Hi. I am interested to find the pdf of this moment function: phi(t) = exp(a * b / p (e^(a*t) -1))
This is a moment of random variable Y = aX where X is a Poisson random variable with rate (a*b/p)
I want to know is it possible to find a pdf from its moment in maple?
If so how?
Best Regards,
Saeid
Sorry to bother you again,fellow primers.A few days ago I asked a similar kind of q.,but here is some change, & I'm stuck again.
int(p^(D-2)/(exp(beta*p)-1), p = 0 .. infinity) assuming beta::positive, D::posint #D>0 & is an integer,this two are the only restriction on D,nothing else.
 I'm not getting any result (correct/incorrect).
The  result is  GAMMA(D-2)*Zeta(D-2)/beta^(D-2).  #Zeta is the Riemann zeta function.
can someone give help or a hint on how to overcome the faulty result in the pdsolve problem with radiation bc described in the following worksheet? I tried also with different method, but no success. the result from pdsolve makes physical no sense, because under pure radiation bc (h=0) the body should cool down and not heat up!
maple_heat_rad_pdsol.mw
btw, the problem was reported befor, see:
How to compute the highest total degree of a polynomial in which a variable, say x, appears?
For example, f := x^2*y+3*x*y^2+x^3*y^3-x^5+y^4*z^5;
then the highest total degree in x is 6.
The degree command does not seem to do what I would like to do, since degree(f,x) will give 5 instead.
Thank you in advance.
Dyson_Mclean_V3.mw
Dyson_Mclean_V5.mw
Hi All,
I have a question that I see has been seldom discussed except certain posts by Mr. Lopez. This concerns the estimation of optimum parameters of the solution of a system of differential equations to fit experimental data. I referred to the Maple document provided by Mr. Lopez on the Maplesoft website.
Good morning.
I want to do a program in a worksheet that it can recall other workeet for plotting with display.
I don´t know how can recall other worksheets.
Please help me.
P.D.: I send a worksheet 01-06-2011-robot-man.mw
I am new to Maple so I don't know if this is expected behavior or simply a setting or command I need to set.
When I calculate (12x2y2)/4xy, I get (3x2y2)/xy instead of the simplified 3xy. Is this normal?
Perry
I am tring to solve two coupled pde's with piecewise/Heaviside conditions. I am puzzled with the maple error...Rhop, Rhos are constants n given some values..
> pde_sys:=[diff(c(m,t),t)=(2/m)*diff(c(m,t),m)+diff(c(m,t),m,m)-(convert(piecewise(d(m,t)<Rhop,(Rhop-d(m,t))*d(m,t)*c(m,t)),Heaviside)+(Rhos-d(m,t))*c(m,t)*convert(piecewise(d(m,t)>Rhop,Rhop,d(m,t)),Heaviside)), diff(d(m,t),t)=convert(piecewise(d(m,t)<Rhop,(Rhop-d(m,t))*d(m,t)*c(m,t)),Heaviside...
Like when I type
1/2^2;
it gives
1/4
but if I type
0.5^2;
it gives
0.25
I want it to consider 0.5 as 1/2, because sometimes I make computations on large equations and I want to have access to the symbolic output, not the numeric output.
Hello all,
I am trying to solve a pde system with piecewise conditions numerically but unsucessful. Here's what i am doing:
> restart;
> sys:=[diff(c(x,t),t)=v(x,t)*diff(c(x,t),x$2),diff(v(x,t),t)=piecewise(c(x,t)>v(x,t),c(x,t)*diff(v(x,t),x$2),0)];
> bc:={c(0,t)=2,c(1,t)=1,c(x,0)=0,v(0,t)=1,v(1,t)=2,v(x,0)=0};
> sol:=pdsolve(sys,bc,type=numeric,time=t);
I am getting the following error.......
Error, (in pdsolve/numeric/process_PDEs...
I am trying to solve a transient heat transfer problem.
The problem is that I have an insulated pipe that is immersed in cold water.  At time 0, the fluid filling the pipe is at a constant temperature.  The insulation at one end of the pipe is different to the rest of the insulation.  I need to find out the time that it would take any fluid to reach a certain temperature, called the cool down time.
A graphic representation of the...
Is there an easy way to find the limit of the following equations as Pec_i approches infinity.
 Equation 1
(Q*(R*S+1-S)/(1-R*R3*k*(1-R1)/C/Pec_i*S)*(H_vap+1/(1-exp(Pec_i)))*exp(C*Pec_i/(R*S+1-S)*(1-R*R3*k*(1-R1)/C/Pec_i*S)*S/k)-H_vap)*(1-exp(Pec_i*(1-S)/(R*S+1-S)*(1-R*R3*k*(1-R1)/C/Pec_i*S))) = 1;
 Equation 2
 Theta0/C = (exp(Pec_i/(R*S+1-S)*(1-R*R3*k*(1-R1)/C/Pec_i*S)*(1-S))-1)*(H_liq+1/(1-exp(-C/k*Pec_i/(R*S+1-S)*(1-R*R3*k*(1-R1)/C/Pec_i*S)*S)));
when try to solve this pde, got error
i know function h already, just try to guess its pde, initial value condition is calculated from known function
motion := {diff(h(x1,x2), x1)^2 + 2*diff(h(x1,x2), x1)*diff(h(x1,x2), x2) + diff(h(x1,x2), x2)^2 = 0};
ic := {h(1,x2)=ln(1-x2-(1/2)*c),h(x1,0)=ln(1-(1/2)*c*x1)/x1};
monster := pdsolve(motion union ic);
Error, (in pdsolve/sys/info) found functions with same name but depending on different arguments in the given DE system: {h(1, x2...
1-(1-x1)(1-x2)....(1-xn)=1-(inverted PI).
Is there a simbol for the Inverted PI?
Does the series sum((-1)^floor(ln(n)^2)/n, n = 1 .. infinity) converge?
First 1858 1859 1860 1861 1862 1863 1864 Last Page 1860 of 2430
