How to find the integral
1/(4*Pi)*int((cos(t)-sin(s)-cos(t)*sin(s))/(3+2*(cos(t) - sin(s) - cos(t)*sin(s)))^(3/2),[t=0..2*Pi,s=0..2*Pi])?
Its geometric interpretation suggests the answer is -1. Maple finds the inner integrals both over t and s, but Maple cannot directly find the iterated integrals.
I'm trying to solve a pretty complex system of equations (a 3rd order DAE with 61 equations) using the MEBDFI numeric solver but I'm always getting the following error.
error in dsolve/dae/numeric/sm_intersect. numeric exception, division by zero
I have tried to find out what the sm_interesect command is but I haven't had luck neither in Internet nor in Maple help. I have looked for similar posts...
https://skydrive.live.com/redir?resid=E0ED7271C68BE47C!358
1/x!*subs(z=0,Diff(g(z)^x, x$(x-1))) = n*x
1/x!*subs(z=0,Diff(g(z)^x, z$(x-1))) = n*x
how to solve for g(z) ?
as i do not know what do this respect to which variable from a book. so i capture this diagram.
hope that can solve it
L := Summation(Summation(g(m, n)-g(m-1, n)-g(m, n-1), m = 1 .. 3), n = 1 .. 3);
M1 := subs(m=1, g(m, n)-g(m-1, n)-g(m, n-1))=0;
rsolve(rhs(M1),g,'genfunc'(1,b));
Error, invalid input: rsolve uses a 2nd argument, Fcns, which is missing
Reference:
Matrix([[0, g(0,1), g(0,2)],[g(1,0), g(1,1), 0],[g(2,0), 0, g(2,2)]]);
I am looking for a package to calculate the power mean (or Hölder mean) defined like
Mean_p(x_n)=(1/N Sum(x_n^p,n=1..N))^(1/p)
in a hopefully obvious notation. I can obviously implement this definition directly in Maple, but there are subtleties (like the limit of p=0) which maybe a mature implementation already covers (?).
I am still mostly on Maple 15 which does not have such a Mean. If 16 or 17 have it I would not becessarily know.
Hey Forums!
Im using maple 16 for some rather simple Engineering calculatioins. One thing about using maple bothers me, and that is the way my result is displayed.
Here is an example
Here is another
Adding "simplify" or "evalf" sometimes does the trick, but id really like...
I have total nine equations,out of which some are linear and some of them are nonlinear.I am a new user of maple.The nine equations are
c2+vc = .34,
c2+c3 = .519,
t8+c3-c4-vc = .132,
t1+t5-c2+0.0435=0,
t1-t2-c2+c3-1.334*vc = 0,
t2+t6-c3-c4+0.0435+1.334*vc=0,
-112.5*t1+112.5*t5+300*c2^2+1000*vc = 38.25,
112.5*t1-112.5*t2-300*c2^2+300*c3-300*c3^2-2000*vc+23.4 = 0,
-112.8*t8+112.5*t2-112.5*t6+300*c4^2-300*c3+300*c3^2+1000*vc+14.85 = 0
This piece of code returns a vector 'Sinrdensity' with identity entries. what's wrong with it?
sinrvalue := [seq(10^((1/10)*i), i = -15 .. 25, .5)];
Sinrdensity := Matrix(1, nops(sinrvalue), 0);
task := proc (sinrdensity, initialpoint, endpoint)
local bft, Theta, bound, value;
for value from initialpoint to endpoint do
bft := unapply(1/(1+I*t), t);
for Theta from 0 to 10^10 while is(0.1e-1 <= evalf(abs(bft(2^Theta...
like f# do
match(tree)
with| verification('hyporesult'(alpha,beta), 'dedeuceto'('Conj'(alpha,beta),gamma) -> 'hyporesult'('Conj'(alpha,gamma),beta)
need to get hyporesult is prefix, and then use if the compare, and get first parameter and second parameter such as for 'Conj'(alpha, gamma)
i use typefunc('hyporesult'(alpha,beta)) can not get 'hyporesult'
moreover...
Who knows what Maple does wrong on this one?
T:=Sum(1/(6*k+1)!, k=0..infinity); evalf(T); value(T); evalf(%);
Sum(1/factorial(6*k+1), k = 0 .. infinity)
1.000198413
(1/6)*3^(1/2)*exp(-1/2)*sin((1/2)*3^(1/2))+(1/6)*3^(1/2)*exp(1/2)*sin((1/2)*3^(1/2))+(1/6)*exp(1/2)*cos((1/2)*3^(1/2))
.6739557747
Download sum.mw
Does any one know how to derive this model in Maple?
The_Price_is_Righ.pdf
I did two polar plots as you see and wanted to color the region between them.
> with(plots);
> a1 := polarplot(1, t = 0 .. 6*Pi*(1/3), thickness = 2, filled = true, color = black);
> a2 := polarplot(2*cos(t), t = 0 .. 6*Pi*(1/3), thickness = 2);
> a3 := polarplot(2*cos(t), t = -(1/3)*Pi .. (1/3)*Pi, filled = true, thickness = 2);
> display(a1, a2, a3);
The program makes the region colored red but there is an overlapping part which...
Can you help me how to program about the interference of wave on the water surface in Maple ?
I've bought NAG C Library for my mac in order to use it in Maple.
However, it seems that Maple doesn't know where to search for it.
Indeed, it returns
Error, (in NAG:-h03abc) external linking: error loading external library libnagc_nag.dylib: dlopen(libnagc_nag.dylib, 129): image not found
I've installed NAG C Library in usr/Library
Thank you very much for your help
If I have several sets of listed data of different lengths,
a1:=[1,2]
a2:=[5,3,4,5]
a3:=[4,8,4,5,3,2,3,4,5]
a4:=[2,2,5,4,7,8]
How do I join the 1st positions into one variable and the 2nd positions into another and so on?
First 1579 1580 1581 1582 1583 1584 1585 Last Page 1581 of 2430
