I have n second order differential algebriac equations (symbolic). I need to convert this system to [A]{X''} + [B]{X'} + [C]{x} + D =0,  where X is the column vector containg the variables and A,B,C,D are the coefficent matrices of X'', X',X and the constant term matrix respectively.
Is there a way to generate this matrices in Maple?
Giving a expression as follows, how to extract  powers of g to a list?
 In this example the list of powers of g is {2,1,2}
6*F*u[0, x]*g[x, x]*g^2+24*F*u[0]*g[x]^3-18*F*u[0]*g[x]*g[x, x]*g+2*F*u[0]*g[x, x, x]*g^2
      i am new to maple before getting this software i need to know how it works in order know that i want trial version of maple software how to get this trial version please suggest me some idea...
I have one 2d and one 3d animation that I want to play at the same time.
p1:=animate(sphereplot, [exp(6*sin(t))-1, theta=0..2*Pi, phi=0..Pi], t=0..3, frames=100):
p2:=animatecurve(rhs(sDE), t=0..3, frames=100):
display({p1, p2});
Error, (in plots:-display) cannot display 2-D and 3-D plots together
I also tried using:
p2:=animate(implicitplot,[(i)^2 + (j)^2= (rhs(EQ2))^2,
                               i = -exp(6)..exp(6),
                               j = -exp(6...
test.zip
1) Compile under vc express 2010 debug config. Don't forget point out your location of maplec.lib in configuration properties/Linker/General/Additional library directories. Assure that configuration is at least Debug or all.
2) Run sheet test_bombard.mw from Debug directory.
Have permanent crash on BombardByRandoms call. If i would transmit creating of rtable from 'InitInternal'...
I've just registered my copy of maple and I'm trying to figure out how to use it to find the arc length of a curve on a given integral. My function is: upper limit 0, lower limit -3; and after the integral sign, the square root of 1+4x^2 dx.
-JerJohn123
I have a pretty simple problem. Given the following set of responses to a "yes (y)/no (n)" question, create a pie chart and a bar chart.
y, y, n, n, n, y, y, n, n, n, y, y
I would like solution that does not involve coding the data, say y = 1 and n = 0. I am aware of the BarChart and ColumnChart commands in the Statistics package, but I can't seem to get them to work with nonnumeric data. Is there an easy way to do this?
I downloaded the Modelica_Fluid 1.0 Library from the Modelica website. When I try to import this library into MapleSim5 I get the following error:
Duplicate class definition found for Modelica_Fluid.Pipes.BaseClasses.WallFriction.Detailed.msim/UNKNOWN
I then click "ok" and the importing stops working with the last message being:
Querying Modelica classes...
Can anybody offer help with this?
Christian
Consider a "toy system" of floating-point arithmetic where each floating-point numberis of the form
x = (-1)s × (1 + m) × 2e-σ:
The mantissa is a binary number such that
m = 0:m1m2m3 (base 2) belongs to [0; 1)
and the exponent e is a binary integer such that
1 ≤ e = e3e2e1e0 (base 2) ≤ 14:
Each m
I have a solution containing many exponentail terms, some of which are in the denominators of rational terms. I would like to be able to have the solution given to me in a manner where there are no exponentials in denominators but only in the numerators. The simplify command in maple does it, however for the shear number of terms (just shy of 400,000 terms and maple saying it's million plus) i am looking at, that particular command is just taking too long (15 hours!). Is there...
Is there any  function  in maple to compute the SVD of a matrix  using jacobi method? Or anybody has maple code to do so?
b) Define a procedure f(x, y) which returns 1 if x < y and 1 if
Hi friends,
I am running an application which consumes big memory and the result was given smoothly
but after 5 hours I running the program again but in the middle of calculation the maple give message show  I got this error:
Execution stopped: Memory allocation failed! Please see
I am currently writing a Python program which takes a Maple Worksheet and evaluate the commands in the terminal version of Maple. However, I have trouble figuring out how the input is formatted. As an example I have following XML code in a .mw file:
<Input><Text-field prompt="&gt; " style="Maple Input" layout="Normal">
<Equation executable="true" style="2D Input" input-equation="A := 4;"
display="LUklbXJvd0c2Iy9JK21vZHVsZW5hbWVHNiJJLFR5cGVzZXR0aW5n\
Dear guys!
I want to solve this system:
> c := 1: RC := 0.03: h := 1: m := 0.3:
> a := H(z)^2/(1+z)-h^2*(m*(1+z)^2+2*RC/(1+z));
> ode1 := diff(H(z),z) = (H(z)^4/((1+z)^2)+m*(1+z)*h^2*H(z)^2-2*m^2*h^4*(1+z)^4)/(2*H(z)*a) - (2*H(z)*h^2*RC)/(a*(1+z)^2) + (2*RC*h^2*(1+z)/(c*H(z)^2*a))*(H(z)^2/(1+z)^2-(H(z)^2/(1+z)-m*h^2*(1+z)^2)^2/(4*RC*h^2))^(3/2):
> ode2 := diff(M(z),z)=3*M(z)/(1+z)-2*M(z)*diff(H(z),z)/H(z):
> sys := {ode1, ode2}:
First 1803 1804 1805 1806 1807 1808 1809 Last Page 1805 of 2430
