I'm not sure why I get an error in the following simple maple code:
test:=s->fsolve(t^3=s,t);     % Simplified implicit expression for illustration.
test(8);  % (this yields the answer 2 - good)
plot(test(s),s=0..8);
Error, (in fsolve) s is in the equation, and is not solved for
Why do I receive this error?
Same error occurs with:
fdiff(test(s),s=1);
I'm a casual user of Maple...
This is more of a tutorial rather than a question because I found some mistakes and because the maple help file was a bit poorly explained and I am posting some additional details.
I am running version 16 of maple and version 7.12 R2011a of matlab.
If some of you are wondering how to call a Matlab user function in Maple this is what I have done:
First of all in the maple...
Here's a Maple trivia question: There is a Maple symbol that cannot be used as a procedure parameter. As far as I can tell it is the only one. What is it?
I am currently running sucessfully Maple 15 on Macbookpro mid 2009 4G, CPU 2,53 Ghz Intel core duo, NVIDIA GeForce 9400M 256 Mo, OSX 10.8.4
I bought the upgrade to Maple 17, when launching the install package : I have a grey window with a "next" button with slow flashing : impossible to click on it ... so impossible to install the new version
thanks for your help !!
by the way Java installed
best regards
Gaetan
     Seems like a silly questionm but the Maple help page suggested usign the option 'interpolation=false' for a numeric dsolve since I ran out of memory (I'm solving a huge matrix DE). But that's not an option in the command dsolve, has this been removed as of Maple 16? Or any suggestions on using less memory? I have 16Gb RAM,
I seem to recall from my undergrad days that a cubic polynomial could be readily factored (even analytically) if you appy the assumption that you will have 1 REAL root & the other 2 are complex conjugate pairs.  I cannot seem to find my old lecture notes & see nothing on the web on this matter.
Anyone here have any knowledge on this subject?  I have played with MATLAB & altered the polynomial coefficients such that whenever complex roots do crop...
Does anyone know why png is not listed in the help on plot/devices?  The png device exists and works.
Also, are there any other unlisted plot devices?
When I export my plot to PDF, adobe acrobat says: A drawing error occurred. Other programs see my PDF as corrupt. I would use a .eps file, but my plot has a semi-transparent component that doesnt show up very well as an eps. Any ideas?
Hello, I'm a newbie in Maple. I just started learning maple and i'm using version 17. I want to know if there is a way in maple to get the coefficients of some variables maybe an example would explain me better. Lets say we have
23x^4 + (12*h)x^2
So my question is that is there a function/method that can allow me to strip the coefficients of x^4 and x^2. Because I have a very long expression and I need the coefficients of the variables therein to populate a matrix.
hey friends please check this code for me..working1.mw
Hi there,
Is there a semi-definite program package in Maple available? I knew there is a SDP in Matlab. Currently I am running part of my program in Matlab then manually export the data to Maple. Which is quite inefficient. I find some paper about that. But I dont know where to download the code. Thanks!
Fei
I have reason to believe that the expression below is a real number:
(1/6)*(-108+(12*I)*sqrt(1419))^(1/3)+10/(-108+(12*I)*sqrt(1419))^(1/3)+1;
A numerical approximation supports that. How can Maple help here to get a simplified expression?
Solving Helmholtz' equation by seperation of variables yields a solution of the form
(a*exp(I*k_x*x)+b*exp(-I*k_x*x))*(c*exp(I*k_y*y)+d*exp(-I*k_y*y))
if we consider a wave in the first quadrant that is moving away from the x axis then it has the form
c*(a*exp(I*k_x*x)+b*exp(-I*k_x*x))
is it possible to plot this wave in the first quadrant?
Also if I switch to polar coordinates (r,theta) can I produce similar plots of rays?
Good day,
I have plotted a family of lines in one graph, and now I want to shade an area between two horizontal (parallel) lines, for example 2 and 5.
So what I did was to use the command 'filled'. First I shaded the area in vertical direction from 0 to 2 white. After that I filled the area in vertical direction from 0 to 5 for example blue.
This results in a shaded area between 2 and 5 in the color blue, what I like to have.
Question: Is there a way (a command) to fill an area between two horizontal lines more easily? So that I shade it between 2 and 5 in just one commandline. Now I first make a part white, and then the next 'layer' behind is in the color I'd like to have.
Another thing is that when I shade an area in the color white, my gridlines disappear! Is there a way to avoid this?
I have found information about shading area between two intersecting lines (can be done relatively easy), but between two horizontal (parallel) lines I still can't find a simpler way to do it.
Somebody got a suggestion?
Greetings,
Frank
First 1561 1562 1563 1564 1565 1566 1567 Last Page 1563 of 2430
