With the command, subpicture,I take the portion of it that interests me.
How I manage to include this sub-image in another image (img)?
Preview(correctedT)
imgs := GetSubImage(correctedT, 100, 125, 20, 120)
Preview(imgs)
Hey there,
i have an System in the form below.
I try to plot s over the angle t which is used in the functions (S,DS and DDS) but because maple uses t in the functions (s, v and a) as the time the calculated eigenfrequency doesnt fit to the System.
The eigenfrequency should be omega:=sqrt(c[0]/m[1])=1035 (over 360 degrees) but because of the angle time switch the eigefrequency is 1035 (over 1).
Has someone an idea how i can tell maple that t is an angle in degree? ...
Hi, here is what I have, I would like to get A[1],A[2],A[3]...A[20] which are 18x18 matrix.
Then I would like to specify certain value for example A[4](2,3), or A[5](1,8) etc.... But there seem to be something wrong with my definition of A[m], I could not write A[m](i,j).
When i type A[4], it does not give me a 18x18 matrix. Please help. Thanks.
interface(rtablesize=infinity):
lam:=RandomMatrix(18);
I’ve created a basic model of a two-lane road.
Is there a way to get Maple 16 into my linux menu (Linux Mint)?  My workaround has been to copy the Maple executable to the desktop.
What changes should I make to make it sum up?
for k from 2 to 21 do
A[k]:=Matrix(18);
P[k]:=Matrix(18);
Ct[k]:=Matrix(18);
for i from 1 to (k-1) do
Ct[k]:=A[k-i].P[i];    ####what changes to make here?
I would like to get
Ct[2]=A[1].P[1]
Ct[3]=A[2].P[1]+A[1].P[2]
Ct[4]=A[3].P[1]+A[2].P[2]+A[1].P[3]
Ct[21]=A[20].P[1...
Hi everyone,
I need to expand a sum inside a single multiple integral into separate integrals, as in:
I need to solve some  transcendental equations, using Maple 16 which i need to transform or bind with java later. My problem is I cant evaluate.
Equation I would like to evaluate is  k= ln((M-m)/m(k-1))offcourse I  defined m and M, prior to c.
Both  eval(k) and evalf (k)  only return k,  I need value for further calculations.
Dear All:
 I have a curve about mosfet  Coss Vs. Vds . the detail math relationship can be found in the following picture:
 Can anyone fitting this picture by simple math function.
 PS: pls don't considering piecewise function
i am successfully transforming a 2D plot, when doing the exact analog thing to a 3D plot i get the error message
Error, (in t) invalid input: unknown uses a 3rd argument, z, which is missing
i have no idea what's going on, please advise.
i made a minimum example:
this works:
> restart:with(plots):with(plottools):
> norm2:=x->x[1]^2+x[2]^2:
> N:=[0,1]:
> phi:=(x,y)->N+2*([x,y]-N)/norm2([x,y]-N):
hi! I have this worksheet with some errrors and I don't know how to solve this.proiect_dm.mw
please help me!
It is possible, using the image tools package, embed a text and a geometric figure in a picture?
 How to proceed?
Gracias
I try to use fsolve to solve a set of equations for real parameters alphaij, thetha (they are the real angle and phases in the parametrization of a unitary 2x2 matrix)
assume(alpha11::real,alpha12::real,alpha22::real,theta::real);
myresult:=timelimit(10*time_max,fsolve({mat_M_V[2,1]=0,mat_M_V[1,2]=0,Im(mat_M_V[1,1])=0,Im(mat_M_V[2,2])=0},{alpha11=0,alpha22=0,alpha12=0,theta=0},'fulldigits'));
unfortunately fsolve ignores my assumptions and returns complex solutions
Hi, here is what I have. How do I assign the each A please?
A:=seq(Matrix(18),i=1..21):
A[1]:=IdentityMatrix(18):
It wouldn't allow me to assign A[1]. May I know how do I do it please?
For a beam vibration problem I want to animate a function w composed of a time dependent part p(t) and a coordinate dependent part W(x).
w(x,t)=W(x)*p(t)
The coordinate dependent part is an analytical function, but the time dependent part is sequence of a cetrain length with numeric data [{value},{time}]. The code that I used for animating a fully analytical function therefore can't work anymore.
w := W*p:
with(plots...
First 1717 1718 1719 1720 1721 1722 1723 Last Page 1719 of 2430
