. How are you? I want to construct an operators to find the derivative and integration of fractional order please help me i am so tens.Jam.mw
First 1563 1564 1565 1566 1567 1568 1569 Last Page 1565 of 2430
