Consider a simple polymer , which consist of long chains of simple molecules attached to each other, e.g:
....-CH2-CH2-CH2-...
If the interaction energy between consecutive sections ca be ignored or is low enough, the chain can be bend around at varios places to form varios configurations. One can start by  fixing the first section to a particular co-ordinate and then add additional components by use of random walk with...
In recent days, I have studied ExcelTools[Export]. Unfortunately, I still can not apply it.
oh, how??
Dear, can you provide an example?
I have to generate F(x) of a function with a degree of 5 who has zeros of x=2,x=1+3i,x=2-4i
After i put it into maple i use the command expand to give me the total function but afterwards i get this 144*i^4*x-25*i^2*x^3+x^5-288*i^4+118*i^2*x^2-8*x^4-188*i^2*x+25*x^3+104*i^2-38*x^2+28*x-8
i need to know what command can i use to get it to converts i^4 to 1 and i^2 to-1 that way i can truly simplify it.
Dear everyone,
  I have a question about the memory requirement of generalized eigenvalue solver in Maple 10 and further versions.
Suppose I have a code like
Digits:=34;
n:=30;
A:=Matrix(n,n);
B:=Matrix(n,n);
for i from 1 to n do
  for j from 1 to n do
     if i=j then
       A[i,j]:=i*j;
       B[i,j]:=1;...
I want to create a simple executable bat fil.
1) When I click on it maple should launch in the background (I dont want to see maple open)
2) Then Maple should open a txt file located on the desktop (containing a 1), read the file
and save  a new txt file on the desktop containing the number in the previous fil +1.
How can this be done?
i study a simple differential equations as follow and get the solution,but i faced two warning which puzzle me:
> restart;
> eq2 := diff(x(t), t) = x(t), diff(y(t), t) = x(t)^2+y(t)^2-1;
   ans1 := dsolve({eq2, x(0) = 1, y(0) = -1}, numeric, [x(t), y(t)], range = -10 .. 10)       ;
Warning, cannot evaluate the solution further left of -1.1646698, probably a singularity
Hi everyone,
I have this differential equations:
gamma1:=1;gamma2:=1;
l:=t->sqrt((x1(t)-x2(t))**2+(y1(t)-y2(t))**2);
2 2
l := t -> sqrt((x1(t) - x2(t)) + (y1(t) - y2(t)) )
DE:=[diff(x1(t),t)=(-1/(2*Pi))*gamma2*(y1(t)-y2(t))/l(t),diff(y1(t),t)=(-1/(2*Pi))*gamma1*(x1(t)-x2(t))/l(t),diff(x2(t),t)=(-1/(2*Pi))*gamma2*(y2(t)-y1(t))/l(t),diff(y2(t),t)=(-1/(2*Pi))*gamma1*(x2(t)-x1(t))/l(t)]:
I want to draw the phase portraits (x1(t...
I'm using the BoxPlot function and am trying to change the colour of two dates in the title="string" part, so they correspond with the colours of the two related box plots. Is there a way to do this?
I have tf=0.04s but the probe plot only 0.02s at one simulation, 0.03s for another simulation ! How to oblige the probe to plot from 0s to 0.04s ?
I have two parametric equations, one for x(t), one for y(t).  Both are ODEs of order 1.  Both are implicit.  There is no way to solve explicitly for dx/dt or dy/dt.  How can I get Maple to do a plot of the solution?  I tried DEplot but apparently it demands an explicit presentation of dx/dt and dy/dt.   I have Maple12 on a Mac, but could use Maple15 on a server.
Dear everyone,
  I have a simple problem of writting data into a file:
  For something like
for i from 1 to 3 do
  L[i]:=i;
writedata(`d:\test.txt`,L);
I got
Just a small question: what's the difference between writing
product( (2*i-1) mod 3 + 1, i=1..10 )
which incorrectly gives 105411381075, and writing
mul( (2*i-1) mod 3 + 1, i=1..10 )
which correctly gives 432...
And what's the reasoning behind this?
-- Regards,
Franky
Hi everyone,
While I am getting more and more comfortable with the document mode, I have some questions regarding the document block feature:
- What is a document block good for anyway?
- Why not have the whole document in one block?
- Can one join two document blocks?
- when do I "remove the document block"
- How can I make sure that say an informational 2-D math expression inside a document block never gets executed?
-- Can I still...
First 1730 1731 1732 1733 1734 1735 1736 Last Page 1732 of 2430
