I have a problem related to solving the complex equation of dispersion relation.
In the plots some modes are missed. I dont know whay?
Is possible to help me? (m0^2<0).
 rrr:=proc()
 local ce,c0,ve,va,cte,ct,me,m0,DT,n,EQ,i;
 ce:=6.2;c0:=0.25;ve:=5.25;ck:=1.06;ct:=0.243; cte:=2.515;
 me:=sqrt(((ce^2-v^2)*(ve^2-v^2)/((ce^2+ve^2)*(cte^2-v^2))));
 m0:=sqrt((c0^2-v^2)*(1-v^2)/((c0^2+1)*(ct^2-v^2)));
I write this code:
> e1 := a-3;
a - 3
> e2 := sqrt(6)*b+6;
(1/2)
6 b + 6
> trac := e1+e2;
(1/2)
a + 3 + 6 b
> dter := e1*e2;
/ (1/2) \
(a - 3) \6 b + 6/
> dell := trac^2-4*dter;
Hello, I'm just starting to work with maple I'm working on Enzyme kinetics project and I have no idea how to solve ODE system using GEAR'S or A-stability methods. I'm looking for help.
What is wrong?
> restart;
> Digits := 10;
> dsys := {diff(E(t), t) = -kf*E(t)*S(t)+kr*ES(t)+kcat*ES(t),
Hi, I'm trying to calculate a few integrations:
E1:=map(int(N1),eta=eta0..eta2)
E2:=map(int(N2),eat=eat0..eta2)
E3:=map(int(N3),eta=eta0..eta2)
N1, N2, and N3 are 3x3 matrix are are functions of eta0, eta2. eta0 and eta2 are derived after several integration as well.
If i do not want to change the name "eta0" and "eta2", can i write something to indicate (eta0 for E1 is 8.3, eta0 for E2 is 4.5, eta0 for E3 is 7.9). I hope...
given a ploynomial in three variables x,y,z, I want to check if it is nonnegative for all (x,y,z) in R^3.
I know there is a function 'verify' in maple but it doesn't work with my polynomial, I think it's too complex.
Do you have any idea which other function I could try?
flower15
Hi, i'm trying to change Matrix([[9,8,7],[6,5,4],[3,2,1]]) into Matrix([[1,2,3],[4,5,6],[7,8,9]]). I try to use FlipDimension, it works with two steps, but i cant seem to fit it into one step. Is there a simplier thing that i could do please? Thanks.
i've been using evalf(Pi*5.6) for my calculations. after a few steps of calculations, some of the values are as small as 7.4x10-9 . These small values are insignificant to my calculations. how should i ask maple to ignore all the positive and negative values that are smaller than 1x10-9?
Please advice. Thanks
there are four points :
O = (0, 0), P = (0, b/d), Q = (beta/delta, 0), R = ((-d*beta+b*gamma)/(-delta*d+gamma*c), (beta*c-delta*b)/(delta*d-gamma*c))
and then  define the jocbian maxtrix as
J=Matrix(2, 2, {(1, 1) = beta-2*delta*x-gamma*y, (1, 2) = -x*gamma, (2, 1) = -y*c, (2, 2) = b-2*d*y-c*x})
at last , i want to get the jocbian matrix at the four points,  so  must substitute the coordinate of the four point into the...
How generate all possible samples of size n = 2 that can be drawn with replacement from this population [0,1,2]?
It occurs to me using these commands.
 restart; with(combinat); choose([0, 0, 1, 1, 2, 2], 2);
        [[0, 0], [0, 1], [0, 2], [1, 1], [1, 2], [2, 2]]
 permute([0, 0, 1, 1, 2, 2], 2);
[[0, 0], [0, 1], [0, 2], [1, 0], [1, 1], [1, 2], [2, 0], [2, 1], [2, 2]]
I am planning to use the "schedual task" in windows to try to launch
maple in the background (run under some different user account)
to do some computations.
For this pupose I have designed a little counter that is located in the
Start up code region:
for i from 0 to 100 do
if DataTable1(1, 1)=i then DataTable1(1,1):=i+1:  break; end if:
the DataTale will tell me how many times the worksheet has been opened
just to check...
For MathieuA and MAthieuB:
Values returned by MathieuA  and MathieuB are characteristic values  of the corresponding Mathieu function only when v  is a rational number and MathieuA  and MathieuB  return a different number only when  v  is an integer.
You can see a plot on maple pages for a0, a1,.. a4. And b1, b2,..., b5.
However, I would like to plot characteristic values for non-integer values. I would like to do this...
I have to plot a variable in a diagram which is updating itself. The Variable is the area of a various triangle and the  value has to be plotet in a view of the triangle. How to do this?
Is there any way to reverse an axis in the plot command? I solved the baristochrone problem as
a school project,but I did it using an upside-down Y axis. Of course, when I try to make a graph with
my solution, I'm getting a regular cycloid instead of an inverted one, since I was using a
reverted Y axis when solving the problem.
Help would be very appreciated as I couldn,t find anything on the subject.
How would one set up a multispring model in maplesim?
Actually I don't know the exact model I want to try to explore yet, but I was wondering if someone could show an example of, let's say a beam with 4 springs attached offset to one end.  On one end of the beam we inject vibrational frequencies and graph the output on the other end - doesn't matter which end - I imagine we could explore both from both ends.  How could we set that up?
Here is my example picture.
I've been trying to work out an algebraic expression for the following summation
S[n,t] = Sum(factorial(k)/factorial(k+t), k = 0 .. n-1), entered as S[n,t]:=sum(f,k=0..n-1); (with f:=k!/(k+t)!;)
I entered the above Maple expression into Maple (13) just so I could check out some small example summations I had. Maple's arithmetic, accuracy and speed is much superior to mine!...
First 1731 1732 1733 1734 1735 1736 1737 Last Page 1733 of 2430
