Well, I'm trying to connect a translational spring to a revolute joint. But, I'm unable to do so. I'm new to MapleSim and I ain't a mechanical engineer either. I need you to help me a little. Anticipating a quick response!
I wrote my own maple library. Some of its procedures require the LinearAlgebra-library.
Is there a way to automatically load LinearAlgebra when loading my library? (I tried to use 'use' but it didnt help )
Currently i load my library with
read "/home/..../something.lib";
Is there any good refernce to learn how to write maple libraries the right way? the maple help isnt actually very helpful.
restart;with(geom3d):
point(M,1,2,1):
plane(P,x+y-3=0,[x,y,z]):
plane(Q,2*x-2*y+z-1=0,[x,y,z]):
line(d,[1+2*t,1-t,t],t):
n:=NormalVector(P):
line(Delta,[M,n],t):
Eq:=Equation(Delta):
intersection(N,d,P):
coordinates(N):
decom:=proc(n::posint,m::posint)
> local a,c,d::posint,e,f,i,j,k,l,s,t,u;s:=[];t:={};u:={};
> if m=n then return [[1$m]];fi;
>  for i from 1 to nops(decom(n-1,m)) do
>   a[i]:=op(i,decom(n-1,m));# a is a list
>   c[i]:=[op({op(a[i])})];
>   #d[i,j]:=coun(a[i],op(j,c[i]));#c:unrepeated numbers in a. d:number of repeatance
>    for k from 1 to nops(c[i]) do
>     e[i,k]:=aadd1(c[i],k);
For example, in the list [1,1,1,1,2,4,6,1,9], how many 1s are there?
Is there a procedure in Maple? Or how can I manage to do it?
See the attached worksheet: myDet.mw
Why does the determinant of A  contain  x, x^3, x^5, x^7 and x^9 ?
Maple15/Linux/Fedora16_x86_64
i am solving for a system of df eq's, but the eq's have these little tricky integrals inside them.....so it either retards operation or no solutoin can be found...They look like...
B_12:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(3/2)) * ((a_3^2+u)) )):
B_122:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(5/2)) * ((a_3^2+u)) )):
B_123:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(3/2)) * ((a_3^2+u)^(3/2)) )):
B_23:=(10*a_2*a_3...
My problem looks as follows................pts1FIXED comes from dsolved solution......it plots a empty figure...and i checked that l(the data pairs looks fine)..
Energy:=array(1..450);
Time:=array(1..450);
for i from 1 to 450 do
Energy[i]:=-1*((32*G*Inertia^2*e^2)/(5*c^2))*pts1FIXED(i);
l := [[t,Energy[t]] $t=1..450]:
plot(l,style=point,symbol=circle,color=blue);
I need some help...i need a solver using the Runge-Kutta method adaptive size control, to solve a sytem of 5 diff eq's, all of them are interlinked...
And
Say that dsolve numeric produces a results, called Solution, Now ex  solution(0)=1, and in general solution(t) can be evaluated, now, i want to use this, in E(t)=2*solution(t), in a plot, thus...
plot(E(t),t=0..100,....), but returns the error....
hello everyone, this is my first time visit mapleprimes, i just started to use maplets programming, so there are a lot of things i still don't know about this maplet, if i ask some stupid questions please be patient with me.
so i've been trying to write a maplet that will calculate some simple functions such as addition, multiplication, division,...,it's kind of like a calculator.
i've been trying all day, and no luck so far. help please.
Ok, I am not a very experienced user, but I am mystified by this.  The essence of the problem is that when entering a range of values in an integration, I get a different answer if the range is given as 0..1 to if it is given as 0.0..1 or 0..1.0. Here is the program
### dgig
dgig := proc(psi, chi, lambda, t)
    (psi/chi)^(lambda/2)*t^(lambda - 1)*exp(-(psi*t+chi/t)/2)/\
    (2*BesselK(lambda,sqrt(chi*psi))):
end: ## End of dgig
if i want to create a table which contain buttons label from 0-9 so when i calculate n! i can use the number buttons on the table? please help.
Suppose I have a file of text that I would like to read into a Maple (16) worksheet as a string. (I have in mind encrypting the string using the RSA encryption scheme.)
If I paste the text directly into the worksheet and surround it by ",  I have no problem, but if I try to read, for example, a file some_text.txt using a command like
     read("C:\\Users\\MyName\\Desktop\\some_text.txt");
I've created a matrix in which each row has two values. I'm using Add(i,i=[matrixName][row element number])/2 to find the mean of each row, which I'd like to transfer to a corresponding element number in an array or a vector, but so far I can only get it to work on single rows or (if I use only Add(i,i=[matrixName]/2), understandably, the mean of the whole matrix. Is there a way to do it wholesale?
First 1733 1734 1735 1736 1737 1738 1739 Last Page 1735 of 2430
