Hi im trying to get maple to output different combinations from a list of elements ( without using any packages ).
for example I have a list :
  here each { } is one element and I need to do combinations in 3's soo I want it to return:
  order doesnt matter and I dont want repetitions.
1. {2,8} {2,4,6,7,8} {4,6,8}
2. {2,8} {2,4,6,7,8} {1,4,8}
3. {2,8} {2,4,6,7,8} {1,4,8,9}
Some calculus problems are worked out with the differential formatted as a function prime (f', G', etc.). How do I enter a function with the prime symbol so that Maple will treat it consistently? I recall entering f'(x) once in the legend of a Plot. The legend, as output, was in 2D format d/dx(f(x).
Another variation on my question is this: If I enter diff(x^2,x), or d/dx x^2 in 2D Maple, and calculate, I get 2x. If there a way to enter f'(x^2) to get the derivative?
I have a 2D ode system. Let the interior equilibrium points be x1 & y1. It is easy to get the Jacobian matrix with the code
> with(linalg);
> with(DEtools);
> J := jacobian([H, K], [x, y]);
where H & K are the RHS of odes. But I need the higher order terms by transforming x=x1+u,
y=y1+v in matrix notation. Please give me the code.
How to find the sum of the series sum(3^(-n)*floor((1/7)*2^(n+2)), n = 1 .. infinity) with Maple?
A more serious formulation is the following. Let us consider the cartesian product
 {1, 2, 3, 4, 5, 6, 7, 8} x {1, 2, 3, 4, 5, 6, 7, 8} as a subset of the plane xOy. What is its maximal subset which does not include three points belonging to a straight line? How to find this with Maple? I don't know the answer. My hypothesis is the number of the elements of that set is about 10.
I have a very basic question: how to make a list of matrices?
For instance, this doesn't work:
for i from 1 to 4 do
M[i]:=Matrix(2,2,[[1,i],[i,i^2]]);
od;
Many thanks!
I am very new to Maple. I would be very grateful if someone could teach me how to write a command in an Maple worksheet to do the following:
Let u(x) be a function of x.
How can I introduce an abbreviation of derivatives so u1x (or u_{1x}) is the first derivative of u(x) with respect to x, i.e., u1x=\partial u/\partial x; u2x (or u_{2x}) is the second derivative of u(x) with respect to x, i.e., u2x=\partial^2 u/\partial x^2; u3x (or u_{3x}) is the third derivative of u(x...
I was wondering if there is any function to represent matrices into linear equations. For an example,
if A=Matrix([[1,2],[2,3]]) , B=Matrix([[x[1]], [x[2]]]) and C=
Is it possible to simplify for example the expression
5^2 * 5^(1/2)
to get
5^(5/2) ?
PS: I am sorry if it was asked and answered, I can't find it.
I have defined a function q(t) in Maple as:
q(t):=ln(cosh(t));
I then calculate it's 15th (!) derivative and assign it a name:
diffq(t):=diff(q(t),t$15)
I wish to maximize this function on the domain [0,50], so do the following:
I use combinat[randperm] in MapleTA to get random permutations. But everytime I call the corresponding question bank, I get the same sequence of permutations. Even a randomize();with(combinat);randperm... doesn't change this behaviour but every single student should get different homeworks. Any idea?
In economics, variables are always real and often positive.
With assume(x>=0) I can set this for individual variables. But with many variables it is arduous.
Is it possible to set by default all variables to >=0 and define ony the exceptions individually?
Thanks you !
With Maple I get the following result
A*x^`beta` = R-A*`beta`/(x^(1-`beta`)*(1-t))
For easier interpretation I would prefer the following, equivalent form:
1/(1-t) * 1/(R-A x^beta) = 1/(A*beta) * x^(1-beta)
I tryed a lot,...
I have to maple worksheets: one called test.mw and another called wholecode.mw. I read a file with
read(filename); from both .mw sheets.
but then test.mw file gives me a correct result while wholecode.mw does not execute the linalg commands. For example, in filename there is:
for i from 1 to 8 do
    s:=col(A,i);
    A1[i] := dotprod([1, x1, x2, x3], s);
od;
while test.mw gives the result wholecode.mw just gives
INPUT:
  [1,2] + [3,4]*x
DESIRED OUTPUT:
  [1+3*x, 2+4*x] as a list
Right now I do the following:
  >  combined := evalm([1,2] + [3,4]*x);
combined := [1 + 3*x, 2 + 4*x]
  >  combined := convert(combined, 'list');
The reason I need to use...
First 1659 1660 1661 1662 1663 1664 1665 Last Page 1661 of 2430
