Hi everyone,
I would like to do:
f:=unapply(x**2,x);
j:=unapply(2*f(x),f(x));
Basically it is to define j(f(x))
But this is doesn't work. What is the right way to do it?\
My final goal is to calculate int(j(f(x)), f(x)=-infinity..infinity).
I have the following lines of code:
W:=sum((k^(2*i))*sum((e^(j))*w[i,j](r,t),j=0..2),i=0..2);
P:=sum((k^(2*i+1))*sum((e^(j))*w[i,j](r,t),j=0..2),i=0..2);
for c from 0 to 2 do
  for d from 0 to 2 do
    rw[c,d]:=coeff(coeff((k/(2*r))*(diff(W,r)*diff(P,t)-diff(W,t)*diff(P,r)),k,2*c),e,d)
  end do
I mean to compute the coefficients in front of powers of e inside...
Hi everyone,
Is it possible to perform an integral over vector without writing a multiple integral over each component?
I am integrating over a vector of dimension 12, so I am trying to find another way to calculate rather than writing 12 integrals.
Please write for me a code for the following problem.
Let (S): x^2 + y^2 + z^2 -2*x +2*z + 1 = 0 be a sphere and M(1, 2, -1), N(3, 1, -1) be two points. Find the coordinates of the point K lies on the sphere (S) such that the triangle KHN has minimum area.
Thank you very much.
Probably trivial, ...but how to set up a slider in degrees.
I'd like to use degrees instead radians in expresion ...from some reasons.
Help will be apreciated :-)
wzelik
slider.mw
I am fairly new to using Maple and am a university student. Bascially, I wanted to ask, how can I solve for all roots of the transcendental equation
tan(9*(1.1575*10^12/(1-.5)^1.2-x^2)^(1/2)*10^(-6)*(1/2))/tan(9*(5.555*10^11/(1-.5)^1.2-x^2)^(1/2)*10^(-6)*(1/2))
I more than 20000 data points on a an excel file and i want to plot one column against the other. So I imported 10 data points from each column seperately and tried ploting it as a normal plot but it would not work. I kept on getting error messages like
plot([CosAa,CosBb]);
Error, (in plot) incorrect first argument [Array(1..10, 1..1, {(1, 1) = 0.83333e-2, (2, 1) = 0.166666e-1, (3, 1) = 0.249999e-1, (4, 1) = 0.333332e-1, (5, 1) = 0.416665e-1, (6, 1...
I have an equation to solve.
1= sum_{i=1}^n 1/(x+a_i) where a_i is given. I want to solve this equation for unknown x. I know there is a value between 0 and 1. Although I can find the solution by numerical method, I am interested in close form to solve this equation.
Help please.
Best Regards,
Saeid
I have these as outputs from comparing the coefficients. How do i assign the g2xyz totheir associated numbers.
eg at present g2000 is g2000. I need it to be 1.2e7. And so on down the list.
I got an MS Excel file where the matrix (7054x60) is created and the last row of the matrix is used for optimization of its (the matrix) values. In Maple you can create the matrix as follows:
M := Matrix(7054, 60):
for i to 10 do M[1, i] := 1 end do:
Mat_proc := proc(x)
  local i, j;
  global M;
  for i from 2 to 7054 do
How does this  function  work:
rtable_scanblock( M, [rtable_dims(M)],
    (val,ind,res) -> `if`(val > res[2],[ind,val],res),
    [[1,1],-infinity]);
Please could comment on each statement.
Taken from  http://www.mapleprimes.com/questions/131889-Finding-A-Max-In-A-3d-Plot#comment131997
Gracias
xsys11demo.mw
The attached worksheet (xsys11demo.mw, first-order non-linear ODE system) is ~x100 (one hundred) times slower that the "same" program in Mathematica 8. Both give the same/satisfactory numerical results and have similar/identical structure (I can supply the Mathematica 8 notebook, if requested).
I assume that my attached worksheet must be sub-optimally programmed and would be grateful...
Like this! Some error. How to do it
[IMG]http://i730.photobucket.com/albums/ww309/ytyyutianyun/Capture-6.png[/IMG]
I have the function which I run well in Maple V
but in maple 15 .It's wrong. How can it be? and please help me to edit it.
for i from 0 to 15 do
t:=1+i/16;
p.i:=plot(sin(x*t),x=-10..10,axes=none):
display(array(1..4,1..4,[[p0,p1,p2,p3],[p4,p5,p6,p7],
[p8,p9,p10,p11],[p12,p13,p14,p15]]));
Hi everyone,
I guess the question I am asking is quite common, however I am still not able to figure it out. I have several (right now three) non-linear inequalities. Given these inequalities, I try to plot them in one graph and then color the different areas with different colors. It would be also ok, if just the area where all inequalities hold is plotted. To do this I have already tried several things. With implicitplot and transparency it is generally working, but...
First 1749 1750 1751 1752 1753 1754 1755 Last Page 1751 of 2430
