solve_assume.mw
dear experts
the above solution violates my assumption phi should be between -1.57 and +1.57. why?
Hi Maple users and experts!
I have some systems of non linear equations. Maple's "solve" is often able to give explicit solutions. However, I'm actually not very interested in the solutions but rather in knowing whether or not a unique solution exists. Is there a way to determine this with maple?
- John
Hellow,
 any one know how to solve the second order differential equation using finite element method (Using Linear shape functions)
I'm dealing with an iterated function (logistic map) where f(x)=s*x*(1-x) where the s is a general parameter between 1 and 4 inclusive, and it's fourth return map, or f(f(f(f(x)))) or f^[4](x).
h:x->f(f(f(f(x))))
What I'm trying to do hinges on evaluating this:
solve(h(x)=x,x);
a
DoExist := proc(tau, n)
if rtable_num_elems(tau) >= n then
        return tau[n];
        return 0;
g1 := [0, y, x];
g2 := [0, y^2-x-y, 0];
g3 := [x, x+y, 0];
g4 := [y, -y, 0];
g5 := [0, x*y+x/2+y/2, 0];
g6 := [0, x^2-x/4-y/4, 0];
m1 := Basis(g1, tdeg...
> restart; with(plottools);
> U := u(x, t);
> pde := (diff(U, `$`(x, 2)))/(2*x)^2 = (1/1250)*(diff(U, `$`(x, 2)))+(1/9)*sin(0.10e-1*Pi*t)*exp(0.10e-1*Pi*t^2);
ic := u(x, 0) = x^2, (D[2](u))(x, 0) = 1;
bc := (D[1](u))(0, t) = 0, u(1, t) = 1;
> S := pdsolve(pde, {bc, ic}, numeric);
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 0, got 2
ode := diff(x(t), t, t) = 1^2*(cosh(x(t))-1)/cosh(x(t))
ics := x(0) = 2, (D(x))(0) = 0
xs := dsolve({ics, ode})
plot(xs, t = 0 .. 3)
why do i get this error?
Error, invalid input: plot expects its 1st argument, p, to be of type {set, array, list, rtable, algebraic, procedure, And(`module`, appliable)}, but received x(t) = RootOf(Int(1/(-4*arctan(exp(_a))+4*arctan(exp(2))-4+2*_a)^(1/2), _a = _Z .. 2)+t)
i want to solve these equations to find the 18 coefficents,how should i solve them to solve it in minimum time possible?
eq(1):= -2144447222.22*a(7)-1531751031.75*a(8)-1148816190.48*a(9)-584858207.070*a(12)-5003703703.71*a(18)-714823743.386*a(11)-893526455.026*a(10)-5361111111.11*a(17)-5744047619.05*a(16)-6433333333.35*a(13)-6433333333.34*a(14)-6126984126.99*a(15);
eq(2):=-1531747698.41*a(7)-1148812857.14*a(8)-4288888888.90*a(13)-4595238095.25*a(14)-4595238095.24*a(15...
I`m having trouble using dsolve in a loop in order to evaluate a differential equation for different constants/initial values. I`ve imported the data for the constants from excel using the import function and have defined them, and then created the differential equation which returned a DE with array parts. I created a sequence called sys_ode ad sys_init_val so that I could easily call the DE`s individually. I now wish to solve the DE at each of these points...
if you have four teams a b c and d playing in a tournament and teams a and d have not played each other but all other teams have played .. typing this from my phone but its not too friendly ...  soccer scores how would you determine who would win and by what score
How to implement this in maple, can be developed graphically?
I have a question concerning a 3d theory to calculate forces, stresses, deflections, etc. I am calculating a simply supported beam (a cylindrical pile). The theory is build up cylindrical coordinates; x and theta.
solving the theory gives me deflection in 3 directions; ur (radial), ux (length), utheta (along the surface). To plot a the deflection of the pile I convert all to cartesian coordinates:
> xcart := unapply(x+ux(x, theta), [x, theta])
I've just started learning Maple. I can't figure it out how to transform my problem into maple syntax.
My problem includes solving a simple algebraic equation, that is,
Y[k+1] = -10*Y[k]
I would like to solve this equation for different values of k, for example, k = 0,1,2,3.
and express my results in terms of Y[0], i.e,.
Y[1] = -10*Y[0];
Y[2] = -10*Y[1] = 100*Y[0]
Y[3] = -1000*Y[0]
I don't know...
hello support,brand new to maple. i am trying to plot the solution for the functions cosx=x. if i set these both like so: y = cosx and y=x.orf:=cos(x);f:=x;it will plot the cosine function.how do i plot these in maple 17, i tried using the graphing calculator also that comes with maple 17 but that for some reason will not allow me to type an equal sign , i looked over the web for a solution.so i pose the question why the graphing calculator will not accept the "=" sign???thanks,noobie craig
hi guys , i want to solve a system of equations but maple gives me "warning, solutions may have been lost" !
what can i do ?
z0.mw
First 1578 1579 1580 1581 1582 1583 1584 Last Page 1580 of 2430
