In polar coordinate, when we differentiate er, it becomes e[theta]. However it seems Maple can't do this, even I have set it into polar coordinate.
How can I allow maple to do this?
Any Example can help see the difference between contour and simple integration?
int(XXXX, x, method = contour);
int (XXX, x)
which example can help to see the difference?
Why that Find / Replace doesn't work?
Wnat to rename some variables but it doesn't seem to find text in eval-cells at all :(
hi
I wan`t use maple to solve my problem
x1[n]= ej*( Π/6) *n
Hey, so i guess i dont really know whats going on. I am trying to install Maple 10 on my Macbook Pro. I get an error message Uncaught exception in main method: java.lang.NoClassDefFoundError: org/apache/crimson/parser/XMLReaderImpl when i try to open the program. Any help?
Want to do smth like that:
Call EvalMapleStatement from c dll.
expression always has form like "F(0.4, 0.7, 0.9);" i.e. maple defined function called. All i need it's value without any kind of caching. But memory usage dramatically grows. Help to overcome it!
Tried already EvalMapleStatement ("forget(F);") - do not work. I'm out of ideas what maple also caches. F itself is complicated enought. And not known a priori. How to clear all caches of other functions that f might call?
How to make maple to change ln(exp(x)) = x?  for example exp(ln(x)) = x, or ln(exp(x+1)) = x+1
How can I most succinctly and straightforwardly get Maple to simplify f below to g below?
> f:=(6*x^2-6*x+6)^(1/2)*(2*x^2-2*x+2)^(1/2);
                          (1/2)                 (1/2)
          /   2          \      /   2          \
          \6 x  - 6 x + 6/      \2 x  - 2 x + 2/
> g:=simplify(f) assuming x::real;
                        (1/2) / 2        \
                     2 3      \x  - x + 1/
> simplify(g-f...
I want to plot a random ... no, sorry, normal distribution of points around a line.  Let's supose we use the line sin(x) from x=0..2*Pi as an example.
I have a complex nonlinear long term, I have not found a way to simulate this expression,how I can apply the method of least squares
I want to evaluate an approximation of the solution of the equation eq1 in [0,1] using 4 digits.
In first try, when I first write Digits:=4,  this seems avoid the command fsolve to display the solution.
In second try, when I write evalf(fsolve(eq1,beta=0..1),4),  evalf seems avoid the command fsolve to display the solution.
In the final try, when I write
> fsolve(eq1,beta=0..1):
> evalf(%,4);
I have...
when i use u and t in the lower bound of summation, everything works fine, as you can see, proc(2,10) gives me a number.
now, if i change u to T[3] and t to T[2], suddenly we have a problem! What gives?
I've finally tracked down a problem I was having to a behavior in Maple I find, possibly, understandable, but need to figure out how to prevent.   Specifically, in expressions of the form x^y, where both x and y may sometimes be zero, the behavior I require is for Maple to evaluate y first so x^0=1 whatever the value of x is.   (Maple does evaulate 0^0=1 itself, I note.)
An example where this sort of thing comes up is in an expression like
sum(x^k,k=0..5)
Sequencing sequences doesn't appear to work with round brackets
seq( (seq(i,i=1..10) , seq(j,j=9..2,-1)) ,k=1..4)
First 1812 1813 1814 1815 1816 1817 1818 Last Page 1814 of 2430
