I have defined a function(say fun) to do certain task, it works well when I call it from a script file(say script1). However, when I copy the complete script1 and paste onto another script file(say script2), the function, fun, doesn't execute. It's very peculiar as my project requires lot of modification, so I copy the old script and...
Hello every one,
I am gettting this error "unable to store HFloat", while solving a system of ODES numerically.
eq1:=n*(-diff(f(eta),eta$2))^(n-1)*diff(f(eta),eta$3)+(2*n/(n+1))*f(eta)*diff(f(eta),eta$2)
-diff(f(eta),eta$1)^2-M*diff(f(eta),eta$1)+M*epsilon+epsilon^2+lambda*f1(eta)=0;
eq2:=diff(f1(eta),eta$2)+P*(2*n/(n+1))*(f(eta)*diff(f1(eta),eta$1))=0;
bc:=f(0)=0,D(f)(0)=1,D(f1)(0)=1,D(f)(N)=epsilon,f1(N)=0;
If S= { <0,1>,<1,2>} and T={<1,1>,<2,3>} are ordered bases for R2 and v=<1,5> and w=<5,4>, then can someone help me:
-find the coordinate vector of v and w with respect to the basis T by creating a procedure?
-I can make a procedure to find the transition matrix PS<-T from T to S-basis, but can you help find the coordinate vector of v and w with respect to the basis S. Using PS<-T?
Hi guys, I would like some help writing a procedure that checks whether the group of input vectors is an orthogonal basis. Any help would be great!
How does one change a previous Atomic setting back to non-Atomic?  This seems so simple, but I can't find anyway to Undo this change.
Dear Mapleprimes,
I am trying to solve an Optimization problem analytically. I set up a lagrangian as follows:
L:= Objective function + mu_1 (constraint 1) + mu_2 (constraint 2)
I maximise with respect to two variables, call them x1 and x2
I want constraint one to bind but not constraint 2. Hence, I set mu_2=0. The I do:
diff(L,x1); diff(L,x2), diff(L,mu1), diff(L,mu2)
I want to claculate a triple integral of a piecewise function. The piecewise function has 17 domains and I guess that this is a bit too much.
Is there any possibility to optimize it?
the piecewisefunction looks like this:
a := unapply(piecewise(
    x1 < 0 or x2 < 0 or x3 < 0 or h < x1 or h < x2 or h < x3, 0,
    0.5*h <= x1 and x1 <= h and h-x1 <= x2 and x2 <= x1 and h-x1 <= x3 and x3 <= x1, A1[13],
I am trying to force Maple to read big matrices from files, produced by other programs (GAP in my case).
The output looks like this after it's been saved in a *.txt file:
[ [ 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
      0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
      0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 0,
thanx for ur answer.it reallly work for float data.but some of the data are complex,like:0.0536472874I,and some are float like:0.043443322222
the float numbers are written in the file and the program is worked until the result is complex number.it stop the program and print the error again!
what should I do with this?!
thank you
I have install Maple13 and GRTensorII on my PC (Ubuntu12.04) ~ but GRTensor dosent work ! When i start Maple13 ,there are the words "Error, "/home/herb/.mapleinit" is an empty file".
Is anybody can help me out of it? I really have done the following in README:
3. Go to the INSTALLDIR. In this directory you will find a file called
mapleinit.sample. This is a Maple configuration script which has
 ((1/(1-x^2))^(1/2))*(sin((1-x)^(1/2)))
I am Beginner in maple , i cannot see why while this function cannot be defined at x=1, but the graph is plotting fine and continuesely in x=-2..2 ?!
and with this one we get another graph and yet different one !
sin((1-x)^0.5)/(1-x^2)^0.5
Can anybody explain to me why , your help will be appreciated !
 I need help to plot  a sequence of the form given in the attachment below
seq.docx
I'm trying to import matlab function from m-file.
File looks like this:
    function out = xxx(omega)
    out = heaviside(omega);
It's only heaviside function.
And now, when I'm using "FromMFile" command in Maple it doesn't recognize Heaviside function. It imports that function as "heaviside" - witch small first character (in Maple we needs big "H").
Any help?
thx
Hello, I'm creating a rolling thin disk (rolling without slip) in the MapleSim, the model like the picture below (Fig. 1).
I am trying to write a script that will read in vector files using ImportMatrix, perform a simple calculation then output a matrix file using ExportMatrix.
The difficulty I am having is that I would like to do this on a number of files,
eg.
for i from 1 to 600 do
Mi:=ImportMatrix(rowi):
do calc....
ExportMatrix(matrixi,Mi):
The variable i is in italics...
First 1663 1664 1665 1666 1667 1668 1669 Last Page 1665 of 2430
