Can you divide 2 polynomials with Real coeffs.   eg 1.87x3-2x2+5.789x- 3,2 by    1.5 x2+2x-1.4 to get the quotient and remainder? If so how?
hello
my duty variational iteration method for solving nonlinear equations with maple code need finding.
I looked but I could not google
please help me
Suppose that S1,S2,S3 are 3 blocks of a matrix S := Matrix(...). I would like to do
out := ArrayTools:-Concatenate(2,convert(S1,vector),convert(S2,vector),convert(S3,vector)):
but in the case when I have n blocks.
Dimitar
given : A(n+1)=2*A(n) , A(0)=70
write a procedure and find A(5)=?
> dsol1 := dsolve({-(diff(y[1](t), t, t))*sqrt(y[1](t)^2+y[2](t)^2)^3/y[1](t) = 0, -(diff(y[2](t), t, t))*sqrt(y[1](t)^2+y[2](t)^2)^3/y[1](t) = 0, y[1](0) = 1, y[2](0) = 0, (D(y[1]))(0) = 0, (D(y[2]))(0) = 1});                             dsol1:= >
Why the result can't execute?
I am aware of how to plot the feasible region defined by a system of linear inequalities (inequal in the plots package). Also, I can use the implicitplot command to plot the feasible region defined by a single nonlinear inequality. My question is, how do I plot the feasible region defined by a system of nonlinear inequalities. For example, how would a graph the region satisfying x>=0, y<=exp(-x), and y>=x^2?
i stroe the x coordinate in arry A, and y in arry B
for example
A:=araat([x1,x2..,xn])
B:=ayaay([y1,y2..,yn])
how can i plot this data,
i had tried the follows expression:
plot(x,y)  or plot(x[i],y[i],i=1..n)
but they all return the wrong answer, why?
given a recursive sequence : J(n)=b*A(n)  for b=0.5 , A(0)=70% , n is integer
wrote a procedure to find J(n), for example: find J(5)=?
i need help with this please .
I hope someone can help me.
I'm trying to integrate the following equation:
sin(v))*sqrt(cos(t)^2+4*sin(v)*sin(t)*cos(v)*cos(t)*sin(w)+4*cos(v)^2-cos(w)^2*cos(t)^2+cos(t)^2*cos(v)^2*cos(w)^2-5*cos(t)^2*cos(v)^2)
The boundaries are
v=0..1/2*Pi
w=0..2*Pi
I've tried evalf and simplify, but none of those worked. Does someone know how to solve this one?
Can someone explain to me why when "x:=vector(2):" is used in the code below, the file "test_file.c" is generated correctly, while when "x := Vector(2,symbol=v):" is used, there is an error:
Error, (in codegen/makestat) symbol or symbol::type or symbol:=expression expected in parameter list
with(codegen, C, makeproc):
#x := Vector(2,symbol=v):
I'm creating a table of random math problems for my daughter to print out.  How do I get more columns?
a := rand(1 .. 15):
b := ["+", "-", "x", "/"]:
for i to 15 do
  print(cat(a(),b[rand(1..nops(b))()],a(),"_____")):
  print(``):
                                  13x4_____
I have written a 20-page program created on Maple 14 Classic Worksheet that generates holding patterns in crosswinds.  The program requires about 10 input values.  Can this be migrated to an Ipad or accessed from an Ipad?
How can I define the following commands of MATLAB in MAPLE,
MATLAB:
zimag=j*[0:thetas/N:thetas];
zreal(1:length(zimag))=log(R);
z=zreal+zimag
Also
MATLAB
For i=1:length(z)
Your help will be really appreciated.
Best Regards
A.Q
SOTON
I have two list, x1 and d, I want to make a piecewise function out of them and plot it, but I may have some other stuffs like this so I decided to write this procedure in a proc, the proc makes the input of the piecewise right, but when I want to make a function out of this and pass it to plot this does not works properly, I tried something else; first assigned a seri to a variable and passed it to the piecewise to make a function out of it this does not works either, but when...
I have program in txt,I want to copy it into the command-line maple 15 as belows:
How to do it. Ctrl+V is useless
code:
> MEMBER := proc(x::anything, L::list, p::evaln) local i;
> for i to nops(L) do
> if x=L[i] then
> if nargs>2 then p := i end if;
> RETURN(true)
> end if
> end do;
First 1747 1748 1749 1750 1751 1752 1753 Last Page 1749 of 2430
