Let's say we have the response of a discrete system  to a unit step, the measured data is available as a vector in Maple. As example: seq(evalf[2](exp(-n/5)*sin(n)),n=0..20);
How can I find the coefficients of the transfer function G(z)=(a1*z+a2)/(b1*z^2+b2*z+b3)?
Here is a paper that describes on page 27ff how to do this with regression.
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.136.373&rep=rep1&type=pdf
Maybe there is a better way.
> with(CurveFitting); data := [[2, 10], [3, 1], [5, 4], [7, 5]];
> PolynomialInterpolation(data, y);
                    3  3       2   199     143
I have a 4 by 4 matrix that I need to augment to a 7 by 7 matrix.
I find I can use the "|" operator to append a column to my original matrix. So I can do this three times and I have a 4 by 7 matrix.
Now, the only way I have found to add the three rows I still need to add is to transpose, use "|" three times and to transpose back. While this indeed works it is rather clumsy and probably not efficient.
Is there a better way to do that better; i.e. is there...
I need to fit a complex function to some data points Couuld you please show me what Maple operations to use?
The function is:
pn := unapply(KT*bn*(sum((dWn[i](lambda)*(sum(c[i+r]*binomial(i+r, i)*(Lmbd0(lambda)/bn)^r, r = 0 .. nterm-i))+IWn[i](lambda)*(2*lambda^3-2)*(sum(r*c[i+r]*binomial(i+r, i)*(Lmbd0(lambda)/bn)^(r-1), r = 1 .. nterm-i))/(bn*(3*lambda^2)))/bn^i, i = 0 .. nterm)), lambda);
- 'IWn' and 'dWn' are known (and long) functions of lambda.
I'm having problems to do somehting that I guess maple should be able to do. I am solving numerically a 2nd order equation. Then Dsolve gives me the function and its first derivative.
Is there not a way to plot 2nd and 3rd derivatives??
Of course I have thought of getting f'' as a funtion of f' and f through the differential equation, but in my case that involves a complicated analytical development, and I precisely want to verify that I didnt do...
Dear everyone,
  I have a question related to copy and paste in Maple 16.
 Consider an input like
eq1:=4*x^n*y^m+3*x^2+5*y^2;
f1:=map(t -> `if`(match(t = c*y^d, y, 's'), subs(s,c), NULL),
      convert(eq1, list));
f2:=map(t -> `if`(match(t = c*y^d, y, 's'), subs(s,d), NULL),
Sir/Madam
My Version of MAPLE is 13.02
I have the following expression on my worksheet:
(63/8) ((cos(Θ))^5)[G,H,L,P,T,U]^5 -(35/4)((cos(Θ))^3)[G,H,L,P,T,U]^3 + (15/8)(cos(Θ))[G,H,L,P,T,U]
I do not need the factors of [G,H,L,P,T,U] and I want to delete them, but all my efforts in the past few hours are in vain. I have tried to highlight those expressions and then use the EDIT -> DELETE ELEMENT...
Is there a way to generate Java or C code to implement a general nth order linear ordinary differential equation?
I am looking to be able to send the coefficients and have it compute the time waveform given initial conditions.
Regards.
how can I solve memory used limitation problem on MAC OSX LION .After memory indicated on the bowwtom of the sheet reaches 57M it freezes.
I noticed the following behaviour in Maple 16:
x1 := (a)^(b):
eval(x1,[a=103/100]):
evalf[3](%);
                                 b
                             1.03
I wish to use the 'Numeric Formatting' feature on some results in Maple, to show the correct significant figures in the results. But when I apply Numeric Formatting to any result, the decimal seperator changes from the usual dot (.) to a comma (,). How can I keep the dot as decimal seperator while applying the correct significant figures?
I entered the following code in Maple 15.  In one instance it plotted the correct graph with the "x" and "y" labels exactly where I wanted them.  The identical code, in another instance (and again in a separate tab) generates an error:
  "Error, (in plots:-display) cannot make plot structure from object with name textplot"
Of course, when I click the error above in Maple (it is a link), a Maple webpage comes up that says:
mapletrig.mw
I need to solve a simple integration as shown in the attached work sheet.  But don't know how to obtain the required answer as shown.
I shall be very thank full if you guys could help me out with this.
Best Regards
A.Q
Please excuse me if this question is too basic or has been answered before, though I've spent a couple of hours searching for similar questions without any luck.
I have the following expression, which is given in terms of other expressions:
Hallo Everybody!
I have a question concerning MapleSim5 and the "change of parameters during the simulation".
I am trying to build a kind of gantry crane, consisting of a vehicle with a pendulum. The mass on the pendulum can be pulled up and pulled down (the pendulum length can be varied). The inertia of the pendulum changes with this length of the pendulum. The pendulum is represented by a "Rigid Body". In this block it is possible to enter the matrix of inertia.
First 1714 1715 1716 1717 1718 1719 1720 Last Page 1716 of 2430
