Situation:  I have multiple lists of the form [i$i=1..n,0$k] , where n is a positive integer and k is a nonegative integer.
Desired result:  For each list, produce a list of permutations of the list (as you would receive from combinat[permute]) such that in each permutation, the nonnegative integers in the list appear in ascending order from left to right and no two nonnegative integers are adjacent to one another.
Here is a simple sequcnce of commands that execute without a problem:
eq1 := 5+3*x=0:
eq2 := 2+7*x-3*y-5*x*y=0:
x:=solve(eq1,x):
y:=solve(eq2,y):
lprint('x'=x,'y'=y);
x = -5/3, y = 29/16
If I put the commands into a procedure there are problems:
How can i ignore the singularity and gain values past this point? i get:
cannot evaluate the solution further right of 2.6991460, probably a singularity.
the program decsribes the motion of a double pendulum, so that the equations used show their angles relative to a normal...i want to gain information about these angles from a static point as time procedes. therefore the points will go back on themselves.
alex
I have a question concerning list.
I want to calculate value of X which is sum of x[i]
And there is a list L of length n whose i th element is x[i].
How can I do it in maple using procedure? Hence, use this procedure to calculate L:=[1,4,5,6,8]
Thanks~
please help me here
suppose we know the following for a function which we donot know
x0 and f(x0)
x0 and f ' (x0) (first derivative at x0)
x1 and f(x1)
x2 and f(x2)
how can we approximate second, third and fourth derivatives of f(x)  for example say at  a point x3
I'm using maple 13 in document mode. When I want to designate a variable as the time derivative, I use the over dot symbol. The problem is that the output is displayed with the full derivative symbols in leibnitz notation. It's really hard to read when the my outputted equations are very long with higher order time derivative terms. Is there a way to get the output to be just displayed with the over dot symbol.?
Thankss
hi
how can we compare the malpe calculation and manual calculation.
I mean if we use maple to have a solution (different form) and then try to get the same solution manually (compressed form compare to maple), now i want to compare both the solutions using maple, whether the two solutions are same or not.
I'm plotting some random points along a curve but I'm not sure of a couple of things so I have a few questions.
Using a simple curve like x for example.  First I'll choose some random numbers, 100, between -8 and 8, but I also want a couple of decimal points otherwise random integer values will only give me a maximum of 17 points.  So is the best way to do that like this?
a:=[seq((rand(-800..800)(i))/100,i=1..100]    # These will be my x point values;
I have used bubble sort to put my list in order but now i need help to rearrange the list.
For example l:=[2,2,2,3,4,5,1,3,7,8,9]
Bubble sort:= [1,2,2,2,3,3,4,5,7,8,9]
What i want to do is do, smallest&largest,next smallest & next largest
Like this - [1,9,2,8,2,7,2,5,3,4,3]
So as you can see its been rearranged so that their all next to each other.
Any help would be great.
Hi, all, I want to know whether I get a row of a matrix. For example, I have a matrix: [ 1 0 0 1] [ 0 1 0 1] M=[ 1 0 1 0] [ 0 0 0 1] and I want to the first row [ 1 0 0 1], how to do this? thanks Gepo
hello, i am generating an eigenvector of three elements. i need to assign each element a parameter...u,v,w. so for example if the vector is [1,2,3] then i want to assign u=1,v=2,w=3. can somebody pls show me.
the big picture is that i have 4 roots, and for each root i will have 4 eigenvectors, and i need to assign them to u[i],v[i],w[i], where i=1..4.
thank you
I read this forum http://www.mapleprimes.com/forum/plotsunits  in which it says you have to extract units beforehand to plot.
The problem is that I have a lot of functions and I can't remove units by hand, so I wanted to use the command convert(........,unit_free) but  with no result
The function in the convert command is a piecewise. I upload the file
supporse for a function f(x) (which we do knot know), we know
x0  and f(x0)
x1 and f(x1)
x2 and f(x2)
how can we find best approximations for the first , second, third and fourth derivatives?
hi i think this is an easy one,
for a from 1 to 3 do sol:=solve(x^2=16*a,x) end do;
ok this gives us 6 solutions, 2 for each value of a. how do i display a particular solution?, for example i just want to display the solution when a=2, and then i just want the second solution of a=3... hope this makes sense
Hi, I'd like to substitute the expression A into B, where B is of the form
B:=a*x+b*y+c*z+D(f)(p*x+q*y*r*z),
where a,b,c,p,q,r, are constants. The problem is: I only want the substitutions to be done outside of the unknown function f. So, if
A:=x=4*u,
First 2037 2038 2039 2040 2041 2042 2043 Last Page 2039 of 2431
