In fact, I have one last question :
Now I have drawn polyhedron whith the command that goes with it. How can I do the same thing for the color ?
polyhedraplot([0, 0, 0], polytype = hexahedron, scaling = constrained);
And is it possible to add points on the picture of the polyhedron ? Like center of the faces, middle of the edges and vertex...
I am trying to solve the following bvp:
with*plots
Eq[1] := diff(f(eta), `$`(eta, 3))+3*f(eta)*(diff(f(eta), `$`(eta, 2)))-2*(diff(f(eta), eta))^2+theta(eta)
Eq[2] := diff(theta(eta), `$`(eta, 2))+3*Pr*f(eta)*(diff(theta(eta), eta))
Eq[3] := diff(phi(eta), `$`(eta, 2))+3*Sc*f(eta)*(diff(phi(eta), eta))-kappa*Sc*(phi(eta)*(diff(theta(eta), `$`(eta, 2)))+(diff(theta(eta), eta))*(diff(phi(eta), eta)))
BCs := [f(0), (D(f))(0), ((D@@2)(f)...
Hello everyone !
First of all, excuse my English if it's difficult to read, I'm french.
I'd like to draw a surface/shape in 3D in spherical and I used plot3d with coords=spherical to do so. But I'd like to color on the picture to change when R(theta,phi) changes. I could visualize how R is changing and where it is the same. But I have no idea how to do so...
I can't put the picture here, the formula is too long...
good say !
I want for my work to calculate the International Equation of State of Seawater
but when i enter my fonction in mapple: it is like mapple don't recognise the second variable s:
>t:= -> t;
s:= -> s;
> g :=(t, s)-> 999,842594+6,793952*10^(-2)*t-9, 95290*10^(-3)*t^2+1, 1685*10^(-4)*t^3-1, 120083*10^(-6...
I would like to extract data from 3d implicit plot. I try this:
> points := plots[implicitplot3d]((x^2*(1-x^2)-y^2)^2+0.5*z^2-0.025*(1+1.0*(x^2+y^2+z^2)) = 0, x = -1.5 .. 1.5, y = -1.0 .. 1.0, z = -1.0 .. 1.0, numpoints = 1000);
> ptslist := convert(op([1, 1], points), listlist);
> ptslist[1..12];
Maple prints a list:
[[[-1.50000000000000, -1., -1., 14.9039062500000], [-1.50000000000000, -1., -.818181818181818, 14.7468814566116...
I was able to try the code on M15 and M16 but the final answers are slightly different.  Why is that?  Shouldn't they all come up with the same value?
The value for M15 came up with the same as value as M12 but M16 was different.
Using p(.22,80*3600)
M12  [x = .22, t = 288000., T = 685.116351910514254]
M15  [x = .22, t = 288000., T = 685.116351910514254]
M16  [x = .22, t = 288000., T = 685.11635191051
How can I resize inline plot-window without mouse? (I know about resize tool, but it displays plot in new window :( )
And how can I display 5 plots in one line one by one?
Thx :)
I cannot make Maple find the solution for the integral of sqrt(x/(1+b*x^3)) assuming x>0 and b>0, which is 2*arcsinh(sqrt(b*x^3))/(3*sqrt(b)). Mathematica does this without any problems. What am I doing wrong?
How do I stop maple from running the rest of the worksheet in case an error occurs in the middle of it? Which command should I use?
More specifically, I have a program in which I input the masses of the particles and then the program will calculate the corresponding parameters of the potential, and will do a lot of other stuff with these parameters. However, it these parameters happen to be complex, the program should simply halt with a warning: "your parameters are complex, cannot continue".
Good day! Some of my tasks are quite time consuming. What maple command I have to use in order to get some sound signal when calculation is over?
I am trying to set up a procedure for creating a matrix of user specified size.  Basically, I want the user to be able to specify the size and the values of the internal parameters and maple will generate the matrix.  The matrix has the form:
[e   h1   0   0   ...    0]
[h1  e    h   0   ...    0]
[0    h    e   h   ...    0]
I have a module which is an argument to a procedure.
When I "trace" this procedure, the entire module is  printed (as it should).
Is there a way to NOT print the contents of the passed module? It is annoying when debugging.
Paul
I've got a list of inequalities
[x > 5, 10 < x]
and I need to plot the region by
plots[inequal]( [x > 5, 10 < x], x = 4 .. 11, y = 0 .. 1);
but I don't want to specify x-range.
So how can I get the numbers from inequalities and generate something like "x = 5-1 .. 10+1"?
Thx :)
I realize that Maple itself does everything but I would like a simpler cheaper solution for a number of computers in my classroom.  Multiple licenses of Maple is not an option.
maplematrix.mw
I am stuck again in a simple problem of creating a M*1 Matrix.  I have attached a Maple file for your kind consideration.
I shall be looking forward to your reply.
Best Regards
A.Q
First 1712 1713 1714 1715 1716 1717 1718 Last Page 1714 of 2430
