create the function f(x)=(x2,x=<0), (2x, 0<x<1), (2sin(Pi.x/2),x>=1). how do you find derivative in one command and integrate f(s)ds from -1 to 2.
I have created a MapleSim model including a few custom components. When I try to run the simulation, I receive the following error:
cannot resolve function `Main.'Typesetting:-mambiguous'`; there is no function `'Typesetting:-mambiguous'` visible in model `Main`
How do I know where the source of the error is?
Thank you,
Behzad
how do you analytically and numerically solve the IVP: y" + 4y' + 13y = cos2t, y(0)=2, y'(0)=-1.
Let A(1,0,0) be a point and two lines
d1: (x-5)/3 = (y-1)/1 = (z - 2)/2,
d2: (x-5)/1 = (y-1)/1 = (z - 3)/3
Let B and C be two point lies on d1 and d2, respectively so that the three points A, B, C
If log105 =c and log2050=d express log940 in terms of c and d ?
Hey everyone.
I have been trying to solve an ODE with BC with dsolve,numeric but always get the error below:
> Error, (in dsolve/numeric/BVPSolve) matrix is singular
My problem is not solving it (ie fine to do with LinearAlgebra package or similar), but why does this error occur? What is the problem with the ODE/BC that produces this error?
And is there a way of adjusting the ODE/BC to be able to solve it simply by using dsolve,numeric?
On my Dell Latitude E5400 laptop with up-to-date Fedora 16:
$ maple15
    |\^/|     Maple 15 (X86 64 LINUX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2011
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
>  log[2](8);
I've been trying to solve eqn1,eqn2,eqn3,eqn4 for T[water],T[air],T[Al],T[plastic] by using the defined variables listed above the set of eqn's, but everytime I get the "Warning, solutions may have been lost". Is there a solution to this or are the eqn's unsolvable?
> restart;
> h[infinity] := K[infinity]*(0.37e-1*RE[infinity]^(4/5)-871)*Pr[infinity]^3/L[plastic]:
> h[plastic] := N[plastic]*K[plastic]/L[plastic]:
> h[water...
Problem. Write the equation of the plane passing the point H(1,1,1) and cut the coordinates axes Ox, Oy, Oz at A, B, C respectively so that H is centre of the circumscribed of the trianlge ABC.
This is my code.
with(geom3d):
A:=:
B:=:
C:=:
H:=:
f:=(x,y,z)->x/a + y/b +z/c-1:
solve([f(H[1],H[2],H[3]) = 0, Norm(H - A, 2) = Norm(H - B, 2), Norm(H - A, 2) = Norm(H - C, 2)],{a,b,c}): assign(%):
Problem. Write the equation of the plane passing the point H(2, 1, 1) and cuts the coordinates Ox, oy, oz at A, B, C respectively so that H is orthocenter of the triangle.
This is my code.
with(geom3d):
A:= <a,0,0>:
B:=<0,b,0>:
C:=<0,0,c>:
H:=<2,1,1>:
eq:=solve([f(H[1],H[2],H[3]) = 0,DotProduct(B-C, A-H, conjugate = false...
Simply using display(array) we can create larger zoomed sized plots that I think some people would like but only for 2d but what about 3d plots ? - read on.
Now this expands only the width of the plot and works for all 2d plots.
a:=plot(sin(x)):
display(array([a]))  # displays plot at screen width size
What I think most people want is an easy way to adjust plot sizes from the default Maple install without having to load any special packages ...
I've made exam questions for students that they have to answer by doing some calculations in Maple.
I would like to let them copy the commands they used to a Maple TA text field.
However, the standard worksheet in our computer lab uses 2-D math. Copying this 2-D math to Maple TA works fine with "paste as plain text", but copying 1-D math also works with ctrl-v in Maple TA, which is more convenient for students under stress.
Since I am not allowed change...
Hi everyone.
I am currently trying to write the gradient projection algorythm for an optimal control problem with Maple.
This involves calculation of the gradient of the objective function at every new iteration, which would be not a problem per se. However, in optimal control problem this last depends on state and costate variables which, in turn, are given by the system of ODEs. This system is solved numerically only. As far as I understood Maple is recalculating...
Am i undestand right that all GUI-changed properties of plot are not accessable via command-line because with already pictured plot there are no binded variables and no method to bind? For example after manual streching and moving i need to work in interest area of graph i.e. includding new textplots there and so on. See only way to work with via DocumentTools component and it events to get e.g. xrange  and yrange. Is there better way?
Cannot find own answer in
http://www.mapleprimes.com/posts/100884-Precision-And-Plot-Drivers
via searching in my answers. Is it because original message is too old and thats why should be so?
First 1773 1774 1775 1776 1777 1778 1779 Last Page 1775 of 2430
