hey friends I am attaching my worksheet. In it am working on wavelet method now problem is in the end of worksheet am having output of  four column vector matrixes and i want all these column vector matrixes in A matrix of order n x n but problem is am not getting my desire matirx form. I want all the entires from all the vector column matrix to be wriiten in the matrix A in column wise.
new.mw
I am trying to solve the coupled system of PDEs. Maple throws below error(highlighyted in bold letters) when I try to solve it using 'pdsolve'. Attached is the maple worksheet(BatteryPDEEquationsBackUp8thJuly13_constantCurrentInput.mw) having complete code. Please help.
> pds := pdsolve(BatSys, IBC, numeric, variables, time = t, range = 0 .. L[N]+L[sep]+L[P]);
Error, (in pdsolve/indexlex) invalid input: a string/name list is expected for sort method `string`...
-(1/2*I)*(I*Pi*ln(2)-I*Pi*ln(g+4)-2*ln(2)^2+2*ln(2)*ln(g+4)-2*ln(2)*ln(-1/2*I)+ln(g+4)*ln(-1/2*I)-ln(g+4)*ln(2*I)+ln(-1/2*I)*ln(4-g)+ln(4-g)*ln(2*I))/Pi
why doesnt maple simplify this expression any further?
I tried radnormal and simplify.
but he complains when using combine saying:
Error, (in combine/ln) second argument must be a maple type
Why is that?
Yesterday I’ve updated to the new Version 17.01 and now I’ve the problem that I cannot enter  ‚}‘ and another problem is an exponent e. g. x^2. To enter it I have to write x^22. The first number is not shown in the worksheet.
I hope someone can help me to solve this problem.
what is the normalization constant N for this wave function x range from  x=o and x=L ?
Eigenvectors(A, C) can be used to solve the eigenvalue problem:
A . x = lambda . C . x
if a new term " lambda^2 . D . x " is added to the right hand side, where D is a new matrix, is there a simple way to solve the new eigenvalue problem:
A . x = lambda . C . x + lambda^2 . D . x
Simple Maple procedure definition is like this:
f := proc (x, y) sin(x+y)-exp(x)*y end proc:
How can I use indexed parameter declarations, say:
f := proc (x[1], y[2]) sin(x[1]+y[2])-exp(x[1])*y[2] end proc:
where x and y are arrays of unknowns. It seems that this does not work in Maple 13.
Originally, I want to solve a set of n nonlinear equations with n unknowns W[n] using fsolve(), and the output is a set of equations, say:
I have some strange problems with the function "Equal" in LinearAlgebra, which should allow me to compare matrices.
First of all, this works without any problems:
> restart; with(LinearAlgebra);
> A := Matrix(2, 2, [[0, 0], [0, 0]]);
> Equal(A^2, A);
Maple correctly returns "true" since here A is equal to its square.
But:
> A := Matrix([[a, 0], [0, 0]]);
Good day,I was wondering what I do wrong when I use this procedure, which I want to plot.I just created a small procedure and don't know why the two methods are different.Maple_-_Proc_IF_THEN.mwThank you.Greetings, Frank
hi guys,i have a program when i run it after 3or4 minutes maple give this :
execution stopped:memory allocation failed.please see ?alloc for more detail.
when i ok it then give this :
the kernel has been shut down.further computations cannot be performed.
what do you think ?
thank you very much
Are you in or near Berkeley, California?
Are you experienced with Maplesoft for academics?
Can you train a student to use it with the tutorials and your own knowledge?
This student is located at University of California, Berkeley and needs an immediate hands on private trainer.
He will be taking Calculus 1A next semester and needs to learn to use this program this summer.
He is a student who uses an eye control computer without the use of his hands and needs this
I'm using Maple 14 and I'm trying to solve a system of recurrence relations with initial conditions (a Vector Autoregressive model). The system is
const:=Vector[column]([0.009421681, -0.0005441856]):
lagY:=Vector[column]([0.796519372, 0.0179147112]):
lagZ:=Vector[column]([0.133049059, 0.5240695764]):
A:=<<const>|<lagY>|<lagZ>>;
eq1:=y(t) = A[1, 1] + A[1, 2]*y(t - 1) + A[1, 3]*z(t - 1);
eq2:=z(t) = A[2, 1] + A[2, 2]*y(t - 1) + A[2, 3]*z(t - 1);
Hi all
I want to simulate the threshold effect in FM modulation\ demodulation, in theory ,when the carrier to noise ratio (the modulated signal SNR)fall below a certain value ,then the signal to noise ratio(of the demodulated signal will fall dramatically and the signal will not demodulated , click sounds will be heard in the output of demodulator. I have tried first "slope detector" as a demodulator, but the threshold effect didn't appear at all when i decrease...
i wrote the following code
zet:=0.5:
rhop:=3880;
rhobf:=998.2;
cp:=773;
cbf:=4182;
eq1 := diff(u(eta), eta, eta)+0.133762025280e-2/(0.993000000000e-3+0.388362300000e-1*phi(eta)+.530162700000*phi(eta)^2)+(1/(eta-1)+(0.388362300000e-1+1.06032540000*phi(eta))*(diff(phi(eta), eta))/(0.993000000000e-3+0.388362300000e-1*phi(eta)+.530162700000*phi(eta)^2))*(diff(u(eta), eta));
eq2 := diff(T(eta), eta, eta)+(.63267672*((2.66666666666*(-1.1752324*10^6*phi(eta)+4.1744724*10^6))*u(eta)/p2+7.04876575828*(diff(phi(eta), eta))-(1.58058605349*(.597+4.45959*phi(eta)))*(diff(T(eta), eta))/(1-eta)))/(.597+4.45959*phi(eta));
eq3 := diff(phi(eta), eta)-5.00000000000*phi(eta)*(diff(T(eta), eta));
p:=proc(pp2) if not type([pp2],list(numeric)) then return 'procname(_passed)' end if:
res := dsolve({eq1=0,subs(p2=pp2,eq2)=0,eq3=0,u(0)=0,u(1-zet)=0,phi(0)=0.008,T(0)=0,D(T)(0)=1}, numeric);
F0,F1,F2:=op(subs(res,[u(eta),phi(eta),T(eta)]));
res(parameters=[pp2]);
evalf(2/(1-zet^2)*Int((1-eta)*(F1(eta)*rhop+(1-F1(eta))*rhobf)*( F1(eta)*rhop*cp+(1-F1(eta))*rhobf*cbf )/(F1(eta)*rhop+(1-F1(eta))*rhobf)*F0(eta),eta=0..1-zet))-pp2
fsolve(p(pp2)=0,pp2=(20000)..(8000000));
it has an error and i cannot find that. would you please help me?
First 1567 1568 1569 1570 1571 1572 1573 Last Page 1569 of 2430
