what should i do to write matirx of this form in maple  for nth order
[1        4        1                                    ]
[B-1,0   B0,0   B1,0                                   ]
DMS_13.mw
this code executes fine in  M13. but in M15 theres a problem. doesn't like the local.
i wish maple had a compatability/update feature like mathematica...
I recently have a problem when I try to use dsolve/numeric to solve an IVP. Suppose we have diff(y,x) = w(y) and y(0) =  y0. We can solve this IVP numerically by dsolve/numeric. In Matlab, we can obtain y and  the derivatives yp using the command [y,yp] = deval(sol,t) at any time t within the range we pre-defined. Basically, matlab ode solvers return a solution  skeleton first, then evaluate y and yp of the other points by a piecewise interpolation which is called...
with insequence=true command, first, the first option is showed, then second, then third and so on.. but i want to show all options from in grpah, then animate in sequence.
hi  projet_TW.mw
procedure_final_(1.mw
could someone help me.thanks
     I'm reading in a file as
eigvect:=ImportMatrix("C:\\Users\\Sorted_Eigenvectors_1.txt", source=csv):
but I want to generalize this to
eigvect:=ImportMatrix("C:\\Users\\Sorted_Eigenvectors_i.txt", source=csv):
where i is a positive integer, I tried
eigvect:=ImportMatrix("C:\\Users\\Sorted_Eigenvectors_%d.txt",i, source=csv):
but this is incorrect. What is the correct syntax?
So i got rhis
with(plots); low := 1015; high := 1019; j := 0; for i from low to high do proc (X) options operator, arrow; X(t) end proc; proc (Y) options operator, arrow; Y(t) end proc; ode := diff(X(t), t) = evalf(subs(x = X(t), y = Y(t), subs(vvx = VX[i], vvx))), diff(Y(t), t) = evalf(subs(x = X(t), y = Y(t), subs(vvy = VY[i], vvy))); ics := X(0) = Cordx[i+1], Y(0) = Cordy[i+1]; j := j+1; plott[j] := odeplot(ds, [X(t), Y(t)], t = 0 .. 100, numpoints = 1000) end do; display(plott, jj)
Hello, im a current user of Maple 16, i have a problem in finding a minimum of equation ( equation of a external work equating the internal energy dissipation) f= E-W ( im studying a slope stability with limit analysis)
the equation is:
I have a 3dplot of a certain procedure with the color specified by another procedure.
The standard color range, from red to purple, does not look very good in my application. Is there a way to change the color range to for instance: light green to dark red?
This is a very strange and specific issue I am having with any Windows x86 vm after having installed Maple 17.
Before installing Maple 17 (and also AFTER installing it, before the reboot), I can open a command window while logged in as the local administrator and successfully issue a command like:
sc config BDESVC start= disabled
After installing AND REBOOTING for Maple 17, if I log in as the local administrator, open...
hi friends i have done with my code but still getting error in summation term. Please help me out. ThanksFractional_(1).mw
Let A be a table. I give following sequence of commands:
>>B:=A;
>>A[x]=34:
Then surprisingly (at least for me) it turns that B has also changed its value for B[x]. Would someone help me understand this? What is it called? How we can stop this behaviour i.e. A and B should behave as independent tables?
regards
What are the main functions of the kernel Male and for which they are responsible?
I would like check with you about the real form of the functions following modified bessel functions.
BesselI(0,i*x) and BesselK(0,i*x), where i is the complex variable. IS there any real form to these functions in either BesselJ and BesselY.
I come across the BesselJ(0,i*x)  = BesselI(0,x). However, I was not able to find the converse relation.
I have not seen the complex arguments...
First 1577 1578 1579 1580 1581 1582 1583 Last Page 1579 of 2430
