Hello, I have a set of equations, and I want to solve it over the integers (mod 13). But msolve command fails. Here is my code:
eq:={a4*a1-11, a4*a2-12, a4*a3-6, a5*a1-3, a5*a2-8, a5*a3-4, a6*a1-2, a6*a2-1, a6*a3-7};
msolve(eq,13);
It fails, but I can solve it manually. Here is a solution:
a4*a1 = 11 => a4:=1 and a1:=11
a4*a2 = 12 => a2:=12
a4*a3 = 6 => a3:=6
a5*a1 = 3 => a5:=3/11 mod 13 = 5
a5*a2 = 8 => a2:=8/5 mod 13 = 12
Hi there,
 I have a piece of code that uses lists instead of vectors and recently, it crashed, it ran out of memory. Long story short, if I use vectors instead of lists, the performance is much better and optimal (this I knew but I was lazy to translate all my code). However, there's one single line that I cannot efficiently translate and it's the one that uses the function member(). Before, I had the following (it's an oversimplification of my code in order to easily discuss it in here):
In the name of God
Hello all,
Look at these instructions, entered in maple16(x64):
temp:=Matrix(25000):
--- Up to now, about 5 Gb's of my 8Gb memory is occupied and no problem
unassign('temp');
gc()
Error, (in Matrix) Maple was unable to allocate enough memory to complete this computation. Please see
hello i am using maple and i really like it but one part about it that i do not like is the following:
  • the program forces me to use the mouse. it makes me point and click as if I'm a little child and I find this very degrading. Please help.
For example, how do I perform "insert maple input after the current execution group" with the keyboard? And how do I find/configure other keyboard shortcuts? Thanks in advance.
Recently, I upgraded from Maple 13 to Maple 16.  I have been using Maple for 20 years --- Maple V Release 2 (1992) through Maple 16 (2012), and I participated in beta testing Maple V Release 4, which developed what we now call the Classic Interface.  The Classic Interface is amazing --- it was better than Mathematica in 1994 and it is still better than Maple's Standard Interface.  The Standard Interface is missing features that were...
1. a)given ∫(0..4)∫(√x..2) of sin(pi)*y^3 dydx, graph the region, R, in the xy plane.
b)Write double integral which reverses the order of integration and then evaluate.
2. Find centroid of cardioid of region enclosed by cardioid r=1-sin(theta)
3. a)Graph wedge cut from cylinder x^2+y^2=9, and by planes, z=-y, and z=0, and above the xy plane.
b)Write the integral which finds the volume of the wedge and evaluate it.
Will an older version of AEM (e.g., AEM 14) run with a newer version of Maple (e.g., Maple 16)?
Is there a quicker way to find all unknows from an expression?
unknowns.mw
Say I want a list contains ALL parameters. In this case, it would return
[w1,w2,mu,tau[2],tan[3],tan[4],eta[1],eta[2]]
Is there a way to do this?
Casper
As an intermeditae result I get from maple
A*x^beta = R-1/((y/A)^((1-beta)/beta)/(A*beta))(1-t)
It is obvious, that two fractions can be reduced by (1-t).
I could not reach this with simplify, solve, factor, expand, ...
Any idea?
In addition in the numerator (1-t)^2 is possible. How do I get this?
Thanks for any help !
I have the following object:
t = ∫ (from 0 to e_0) [1 + (121/304)e2)]1181/2299 (1 - e2)-3/2 e29/19 de
and I would like to plot t vs. e_0 on the interval 0 <= e_0 <= about 0.9.
So far, I have managed to get Maple to integrate the thing for any value I like of e_0 from 0 up to (but not including) 1. So, I now just need to get Maple...
I have a little problem.
I need to let maple solve: int( diff( u(x), x$2) * v(x), x=0..1), where u(x) and v(x) are arbitrary single variable real valued functions. Moreover Maple should consider v(0)=v(1)=0 while doing integration.
Maple is returning the integral as it is. I think some how I need to force maple to use integration by parts but do not know how?
I know maple knows: int( diff( u(x), x$2), x) = diff( u(x), x)
test.mw
Here is the problem, I will try my best to describe it:
Firstly of all,
log(p[j,c]/(1-p[j,c]))=mu+tau[j]+eta[c];
In this system, the 'j' is a time varying parameter, and the...
pithe eight digits of your student Id number are used to individualise the questions. they are labelled a1a2a3a4a5a6a7a8a.. all non interger outputs should be to 3 decimal places. question 1_ depending of your own value of a8, write a program that performs the calculation below:
a8             ...
I purchased Maple 12 some years ago and I never used it. I want to download it to this new laptop and don't know how
Hi, I need help with graphing a certain logistics population model for an initial population size that is equal to 1.
dy/dt = k(1 - y/M)y  k=2 M(t)=10e^-t/5 +3(1-e^-t/5)
So far I've worked out the values to input, but I don't know how to write it in Maple.
I know all I have to replace is the M in the dy/dt equation with these 2 values.
M(0) = 10
M(t goes to infinity) = 3
First 1660 1661 1662 1663 1664 1665 1666 Last Page 1662 of 2430
