Ok, this mut have been asked a million times, but for the heck I cannot find how to do it:
I have a data file with many columns of data, delimiited, and many rows. I can read this in with ImportMatrix no sweat. The generated matrix has (row,column) format, i.e. matrix[1] is row 1 etc.
Now I want to plot two arbitrary columns against each other, say matrix[][19] vs matrix[][13] (the 19th column vs the 13. column). The data are monotonic in each vector so I can...
Hi.
I have defined a function "norma" that calculates the normal vector in a point "r" in a given surface:
norma:=proc(l,r) local nu;
if r[1]>= l/2 then nu:=[r[1]-l/2,r[2]];
elif r[1]<=-l/2 then nu:=[r[1]+l/2,r[2]];
Now I need to calculate an integral using this function varyign the parameter "r" but I get this error message:
> int(norma(l,[cos(x), sin(x)]), x = -1.5768 .. -.5638);
Error, (in norma) cannot...
I'm using Maple 15 with Suse Linux 11.4
Export to latex produces a tex file which, when conveted by pdflatex contains all sorts of errors. The page margins are very large, parts are missing, the title appears alone on a page, lists of equations don't have line breaks so, for a long list you find just the central part going from edge to edge of the page.
I gave up using "Export to latex" on earlier versions. I had thought that Maple 15 might be better, but it seems worse.
Q1) Could you pls tell me how can I show in maple the curve (x^2+y^2)^2=x^2-y^2 in the form of
x(t)=cos(t)/1+sin^2*t and y(t)=sint*cost/1+sin^2*t.
Q2) how can I express sin^2(4x) in terms of powers of cosx.
a) cos^3(3x)cos(5x) as a linear combination of cosines of multiples of x.
how can i solve matrix ?
for example :
Matrix(4, 4, {(1, 1) = 18, (1, 2) = -45, (1, 3) = 36, (1, 4) = -9, (2, 1) = 9, (2, 2) = -18, (2, 3) = 9, (2, 4) = 0, (3, 1) = 0, (3, 2) = 9, (3, 3) = -18, (3, 4) = 9, (4, 1) = -9, (4, 2) = 36, (4, 3) = -45, (4, 4) = 18})
I have a module to overload the * operator for the function f such that:
a*f(b,c,d) = f(a*b,a*c,a*d)
FPackage :=  module()option package;    export `*`;    `*` :=    overload    (      [        proc(a::algebraic, b::specfunc(anything, f))          option overload;          map2(:-`*`, a, b...
Could uou pls tell me how to do a parametric representation of the curve in maple where curve is define as
(x^2+y^2)^2=x^2-y^2 . Secondly how to plot this curve.
m(x[i]) = product(x[i]-x[j], j = 1 .. N)              i <> j
ex:
for N=4
hey,i'm trying to divide the values i get using this
y := 23.45*sin((360*(x+284))/365):
seq(evalf(y), x = 1..365);
by some imported data....how do i do this?any good advice will be appreciated.Thank you in advance
Judith
How to find the sum
sum(tan((1/180)*(4*j-3)*Pi), j = 1 .. 45)
 explicitly? Of course, with Maple.
I am trying to solve a system of six equations with the command solve. Unfortunately I only get the message "Warning, solution may have been lost". If i try to solve only five equations, i get an answer, that could be right.
My questins is: Is there a mistake in the syntax of solve? Or, is my equations system wrong?
Thank you!!!
Maple code:
> restart;
> FZ := 0 = FLZ+F11Z+F12Z+F21Z+F22Z+F31Z+F32Z;
I've this task to deliver to my teacher, yet when i try to open up my maple file, it appears to be corrupted (i've no idea why) i used it last night without any problems? ...
The only part that opens is the headline...
Need assistance!
Rapport_1.mw
Ive tried several commands, but none of them will give me a response
Here are the points im working with:
u = (2, -3, 1), v = (-4, 3, 3), w = (2, 4, 6)
And here are the several commands ive tried to use, with "with(LinearAlgebra), with(geom3d)" implemented before:
1.
volume([2, -3, 1], [-4, 3, 3], [2, 4, 6], parallelepiped)
> with(plots, display);
> volume;
display(parallelepiped, axes = normal, scaling = constrained, orientation = ...
I have 91 points and to take the sum of the y-coordinates, I do
sum('points[k,2]','k'=1..91);
But if I want to take the sum of the points on just the even indeces i.e k=2, 4, 6, 8, 10...etc, I try to do
sum('points[2k,2]','2k'=1..91)
but Maple gives me an error. I'm doing something wrong here. Help me please me fix the syntax error!!
I am using Maple first time to solve equations. Equations and error message are as belows:
> solve({a(3.05-c)^b = 0.7400000000e-4, a(3.10-c)^b = 0.1806000000e-3, a(3.75-c)^b = 0.5840000000e-4}, [a, b, c]);
Any solution, what is going wrong?
Nurul Islam
First 1805 1806 1807 1808 1809 1810 1811 Last Page 1807 of 2430
