Use the Gram-Schmidt process to transform the basis
{Vector(3, {(1) = 0, (2) = 1, (3) = 1}),
Vector(3, {(1) = 1, (2) = 1, (3) = 1}),
Vector(3, {(1) = 1, (2) = 2, (3) = 3})}
for the Euclidean space R3 into an orthonormal basis for R3
Show 3D result.
I am having a great deal of difficulty with this exercise.
Clues are
>irem(floor(evalf(K*10^n,N)),10) can be used to find the nth digits of the decimal expansion of K
A given process.
The following procedure P(n) counts the number of prime numbers ≤ n.
> P:=proc(n) local c,i;
c:=0; # initialize the counter c=0
for i from 1 to n do
if type(i,prime) then c:=c+1;
end if; # increase c by 1 if i is prime
I have a multivariate polynomial equation, in that somehow I know the coeffcients, using this information, I want to extract the variables. This will be the opposite of coeffs function.
for e.g. I have 3*x3 + 5*x4
Given 3 and 5, I want to extract x3 and x4.
Satya
I believe this is a result of my ignorance rather then the flaws of the system. Can anyone teach me how to do this question?
Given
>sum(1/n, n = 1 .. N)
I want to find the value of N such that sum(1/n, n = 1 .. N) is greater then 20.12.
>solve(sum(1/n, n = 1 .. N) > 20.12, N)
Help please! Thanks.
Hi, experts,
I have an equations:
How to solve a, and b? It's easy to know that a = 2, b =5 though.
Many thanks!
In the name of God
Any one knows how I can summerize this:
v1:=Vector(3):v2:=Vector(3):v3:=Vector(3):v4:=vector(3):v5:=Vector(3):
these 5 are independent.
Maybe some help page of maple helps me.
Hossayni
How can i solve for G(p,q,r,t) in the following pde
diff(G(p, q, r, t), t) = {lambda*(p-1)+gamma*(r-1)}*G(p, q, r, t)+delta*(1-p)*(diff(G(p, q, r, t), p))+kappa*(N*r-q)*(diff(G(p, q, r, t), q))+mu*(1-r)*(diff(G(p, q, r, t), r))+beta*(q*e^(-`ρτ`)-p*r)*(diff(G(p, q, r, t), r, p))
Dear All
I trying to solve the following in MAPLE, the code works fine in MATLAB but I am not sure why it doesn't give me values in MAPLE
n:=3: alpha_p:=1: p:=2: mu0:=4*Pi*1e-7: Br:=1.12:
A1:=unapply(sin((n*p+1)*alpha_p*Pi/(2*p))/((n*p+1)*alpha_p*Pi/(2*p)),n):
A2:=unapply(sin((n*p-1)*alpha_p*Pi/(2*p))/((n*p-1)*alpha_p*Pi/(2*p)),n):
M1:=unapply((Br/mu0)*alpha_p*(A1(n)+A2(n)),n):
M2:=unapply((Br/mu0)*alpha_p*(A1(n)-A2(n)),n):
How can i solve for X(t) in the following equation
diff(mean(X(t)), t) = lambda-delta*mean(X(t))-beta*mean(X(t)*V(t))
and how can i plot X(t) against t.
Here is what I tried.
I need to get the sum of all the real roots of 3*sin(x^2) = x
So I tried this.
>solve(3*sin(x^2)-x = 0, x, AllSolutions)
Which gaved me this 3*sin(RootOf(_Z-9*sin(_Z)^2))
Then >sum(3*sin(RootOf(_Z-9*sin(_Z)^2)), _Z = -infinity .. infinity)
Which gives me this answer which I cannot make sense of.  signum(sin(RootOf(_Z-9*sin(_Z)^2)))*infinity
I'm trying to solve for n in a simple sum() function:  Here is the function.
I have a question regarding on how to graph and prove that csc ^2(theta)-cot ^2(theta)=1 our professor provided us with a very poor example, i have to graph the left side of the equation first with a 0 to 2*Pi x-axis and then graph the right side on the same plot.
I examined some rules to verify that if a certain function for example f(x)=x^2+5 is a 1-1 function or not.
What I did after defining the function was as follows:
[> assume(x>0,s>0);
[> solve(f(x)=f(s),{x,s});
OR
[> solve(f(x)=f(s),{x,s}) assuming x:: positive;
They didn't give me just
s=x
at all. Thanks so much.
Could anyone help with solving this integral?
> evalf((∫)[-infinity]^(infinity)((∫)[-infinity]^(v)( uv)/(sqrt(2 Pi))(1/2+1/2 erf((1 )/2 sqrt(2) u))(1/2-1/2 erf((1 )/2 sqrt(2) v))(e)^(-((u^(2+v^(2))))/(2)) ⅆu )dv);
thanks,
I have a piecewise defined function alpha. Its functional directives are stored in a vector A. But when I call up the command
alpha:=(x1,x2,x3)->piecewise(
    x1 < 0 , A[1],
   0< x1<1 A[2], ...):,
the result (x1,x2,x3)->piecewise(.... , A[1], ...) remains symbolic. What can I do that the entries of A[i] appear in the functional directive?
First 1665 1666 1667 1668 1669 1670 1671 Last Page 1667 of 2430
