with(Statistics):
Phiinverse := (x) -> Quantile(Normal(0, 1), x) :
evalf(Phiinverse(1-1/2^24));
and the result is 5.691523310-2.147372008*I
Now, I can get a real-valued solution to this by using the equivalent
functionality from stats instead of Statistics.
with(stats):
PhiinvClassic:= (x) -> statevalf[icdf, normald[0, 1]](x):
evalf(PhiinvClassic(1-1/2^24));
I have coded maple script and got that error. How can I fix it?
Here is my code error.mw. Please help.
raw_panel_cuttin.doc
 Given a large rectangular wooden panel, you want to cut specific quantities of smaller rectangles from it.
Hi.
I have two complex functions with 3 variables: z1,z2,t . I need the first derivative of one of these functions with respect to one variable onle. Here is what I did:
f1:=z1(t)+2*z2(t):
f2:=z1(t)-3*z2(t):
diff(f1,z1(t)) this gives me an error. I need to write the variable as z1(t) not z1 because I'm doing some calculations for different time.
Thanks for the help.
     I just purchased Maple and I am just learning calculus pretty much for fun.  I am reading "Calculus Made Easy" by Sylvanus Thompson.  On page 56 there is a set of equations for which I would like to know the steps.  I was wondering how to do this in Maple.  I played around with the Student and Tutor commands, but can't seem to get it to work.
     The equation is y+dy=(x+dx)^-2
hi,
how to change coordinate system?
for example :
diff(f(x, y), x)   =   (diff(f(r, theta), r))*cos(theta)-(diff(f(r, theta), theta))*sin(theta)/r
thx;
aryan.
There i see
for advanced users, see the routines `simplify/size/size` and `simplify/size/size/object`.
How to write coorectly in maple 15 those calls? From maple 5 (it was ~10 years ago ) i hardly remmember
that f/x also could be treated as function call f  at x or smth. like that...
I am going to use maple in connection with my project concerning non-linear dynamic and chaos, but i have never used the program before, so I hope you guys can help me with that,
I have a model of non-linear dynamic system as following:
dA/dr = k + m * Y(r) - A(r) * B(r) * B(r) - A(r)
dB/dr=1/q * [A(r) * B(r) * B(r) + A(r) - B(r)]
dY/dr=1/s * [B(r) - Y(r)]
the values of the parameters are:
k= 10
q= 5 * 10^(-3)
s=2 * 10^(-2)
simplify(expr, power, symbol, size);
- simplification by size proceeds 1st or last?
Ok, when I run the below code which maximize the risk adjuested portfolio returns
(long and short positions) in QP matrix form on empirical data I get very strange
allocations ie we go 100% or 100% short in almost all stocks except for a few
where the allocations are more appropriate like 0.2 etc.
# Maximize Risk Adjuested Return Matrix Form
# Minimize W'.Cov.W−W'.EV
# R=Return Matrix
EV := Vector([seq(ExpectedValue(Column(R, i)), i = 1 .. N)], datatype = float[8]):
if maple cannot factor something, does it mean it cannot be factored for sure?
i have a really really long univariate polynomial with coefficients that are also variables (a[0],a[1] etc), is there any tips on how to factor this monster?
thanks in advance!
well first of all this site was very useful for doing my homework, but there is still something I didnt find on it and im sure other people may find it useful.
I have a system of 5 ode's and 6 initial conditions that ive solved successfully and plotted the graphs i need:  Position VS Time
          Speed VS Time
The only thing I initially know is the final position, which i can read on the first graph and...
I've found no questions about these types of functions. When I try to solve this equation by using the FOC function and then try to isolate one of the variables 'effort' (or optimal effort) the outcome is about 6 lines of algebra. When I use simplify it expands even further. What other options are there to get a 'nice' expression?
to find the maximum number of rectangles that can be orthogonally packed into a larger rectangle:
http://lagrange.ime.usp.br/~lobato/packing/run/index.php
1) can some maple code replicate this?
2) but what i really want is: what arrangement of a given a number of rectangles (of differing widths and lengths...
Professor is working in Maple 13  I have Maple 15 just started using this.
He types
DE1:=diff(TS(t),t)=3*k[abs]*IO*f/4/r[O]/c[W]/rho[O]-mu*T[O]/(s+1)/r[O]^2/C[W]/rho[O]*((Ts(t)/T[O]^(s+1)-1);
I can not type the math in this format in Maple 15. Can anyone help me, I keep getting error messages.
CRS
First 1794 1795 1796 1797 1798 1799 1800 Last Page 1796 of 2430
