Suppose I want a random sample of 500 numbers
RandomSample(Normal(0,1)),500);
Good, now if I am understanding properly [0,1) means positive values with a mean of 0 and standard deviation of 1.  However in Maple RandomSample(Normal[0,1)),500); is not allowed due to bracket mismatching.
how do I get the RandomSample domain [0,1)?
Hi all I've a program running that has been stopped with the error Execution stopped: Stack limit reached. at that time the program was using memory used=480073.6MB, alloc=594.8MB, time=16330.02 The host computer has 16 CPUs and 50Gb of Ram, so I don't think the problem is the memory... Any hints? Thanks Salvo ps: I've found an old discussion about this problem, but it was very old (2005, M9) so I've thought I could open a this one.
I am trying to solve a set of 4 coupled ordinary differential equations, starting from certain set of initial conditions for certain parameter values.  i have to evolve the system for a very long time (higher number of iterates are needed).
For a certain set of initial conditions the following error occurs
"Error, (in sol12) cannot evaluate the solution further right of 2939.9221, probably a singularity"
what could be the possible way to get rid of this error.......
I'm new to programming.
I don't understand what I'm doing wrong in this
If anyone could help me with this, I'd very much appreciate it.
See the attached picture called "equation". That is the differential equation I'm trying to solve. The graph (for m=1) should like as it does in the other attached picture called "graph".
I tried this
with(DETools):
m := 1;
de := diff(y(x), x, x, x)+((m+1)*(1/2))*y(x)*(diff(y(x), x, x))+m*(1-(diff(y(x), x))^2) = 0;
DEplot(de, y(x), x = 0 .. 8, [[y(0) = 0, (D(y))(0) = 0, (D(y))(infinity) = 1]], y = 0 .. 1);
But goes this error message
Error, (in DEtools/DEplot/CheckInitial) initial point in all initial conditions must be the same
I don't know how to get around this because my initial conditions are what they are, I can't change them.
Does anyone know of a way to fix this or know of a better way? The reason I need this is because I need to get the graph for m=0.77, which isn't in those photos.
 Any help is appreciated.
Im  writing a loop which starts by solving a circle equation,  how do i instruct maple to follow another another set of instruction if no real roots are found?
im looking to do something like this
(x1a, x1b) := fsolve((x-h)^2+(eq2-k)^2-r^2)
if real roots are found, do this
else, do something else
end if
I hope im clear enough on what im asking. If not, please let me know.
Lovinash
I have a matrix, let's call it A. I want to define a new matrix by taking every n-th row in the A matrix. How do i do that?
For example,
A= | 2 3 5 |
     | 9 2 1 |
     | 5 1 2 |
     | 1 8 9 |
the B, if n=2, is equal to
| 2 3 5 |
| 5 1 2 |
I'm trying to model Conway's game of Life and I keep running into the same error mesage. I've narrowed the problem down to this line of code
S0 := [[0,0,0,0],[0,1,1,0],[0,1,1,0],[0,0,0,0]];
n:=4
X:= Array(0..n-1,0..n-1,S0)
Error, bad index into Array
I don't know what this error message is or why I'm getting it, any help would be appreaciated.
Hi, sorry to post this as I have read past topics about roots but havent really understoond much.
I have an equation that gives 8 roots. some of them can be real and some can be imaginary. how do i list them separately? I attach the worksheet...
View 11295_21feb.mw on MapleNet or Download 11295_21feb.mw
View file details
Hi to all
I want know that can we slove the following equation
F(l)^2-(A1-A2*1/(l*coth(l*(S0-1))))*F(l)+A3/(l*coth(l*(S0-1)))-A4=0
where
F(l)= coth(l*(S0)))/coth(l*(S0-1)));
Is this possible from mathematical point of view?
 It make any sense to slove the above equation?
When simulating an electrical circuit I decided to eliminate a subsystem block but later changed my mind. Now I'm unable to use the same name for the subsystem block as before despite the fact that there seems to be no place where it is used. Always an error "The name blabla is already in use". Can I somehow list all the names and the places where they are used?
I have been trying to do this for some while now but am not having much luck.
Basically what I need is a hermitian matrix, with real values on the diagonals X~N(0,1) and complex values on the off diagonals X~N(0,1/2)+i*N(0,1/2)
Obviously as its hermitian I need Xij = Xji*
I have tried a few things but can't get anything to work correctly, in my latest attempt I decided to try and construct the 2x2 case from scratch using if and for loops;
for i to n do
for j to n do
if i <> j then
restart; with(DEtools); phaseportrait([(D(x))(t) = -.1+x(t)^2-x(t)*y(t), (D(y))(t) = y(t)^2-x(t)^2-1], [x(t), y(t)], t = -10 .. 10, [[x(0) = 0, y(0) = 1], [x(-2) = -2, y(-2) = -1], [x(0) = 1, y(0) = 0], [x(0) = 0, y(0) = 0]], stepsize = 0.5e-2, scene = [x(t), y(t)], linecolor = t, x = -4 .. 4, y = -3 .. 3) I want to explicitly draw the hyperbola with arrows in the direction of the vector field. How do I obtain this? With the initial conditions I get solution curves that I dont want.
# Hello!
# I've been trying to replace one expression into another, which includes the derivative of a quotient, but algsubs doesn't work and I don't know why.
# To make it simple, I want to replace a expression from rho into the expression for q_x. Let's say rho is a function of alpha.
> restart;
> alias(rho = rho(x, y, t)); alias(rho_an = rho_an(x, y, t));
> alias(p = p(x, y, t));
> alias(q_x = q_x(x, y, t));
> alias(alpha = alpha(x, y, t));
> rho_an := alpha;
Can someone help me please? I cant find what is wrong. thank
View 16354_take13.mw on MapleNet or Download 16354_take13.mw
View file details
Nash
First 2033 2034 2035 2036 2037 2038 2039 Last Page 2035 of 2431
