Hi Everyone:
As far as I know maple has no way to define key bindings for it's actions.
I would however like to be able to navigate around the worksheet using hjkl keys - namely alt+j would be equivalent to down_arrow, and so on. I find that I spend more time reaching for the arrow keys or the mouse than writing useful code (I might be exaggerating slightly here ;) ). I can implement this behavior easily using my window manager (FVWM) - meaning the window...
I am trying to simulate the penetration of the wavefunction into a potential barrier consisting of two barrier steps of different heights, V1 and V2.
My code looks like that:
> restart;
> m := 0.91e-30;h := 0.1055e-33; V1 := 10*0.16e-18; V2 := .8*V1;a := 0.10e-9;En := .6*V1; w := En/h;
Hi experts,
I would like to ask what is the defult method's name for the numerical integration?
Hey guys,
How do I find a max in a 3d plot? I've tried plottools[getdatat] but keep getting the error of
"Error, index must evaluate to a name when indexing a module"
I am trying to solve the following system of quasilinear PDEs for dependent variables pA(z,t), pB(z,t), pC(z,t) using Maple 14:
> system:= [
.15e-3*diff(pA(z,t),t)+.83e-1*diff(pA(z,t),z)+.47e-3/(1+.11e-6*pA(z,t)+.14e-4*pB(z,t)+.73e-4*pC(z,t))^2*((1+.14e-4*pB(z,t)+.73e-4*pC(z,t))*diff(pA(z,t),t)-.14e-4*pA(z,t)*diff(pB(z,t),t)-.73e-4*pA(z,t)*diff(pC(z,t),t)) = 0,
.15e-3*diff(pB(z,t),t)+.83e-1*diff(pB(z,t),z)+.90e-1/(1+.11e-6*pA(z,t)+.14e-4*pB(z,t...
I have a problem with the Brownian Motion (I'm using Maple 15).
Here is the code:
X:=BrownianMotion(0,0,1,t);
X1:=SamplePath(X(t),t=0..T,timesteps =T/d):
Mean(X1);
The last line give me a number different from zero, which is not true for a Brownian Motion as defined.
Could you please tell me where is the problem?
PS: I have the same problem with WienerProcess(sigma).
1.how to plot a equation include two complex variables?
e.g.,0.1501071588582623569e-19 * s1 ^ 2 - 0.1770422954406499377e-11 * s1 ^ 2 * s2 ^ 2 + 0.1526369514180028298e-19 * s2 ^ 2 - 0.8979700309848614490e-12 * s1 ^ 4 - 0.9507487955845430138e-12 * s2 ^ 4 + 0.4941234607542336257e-4 * s1 ^ 4 * s2 ^ 2 + 0.5029096170369867504e-4 * s1 ^ 2 * s2 ^ 4 + 0.1631266049971375518e-4 * s1 ^ 6 + 0.1557291987414385136e-4 * s2 ^ 6 - 0.3925287034197085366e3 * s1 ^ 6 * s2 ^ 2 - 0.5855115617172747465e3...
how to write a procedure in which the in put is any number and out put is odd or even integer?
I would be thankful if someone help me to generate primitive polynomials (of deferent degree if possible) defined over GF(2^16), i.e., the coefficients of the polynomials are in GF(2^16). Thanks in advance.
I have to  solve following ODE set as a part of my MsC thesisr^2*Hr[r, r]+(r+(1/2)*r^3)*Hr[r]+(r^2-4)*Hr+2*R*(1-exp(-(1/4)*r^2))*Hi-(1/2)*R*r^2*exp(-(1/4)*r^2)*Sii-(1/8)*R*r^4*exp(-(1/4)*r^2) = 0
I would like download Maple 15.1. Please Help.
Hi all!
Please I'm having difficulties in specifying a repeat count for my format descriptor in Maple. For example,
If I want to repeat the format descriptor "%-+8.4f" ten times, is it compulsary that I write it explicitly as shown below?
fprintf(file, "\n%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f%-+8.4f",e[5],mp[5],zp[5],mt[5],zt[5],roc[5],ac[5],pnloc[5],fs[5],qcode[5]):
I know in Fortran, a descriptor such as "10F8.4" is possible....
Hi everyone!
Please can some one show me how to implement the "system" command on Maple 13-Windows OS to include the specicfication of the input and output file path? I would appreciate a useful response. Thank you...
I have asked a similar question before but it appears that the difficulty of what I need to do increases when the cases are simpler.
Essentially I want to check that an expression has been fully simplified. Suppose that:
A:=2(a+b);
B:=2a+2b;
Is there any way to test so that
evalb(A=B) returns false?
In my case, both A and B are obtained from MathContainers:
A:=GetProperty('MathContainer1','expression');
I hope this is the right place to ask, as the links for Maple Student Help were dead. I'm trying to assign a range of values to a name in order to solve questions about binomial distribution using variations of the function shown below:
First 1751 1752 1753 1754 1755 1756 1757 Last Page 1753 of 2430
