http://www-igm.univ-mlv.fr/~gauthier/HYPERG.html
> Read("D:/Feb2012/HYPERG.mw"); with(HYPERG);
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received HYPERG
HYPERGLIB := "D:/Feb2012/";
libname := libname, HYPERGLIB:
both methods above.
after typing PolyRecSol(H...
no result in Maple 15, just return similar command, no equation return.
Hello Maple wizards,
I have two questions for you today.
First, a program I'm developing in Maple 15 does frequent matrix multiplication with a constant float[8] matrix. I hope to take advantage of multiple processors in my 6-way desktop processor and/or CUDA features of the Nvidia GPU card. The program is large enough that maintainability and good programming practice dictate that it be broken down into multiple procs. In addition, I'm considering...
I haven't posted here in a while, and am not sure how to enter things, so this may not post correctly. But what I need help with is how to animate the following so that they will actually "draw" the heart shaped implicit plots either from the top down, or the bottom up, or however else might look interesting.
I'm trying to approximate points with a function of certain form with Statistics[NonlinearFit]I expect the graph in the second example to be closely approximate of the points, just like the first graph. For some reason, the second graph is way off. Seems like a bug. Any suggestions are highly appreciated.
Here is the code
plotApprox := proc(listName)
local X, Y, convModel, modList;
I have a region x^2 + y^2 <= 1 and y>=0. It's temperature function is f(x,y) x^2 - 2y^2 + x + y. How do I find the max and min temperatures on the lower boundary y=0?
I took the derivatives with respect to x and with respect to y such that:
fx:=diff(f(x,y),x);
fy:=diff(f(x,y),x);
Then I used fsolve({fx=0, fy=0},{x,y}) which game me (-0.5, 0.25)
Is there really only one critical point on that lower bound...
Hi, I'm trying to have my half circle divided into equal gaps of 33 , but am not sure what to use. I tried using Array, Sequence, Matrix... But don't think i'm doing it right. Here is what I have :
gap :=pi/(16*2)
I want a sequence of [0,0.0982,0.1963,0.2945,0.3927etc] in a vector form. May I know what is the proper way to do it please?
Many thanks.
Please write for me a code this problem.
Write the equation of the plane passing through the two points A(1,-2,4), B(3,5,-1) and make a least angle with the plane x + y + z + 1 = 0.
Thank you very much.
Why in next code i must apply operator twice?
zzz.mw
inert form eval procedure
dear sir, I want to use maplesim to import the modelica model of truetime network, but failed. the model is writen in modelica 2, is there any way to sovle this problem?
Write the equation of the line passing through the point A(2, 2, -5), parallel to the plane (P): 2x +3y -z - 17 = 0 and cut the line Delta: x = -2 +3*t, y = 4-t, z = 5 + 2*t.
1) First code.
with(geom3d):
point(A,2,2,-5):
line(Delta,[-2+3*t,4-t,5+2*t],t):
plane(P,2*x+3*y-z-17=0,[x,y,z]):
parallel(Q,A,P):
Equation(Q):
coordinates(intersection(B,Delta,Q)):
Equation(line(AB,[A,B],t));
Let A(1, 2, 3) be a point; d1: (x-2)/2 = (y+2)/(-1) = (z - 3) / 1
d2: (x--)/(-1) = (y - 1)/2 = (z  + 1) / 1.
Write the equation of the line passing through the point A, perpendicular to d1 and cut d2.
This is my code
restart;with(LinearAlgebra): with(geom3d):
A:=<1,2,3>:
B:=[2*t+2,-t-2,t+3]:
M:=<-m+1, 2*m+1,m-1>:
line(d1,B,t):
a:=convert(ParallelVector(d1),Vector):
v:=M-A:
Is there programs or algorithm to obtain resultant of multivariant polynomials for more than 2 polynomials
Dear Sirs
How to change font there?
Debugger window
a:='a';
                               a
assume(a>0);
H:=a;
                               a
subs(a=b, H);
First 1768 1769 1770 1771 1772 1773 1774 Last Page 1770 of 2430
