Currently I have 500 values, I put them in an array x:= [a,b,c,d,.....] then using with(Statistics) plotted my histogram with Histogram(x) but this doesn't give me a very accurate histogram and there are only 10 or so bars. How can I make this better?
Been looking for about 15 minutes, and there simply isn't that much to look through.
Using Maple 13.0, I can't find the "Find Discontinuities" option that a bunch of walkthroughs insist are in the Plot Builder's Options menu.
Anyone know what I'm missing?
Is it possible to create a procedure in maple that works out how many 'queens'  can be placed on a board size n * n and plot some sort of a matrix which displays the positions using 1's and 0's without conflicting with each other?? What i mean by 'is it possible' is would it be a efficient algorithm (if it is possible)  or a very long algorithm containing of complex maple code?
I want to integrate y=x^2 + 4 from a number to 7 for which i get the area under the curve to be 40. How do I write up a maple code that tells me that number?
Hello everyone
I have a cost function I would like to minimize. It is a fairly simple function that only contains multiplications and additions.
Only problem is, this function has about a hundred variables, but they can only be between the interval [0,1] so I guess it makes the problem easier.
Is it possible to write a little program in maple that can be ran as much as I want it to run and that could try to find an approximation of the actual solution? (By trying random numbers between 0 and 1)
Thank you very much
If I define two arrays in the following way:
for i from 0 to 2 do
for j from 0 to 2 do
A[i,j]:=[i+j]:
B[i,j]=[i-j]:
od: od:
Then if I try to add them and look at the 0,0th component of the result:
C:=evalm(A+B):
C[0,0];
I don't get an answer. (I've tried both the LinearAlgebra package and the linalg package.
What would I have to do to get them to add successfully ?
Download 10402_Massequ_MathCadCompare_v2.pdf
View file details
Sorry but my question os more for mathematica users: The DSolve result is not correct. What can I do?
Thanks for your advice.
Walter
Hi i am trying to code a procedure which sorts a list such that the smallest element is the first element and the largest element is the second elemnt then the next smallest element is the third element and the next largest element is the fourth element. For example:
L:=[ 2, 3, 5, 2, 7, 9 ]:
sorted:= [ 2, 9, 2, 7, 3, 5] :
this is what i have coded so far how do i make the process continue??
I have an expression that involves an unknown function, say g:
expr:=a*x[1]+b*x[2]+cx[3]+g(x[1],x[2],x[3]);
where a, b and c are the coefficients I'm actually interested in. These coefficients are not constants but usually expressions in some constant parameters. The function g is an expression involving derivatives of some more fundamental function (in my problem).
Example:
expr:=(q/r-sqrt(2))*x[1] + x[2] - (w*r+4)*x[3] + D(G)(x[1]) - D(G)(x[3]);
I have som 2D and 3D plots where I would like to change some parameters/constants interactively so that the plot updates automaticly.
I expect that some sort of scroll bar could be used to change a constant interactivly but I need a little help for what it is called in maple and a hint for how it is programmed.
regards Brian
Hi all I'd like to construct a phase portrait of a DE system with several different solutions on one plot. To do this I've been using odeplot for each solution and then displaying each plot with display(). Now I'd like for there to be arrows on each solutions, resulting in a phase portrait which will show the direction of phase flow for each orbit, but I couldn't find a way to add arrows to each individual plot. Is there a way to do that ? If not, is there a different approach to achieve this kind of phase portrait ? Thanks LR
I want to write a loop, which can give me the appropriate roots of a long equation.
I have tired to use a very simple loop, but the problem is that there are multiple solutions of the equation.
I want a loop which use newton methods to give me the satisfactory roots.
The funtion which I am dealing with is of the form sigma(l).
Plz help me out.
I have attached the maple file.
I have been using MapleTA for some years and very occasionally a student wil do something which results in him/her not being able to login. On login an error message looking something like the one pasted below occurs. In every other respect and for all other users, TA is running fine. As an administrator, I cannot find a way of resetting this user account. I have used a workaround in the past of creating another user but this is unsatisfactory for large student numbers. Has anyone else experienced this issue? Is there a common cause? Is there a way to reset the student's account?
Hi everyone,
when I use:
c:=2e-6*Unit(A*s/V);
then maple answers with the unit [F]. but when I use:
epsilon[0]:=8.85e-12*Unit(A*s/V/m);
then in the middle of a large document, Maple (Version 12) ignores [m] and still gives me [F]. On a blank (new) document the same command results in correct units [m^-3 kg^-1 s^4 A^2]. The behaviour is reproducible.
anyone knows why?
cheers :-)
First 2038 2039 2040 2041 2042 2043 2044 Last Page 2040 of 2431
