I guess someone is kidding with me...
I want unsubscribing of this s... place!
when calculating the following equations
int( exp(t*int( (m/2*(diff(x, t))^2-exp(x)), t)), x)
maple give
-Ei(1, t^2*exp(x))
what is Ei? how to show result normally?
Can anybody please help me I posted this question last week and didnt get the response I was looking for. It is a question about explicit finite difference methods for pricing an option.
I understand the mathematics behind this and everything but I am not able to code it. This is where the probelem lies.
I'm using Maple 14 on OSX 10.5.8.  I have a lot of expressions that look like this:
sum(a[n+2]*x^n*(n+1)*(n+2), n = 1 .. infinity);
(which doesn't seem to be rendering here...so in 1D form)
My problem is the when using default fonts and 100% zoom the plus signs in the subscripts aren't...
I'm hoping that someone can help with this.  Below is an example of what I would like to do (part of a larger application):
> roll := rand(0 .. 1);
> roll();> s0 := %;
> roll();> s1 := %;
With each execution, this will yield values for s0 and s1 that are randomly...
SADE is a package used for symmetry analysis of differential equations. I downloaded the package from the link http://cpc.cs.qub.ac.uk/authorIndex/AUTHOR_F.html. But unfortunately, I even couldn't execute the examples given by the authors of the SADE. Please inform be about installing the package in Maple 14.
So, I've defined procedures in a .mw file and now I want to somehow read this file into another worksheet, in order use the aforementioned procedures. Is this doable? I've unsuccessfully tried using the READ command. The error messages I get are :
Error, on line 1, syntax error, character `?` unexpected:
<?xml version="1.0" encoding="UTF-8"?>
Error, while reading ``file.mw``
Not sure where to go from here. Any help would be great!
I am trying to graph some curve C and the vectors from the vector field corresponding to t=1 and t=-1.
My Vector Field is defined by some F(x,y,z) and my Curve is some r(t) [didn't bother putting the actual values here since I only want a general expression...]
In other words I want to have some kind of a curve in 3D with vectors coming out at points t=+/-1 along the curve itself. Is there any way to do such thing?
If one types
seq(cos((n mod 3)*Pi,n=2..13);
Maple returns, correctly,
1,1,-1,1,1,-1,1,1,-1,1,1,-1
If one types
sum(cos((n mod 3)*Pi),n=2..13);  # surely the sum of the above sequence = 4
Maple returns, incorrectly, the value 1.
Sure enough, if one types
sum(cos((n mod 3)*Pi)*exp(n),n=2..13); # expecting the sum of e^n with every third term negative
Maple returns
e^2-e^3+e^4-e^5+e^6-e^7+e^8-e^9+e^10-e11+e^12-e^13  ...
How do I plot a Matrix's columns independently in a same display[plot].
A=Matrix(m,n)
plot(Column(A,1),Column(A,2),..,Column(A,n))
Gracias
I would like the title of my y axis to say "SaO2 (%)".  When I put in "SaO[2] (%)" the output is SaO[2] (%); However, when I put in SaO[2] (%) the output is "SaO2 PLOT (...) "  How can I get both parts correct (i.e., the subscript of the 2 and the displaying of the percent sign)?
hello i  hope if you can help me.
 i have a problem solving this recurrence relation and how to insert if statemen (about  with for loop
and using the series and the solution should be
1-2y(2)-6y(3)-14y(4)=0
y(2)-y(3)-11y(4)=0;
-y(2)+3y(3)+8y(4)=0;
I need to plot solid sqaures and include the figure in a paper.
The plotdevices jpg and ps do NOT support this. Is there a special way to put solid symbols in these? What plot devices support solid symbols?
Hi, Im trying to show the first few energy levels of a particle in a 1-D box. The plots are looking how i want them to look, but i can't stop it from producing loads of unwanted code. It seems to have been produced from P1 and P2 and putting a colon after them doesn't supress the output.
Can anyone see how i can stop the blue code from being shown and keep the plots?
I just copied this from the Maple 14 documentation
f := proc( { [color,colour]::symbol := RED } )
    sprintf("color=%a   colour=%a", color, colour)
to get
"Error, invalid procedure parameters"
Anyone any ideas? It's the same in Maple 12 and 13.
First 1889 1890 1891 1892 1893 1894 1895 Last Page 1891 of 2430
