HI,
I wannt to ploting vector form, such as [a_i + b_j + c-_k =0].
This vetor is not matrix form but equation form with direction.
I also express magnitude of vector and direction of vector in plot.
For example, I define a vector, 3*i + 2*j + 1*k = 0, and I want to ploting in 3-Dim with direction.
Waiting everybody advise.
Maple version : MAPLE11
Major : physics
Hi there,
I was woundering if there is a function implemented in Maple11, where I can enter a function and it's domain, and the output is the range. For example:
Entering f(x)=x^2, and the Domain x in (-1,2), I would want Maple to tell me that f(x) is in [0,4).
Is there such a function implemented? I need this quite often, most times on functions from R->R, but also more general for functions from R^n -> R^m. I know that in some cases you could...
I was wondering if there's a simple way to add something like an interpolation loop to a procedure. For example, say I have a function of 2 vars which is expensive to compute, f(x,y). I can use option cache to speed up points which are already computed, but is there an easy way to interpolate between them using ArrayInterpolation? That is, if f varies on scales of order 1, if I have calculated it at 0.1, 0.2, then It can be guessed with a spline at 0.15 accurately enough. What...
The question is to find the area bounded by x = 0, x = 4, y = 0, y = 1/(1 + x6).
I am assuming I am going to use int, but I don't really know where to go from there.
dear community
I have  problems 1): in solving "rational difference equations" in Maple.
what is the code for solving this kind?
2): plotting difference equations
3):openf and printf command" how I make my results in the same folder as a table?"
Help_Lplot.mw
I cannot get the proc Lplot to work in the worksheet above. Will someone please help?
When I type "hypergeom([a+1,b+1],[c+1],z);", Maple switches "[a+1,b+1]" to "[b+1,a+1]" when using the 32-bit command-line interface.  This does not happen when using the graphical java user interface, nor with the 64-bit version...
Why does this happen?
-- Regards,
Franky
I'm having trouble using the Jacobian command for predefined vectors. I have defined several 3x1 matrices, concatenated them to a 12x1 matrix, then when I'm taking the Jacobian I get the following error:
Error, invalid input: VectorCalculus:-Jacobian expects its 1st argument, f, to be of type {Vector(algebraic), list(algebraic)}, but received Matrix(10, 1, {(1, 1) = v[x], (2, 1)...
Can anyone tell me what I'm doing wrong here?
Thanks so much in advance!
I need to find the eigenvalues for a matrix using the power method in Maple 14 . I want to iterate Xn+1=PXn until it has reached a certain degree of accuracy where P is my matrix and X is a column vector.
I have tried:
> while(abs(X1-X0)>0.0000001);
> do
> X1 := X0
> X1 := PT.X0
> end do;
but I get this error: 'Error, unable to parse'
Please could someone help?
upload.mwDear all, Can someone find what my mistake is?
Hi to all,
I would like to know where if I could plot two functions (both are computed by "if statements") on the same graph and could maple read "where" like VB (if ...where...end if)
Your help is appreciated
hi
i have tried Maple help but could not find any answers.
would appreciate some help on how to construct an algorithm for a Pell's equation with D = 29 (x^2 - D*y^2 = 1)
That is x^2 - 29*y^2 = 1.
i know that there is an infinite number of solutions, but would appreciate the first 5.
(x_1, y_1), (x_2, y_2), ... , (x_5, y_5)
many thanx,
antonio
hi. i write a program consists a for loop in which cycle 'i', x[i] and hz[i] is calculated.
now i want to plot hz[i] correspond to each x[i].
this code is working but how to brief them?
hhz := piecewise(x < X[1], hz[1], X[1] < x and x < X[2], hz[2], X[2] < x and x < X[3], hz[3], X[3] < x and x < X[4], hz[4], X[4] < x and x < X[5], hz[5], X[5] < x and x < X[6], hz[6], X[6] < x and x < X[7], hz[7], X[7] < x and x < X[8...
I have the following procedure that generates Sierpinski's triangle:
seirpinski := proc (n)
> local Mat, Vector1, Vector2, Vector3,
> Prob1, Prob2, Q, prob, counter, fractalplot;
> Mat := linalg[matrix]([[.5, 0.], [0., .5]]);
> Vector1 := linalg[vector]([0, 0]);
> Vector2 := linalg[vector]([0, 0.5]);
> Vector3 := linalg[vector]([0.5, 0]);
> Prob1 := .333; Prob2 := .333;
> Q := linalg[vector]([0, 0]);
> writedata("fractaldata", [[Q[1...
First 1887 1888 1889 1890 1891 1892 1893 Last Page 1889 of 2430
