Let M(1; -1; 0) be a point, Delta: (x-2)/2 =(y+1)/(-1) = (z - 1)/1 be a line, (P): x + y + z - 2 = 0 be a plane. Find the coordinates of the point A lies on (P), knowing that the line AM perpendicular to the line Delta and distance from the point A to the line Delta equal to sqrt(33/2).
This is my code
 with(geom3d):
point(M,1,-1,3):
line(Delta,[2*t+2,-t-1,t+1],t):
plane(P,x+y+z+3=0,[x,y,z]):
a:=ParallelVector(Delta):
Is there a bug in the CodeTools:-EncodeName / DecodeName pair?
Consider the following minimal example:
with(CodeTools):
M := module() option package; export f; f := proc() end proc; end module;
EncodeName(M:-f);
DecodeName(%);
The EncodeName gives answer:
_Inert_ASSIGNEDLOCALNAME("f", "PROC", 0, _Inert_ATTRIBUTE(_Inert_NAME("protected", _Inert_ATTRIBUTE(_Inert_NAME("protected")))))
But applying...
how to find concavity of f(t)=(800-t)t/(100+t)
Hi:
Consider this trivial (very contrived) example:
a:=lambda+3;
b:=Vector([lambda-2, lambda+23]);
subs(lambda=1, a); #works as expected
subs(lambda=1, b); #works as expected
assume(lambda, real);  #seems like this causes a problem
subs(lambda=1, b);  #This substitution does NOT work - lambda stays as 'lambda'
I am using maple 15 on...
I converted an ode using the built-in "convert" tool to check some calculations I had done by hand. To my surprise, there was an inconsistency. I converted the ode using PDEtools[dchange], reproducing the steps I had followed manually, and they checked out. So my question is: is there a sign error in convert? (and therefore a bug) or are both conversions correct, and if so are there any lessons to be learned? (is it related to the equation's symmetries?)
Thanks for your comments.
isnin:=proc(A)
local i,j,f,B:
B[1] := 0:
for i from 1 to numccs do
f:=Size([entries(B)][i][1],2); <---
for j from 1 to f do
if Equal([entries(A)][1][1],[entries(B)][i][1][j]) then
return false:
end if:
return true:
Do you know why maple wont evaluate f?
If it's not something obvious context is below...
If there's some equivalent to a dynamic array in maple I'd really like to know!
I am currently taking a course in quantum mechanics using the second edition of McQuarrie's Quantum Chemistry text. I plan to take a QM II course, more concentrating on atomic and molecular spectra. I have been using Mathcad 15, which includes Maple functionality (please pardon my stating the obvious). Mathcad, however, seems to lack functionality (or I have not found it) that would be helpful, like the ability to easily define an operator. Since...
Find the polynomial y=f(x) such that f(-6)=2400,f(-4)=432,f(-3)=120,f(-2)=16,f(-1)=0,f(0)=0,f(1)=-8,f(2)=0
Hello, I export a plot in an eps format (since other formats have lower resolutions) and want to insert it into Word 2007.
But, everytime when I do this, the Word 2007 will respond error occurred while importing the file.
Could anyone help me to resolve this problem?
Thank you very much.
Hi All,
Thanks for checking out this question. I am working a semi-strange integral and am having trouble getting Maple to evaluate it:
int(((15-x)/((232/7)-((19/14)*x))),x=6..x)
I am getting the response:
"Warning, unable to determine if 464/19 is between 6 and x; try to use assumptions or use the AllSolutions option"
I'm...
I have some numerical data, which are very accurate (500 digits) and want to copy them on a text file.
For pratical reason I would like the procedure writefile to write just 20 digits figures: which is the right syntax to use?
Dear Mapleprimes,
I need to plot a graph for different values of a specific parameter, sigma. It would be great if I could plot them in two separate coordinate systems right next to each other, such that I can copy paste them into my article. Could anyone help me with that?
Cheers,
C
Dear Mapleprimes,
I have a problem with a graph. I need to plot the following:
plot({1/(1-x)}, x=0..2, y=0..4);
But I don't want the vertical line at x=1. How do I get rid of it?
Cheers,
Christian
How it works to be so fast?
impl_plot.mw
Is it somehow related to other wonderful tetralogy:
http://www.mapleprimes.com/posts/95845-Generating-Samples-From-Custom-Probability-Distributions-I?
Implicitplot
First 1769 1770 1771 1772 1773 1774 1775 Last Page 1771 of 2430
