I have tried to solve a certain problem but I can't go on since
Maple can't do rational functions computation.
questions.mw
I wanted to solve Wx1v for funcF1 but Maple couldn't.
So I solved it manually. If I substitute F1 into Wx1v,
Maple should give 0. But it doesn't. Maple couldn't simplify
computations. Any help? Thanks!
Is there a way to change the font size when doing an "export as pdf" from the file menu? It it currently much to big for me (both in plots as well as other text). I use worksheets (not documents) exclusively.
tryed to compile samples\OpenMaple\cmaple\omexample.c in MS Visual C++ Express 2010. Everything is OK but after running is writes "The program can't start because maplec.dll is missing from your computer..." Why? I've linked maplec.lib statically! Besides \Maple\bin.win\ in my library path where both maplec.dll and maplec.lib are. System - Win7 Home Premium +SP1
Why doesn't HTTP[Get] work with the question mark?
for example
a := HTTP[Get]("www.mapleprimes.com/recent/all")  # works to get the first page
a := HTTP[Get]("www.mapleprimes.com/recent/all?page=2")  #  Shows file directory not found
How do I get it working so
Hi simulators
Is there an easy way to give a global time frame/limits for all plots: typically I need to simulate a few seconds to get rid of all my transients, and then I would like to zoom in on the effect of interest. Now I have only found out how to reset one by one each graph via the axis properties, I have a dozen graphs per simulation 4 variables to scan over ten points each, that makes a damn lot of graphs properties click to reset, results: I need 60 sec to...
Download tgh.mw
Hey guys im having trouble opening this file
tgh.mw
Please i need it urgently.
I need a procedure to multiply a fractional number by an integer (n), to produce (the closest) integer (m).
eg 1.333333 * 3 = 3.99999 (4)
i/p fractional number
o/p: n=3, m=4
rgds
Let a partition of a planar polygon into colored polygons be given, i.e. something similar to
  We know the coordinates of the vertices and the color of each part, e. g. in such a way:
>with(plottools): with(plots):
>display(polygon([[.12, 1.28], [3.07, 4.54], [3.41, 1.69]]), color = red, thickness = 2, view = [-1 .. 5, -1 .. 5]);
Student here. I'm having a real hard time with Maple's help. Can someone tell me how to create F, without having to type the whole thing in (like I just did) each time I change N. F is really just columns of omega raised to the (column-1)*(row-1) power
I also need help with the syntax for pulling out a column of F, and multiplying A (an NxN matrix) by that column,
A*F(column n):
>restart;
>N:=2^3;
>ω:=N->e
I am looking for an implementation of the Mathematica equivalent of RegionPlot whose description should be like:
RegionPlot(pred,x=x_min..x_max, y=y_min..y_max) makes a plot showing the region in which pred is True.
For example, I would like to execute:
> RegionPlot(f(x,y) > 0 and g(x,y), x=x_min..x_max, y=y_min..y_max)
where g(x,y) outputs True/False.
One idea I had was to use:
> densityplot(`if`(pred,1,0...
I wanted to vary my mass item in MapleSim5, to have it appear and dissapear. I noted I could us the variable "1*t" [kg] in a rigid body mass item, that worked out fine
Then I wanted to have a force variable depending on the time, but now I get a message Main.t is not defined in Main
So finally how to refer correctly to the "time" ?
Subdiary question: how to use signal blocks to generate a named variable that I use elswhere in my model for a Parameter input
Dear guys! I'm solving a system of ODEs in a for loop with different initial conditions and after that in each loop I use the result to solve an integral and after all I find the minimum value of integrals. But the problem is that when I write for loop with for example 100 initial conditions I get a result and when I expand the numbers to for example 1000 initial conditions where include the 100 previous one maple tell me that the initial conditions that make the integrel minimum are the same ...
Dear guys! I'd like to know that for solving an integral by maple we have to use " int " or we have any other choices? Because I have an integral with large limits from 0 to for example 1000 and it takes much time for maple to solve it.
Using the tree structure example from ?GraphTheory[DrawGraph] using showlabels=true the highlighted areas are merged and no amount of zooming can seperate the merged yellow areas.
Another issue, I don't see the advantage of style=tree when a tree structure can only be printed if the original DrawGraph is already represented as a tree style structure when...
I would like to solve x1v for funcF1(funcr(x),x)). I did similar computations before.
I think Maple can deal with rational functions very well. It's having a trouble to
use the common denominator the simplify x1v.
> denom(Wx1v);
2 2 2
-barv + funca(x) D(funcP)(funcr(x)) funcr(x) ...
First 1815 1816 1817 1818 1819 1820 1821 Last Page 1817 of 2430
