Hello, I bring here a problem with maple where I make a definite integral and appear suddenly in the solution a "csgn".
Here is the integral :
V(z) = (int(int(theta*R*(H-p)/(H*(L*L)*sqrt((R*(H-p)/H)^2+(z-p)^2)), p = 0 .. z), o = 0 .. 2*Pi))/(4*Pi*epsilon)
But i want the solution for z where 0
V := proc (z) options operator, arrow; (1/4)*(int(int(theta*R*(H-p)/(H*L*L*sqrt(R^2*(H-p)^2/H^2+(z-p)^2)), p = 0 .. z), o = 0 .. 2*Pi))/(Pi*epsilon) end proc
I am trying to get Maple to calculate this for me:
Let X1,X2,...X81 be a random sample from a distsribution (not necessarily normal) with mean µ=49 and standard deviation σ =8. Let ¯X = (1/81)* ∑i=181 * Xi
I need to find the mean, the standard deviation and the approximate distribition of ‾X,
BTW, the 81 goes directly...
need to find the explicit root of u where k,b are  positive constants:
eq5:=u->-3*b*k*u^2-3*b*k^2*u^4-k^3*u^6*b+k*u+5*k^2*u^3-b;
sol:=(solve(eq5(u),u)): S:=array([],1..3): S[1]:=((sol[1]));S[2]:=sol[2]:S[3]:=sol[3]:S[4]:=sol[4]:S[5]:=sol[5]:S[6]:=sol[6]:
and choose the positive real root and substitute it in another equation.
and then plot k against b as:
I have a mapping as a Table and want to find its inverse mappings. For example for
TABLE([e = w, c = z, d = w, a = w, b = y])
I want to elegantly compute
TABLE([w={e,d,a},z={c},y={b}])
kindly give a compact line of code, regards.
y am not able to excutes these simple steps. What does this error means Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct
Maple is slowly driving me insane. I look at probobly 15 cloud storage solution and I found
one that support http (OwnCloud on Red Free Hosting (free)). The rest uses https.
So I upload my file (see working link below)
http://marcusdavidsson.redfreehost.com/owncloud/public.php?service=files&t=71ff3b85a3d4353e1dd60a49a6e6250f&download
I have a set of points defined for XX[j] and YY[j] where j=1..16,
I'm beginning to write a loop for these values and I was wondering how to get the actual numerical values in to say the following...
GX := proc (j)
local YY, XX, G;
G := (1/2)*(YY[j]-YY[j-1])^2/(XX[j]-XX[j-1])+(1/2)*(YY[j+1]-YY[j])^2/(XX[j+1]-XX[j]);
diff(G, XX[j]) end proc;
Then - for example - for GX(4), this gives an output in terms of XX[4], XX[5], etc but I'd...
I am done with my code but in the end my matirx B contains values in worng order. In matrix B am having row values in column and column values in row due to which my graph is not in correct form. What should i do to change these values..?? Attaching worksheet let me know. Thanks
code_for_neuman_1d_h.mw
for my mechanical engineering studies we have to optimize an engine during a workshop. Therefore we have to use a numerical dsolve to solve the equation of motion. I have to get the maximum bearing reaction for a constant rpm. In order to get this I can't think of anything else but use the dsolve solution and use it in maximize.
ysk_2 := t -> -rc*cos(phi(t))-lp*cos(alpha(t))-lkb-y(t);
ysp_2 := t -> -rc*cos(phi(t))-lp2*cos(alpha(t))-y(t);
Looking at the new group theory facility in Maple 17 Help, the DrawCayleyTable( H ); does not display correctly
i have 12 second order non linear coupled partial differential equations (Euler-Lagrange Equations) in 12 variables {u1a(x1+l/2),u2a(x1+l/2),u3a(x1+l/2),theta1a(x1+l/2),theta2a(x1+l/2),theta3a(x1+l/2), u1p(x1,x2),u2p(x1,x2),u3p(x1,x2),theta1p(x1,x2),theta2p,theta3p}
also there are 17 lagrange multipliers in these equations which are also to be solved, using 17 constraints equations.
along with 48 boundary conditions. These have emerged out of variational formulations
I've been trying to manipulate the equations of a mechanism that I've exported from MapleSIM.  The system equations contain 4 differential ordinary equations, and 6 algebraic equations.  In MapleSIM it simulates fine, but I'm having problems simulating it in maple alone (without multibody exports).
I've tried solving the initial value problem by replacing all the time dependant variables with constants, (and as this is a dynamics problem) I supplied...
The expression below is not producing any plot, although the axes and sliders are set :
I have a Mma code from a colleague that I am trying to port to Maple. This code uses a lot of Mma With[{...}, ...] constructs, to which I found the Maple "use ... in ... end use" construct the closest equivalent. What is being done is to initialize a bunch of local variables and then run the calculations. Non-initialized variables (the ones not in the first section) remain global.
I ran into a problem in Maple when I tried to initialize an element of a Vector, like "use a[1...
When I use Openmaple with C#, if the command line involves "MapleEngine.StopMaple" or "restart", or the command line including "MapleEngine.EvalMapleStatement" is executed twice (sometimes more), it always cause a crash. Can anybody help me out with this problem? Thank you in advance!
The following is the crash report:
unhandled System.AccessViolationException
  Message=Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
First 1599 1600 1601 1602 1603 1604 1605 Last Page 1601 of 2430
