Is there any way to fill in colour to a polar plot using Maple 16? What I want to do is essentially make a coloured in pie slice using a defined radius and theta range.
I am aware of the function filled, which adds colour starting from the x-axis but that is not appropriate in this situation. I know of the filledregions function but that only works for implicit and contourplot, and as of yet I have not been able to use implicit...
g1 := [0, y, x];g2 := [0, y^2-x-y, 0]; g3 := [x, x+y, 0]; g4 := [y, -y, 0]; g5 := [0, x*y+x/2+y/2, 0]; g6 := [0, x^2-x/4-y/4, 0];
g1 := 0; g2 := 0; g3 := x; g4 := y; g5 := 0; g6 := 0;
restart; with(Groebner):
IsNullZero := proc(tau) if assigned(tau) then return tau else return 0 end if end proc;
Which command is similar with IsNull function in VBA for assign 0 when detect not assigned
I want to find shortest time it takes particle to travel from point A(0,0) to B(1,1). I tried to solve this problem by using following code test.mw. I know that solution to this problem is cycloid and i already found its equations in parametric form.
My problem is that when i try to solve integral as a solution i receive Time := Float(infinity)*I.
Is there any way to get a numeric solution in Maple...
Are There  options to solve this problem?
I solved a PDE system and got module() export plot,plot3d,animate,value,settings; ... end module (Got ui(x,t) and ur(x,t))
And after it I try to solve the task
Xs := [0, .175, .789, 1.818, 3.287, 5.183];
n := 1;
interface(prettyprint = 1);
for t1 from 0 by 50 to 50 do
k1 := sol:-value(t1, output = listprocedure);
(b0*z^n+b1*z^(n-1) + ... + bn) / (a0*z^n+a1*z^(n-1)+... + a_n_minus_m*z^m)
expand
into
beta0 + beta1*(1/z) + ... + betam*(1/z^m) + beta_m_plus_1*r_m_plus_1(z)/a(z) + ... + betan*rn(z)/a(z)
maple 17 does not calculate the definite integral  (?):
f(x):=sin(sin(x)); int(f(x), x = 0 .. 1).
Trying evalf leads to the correct  numerical result.
> de := (1/4)*U*(diff(S(y)^4, `$`(y, 2))) = C*P1*((O*exp(G*y)-R*exp(J*y))/(P1*(exp(J*L)-exp(G*L)))+P2/P1);
/ 2 \
1 | 2 / d \ 3 / d / d \\| /
- U |12 S(y) |--- S(y)| + 4 S(y) |--- |--- S(y)||| = C P1 |
4 \ \ dy / \ dy \ dy /// \
O exp(G y) - R exp(J y) P2\
Help me please, How to get a spatial derivative?After solving a system of differential equations numerically, I got module.Help please, How can I find a  value of the first derivative
For example , after solving the PDE system, module() export plot,plot3d,animate,value,settings; ... end module
So, I need to find diff(U(x,t),x) (for example x=0 and t=0)
hi
how r u
i am writting this commands for loop but its not working .
i want to write genralize matrix for M and K
> Digits := 100;
> n := 4;
> y := vector([1, 1, 1, 1, 1, 1, 1, 1]);
> results := matrix(n, 3);
> for i to n do a1h := Generate; M := Matrix([[2, 3, 0], [0, 1, 7], [3, 1, 2], [2, 1, 0], [0, 0, 1], [3, 7, 0], [1, 1, 1], [5, 1, 0]]); m := `.`(1/(`.`(M^%T, M)), M^%T); mm := `.`(m, y); results[i] := m^%T end do;
I have a set X={a,b,c,d,e} and a table as follows:
M[2]:=TABLE([e = {2,3}, a = 5, c = 1]);
Afterwards I want to add to this table all those elements (e.g. b={3,4} and d=4) of X which are unassigned in M[2]. How I can do this?
Please help me with transformation of the following expression:
> z:=abs(a)^2*b+abs(a)^2*c*conjugate(a);
where I want to derive
a*(conjugate(a)*b+conjugate(a)^2*c)
I try the following:
> z:=collect(z,a);
However it does't transformate z in any way.
In other words if I have
>z:=a*conjugate(a);
>z:=simplify(z);
I derive z=|a|^2. How to decompose z back into a*conjugate(a)?
I have a nasty definite integral to evaluate. I need to integrate w.r.t X[2] and leave the integrated expression as a function of   X[1].
int(-(1/781250)*exp(-(1/1250)*X[1]^2)*X[2]*exp(-(1/1250)*X[2]^2)/((1+exp((1/67)*X[2]-(1/67)*X[1]))*Pi), X[2] = -infinity .. infinity)
The discretization is via the...
hi,i had 9 set of odes,then i used dslove(numeric) and solved my equations,but now i have a question,my answers do not go more than the time 0.14 ,what can i do?i do need my answers at least for the time 5 seconds ,
i have write my code in this way :
MMM := dsolve(AA,numeric,method = rkf45, maxfun = 500000);
but when i want to evaluate MMM(1) i face this error :
Error, (in MMM) cannot evaluate the solution further right of .14055561, maxfun limit exceeded ...
Let x, y, z be three nonnegative numbers and x^2 + y^2 + z^2 = 5. Find the minimum value of the expression
A = 1/2*x^2*y^2 + y^2*z^2 + z^2 *x^2 + 96/(x + y + z + 1).
How to find the minimum value of the expression?
First 1598 1599 1600 1601 1602 1603 1604 Last Page 1600 of 2430
